How fast have you taken the prius?
Discussion in 'Gen 3 Prius Main Forum' started by alfa737, Oct 6, 2011.
  1. alfa737
    alfa737 Member
    126
    27
    nice!
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I pulled out to pass a harvester and discovered it was fifth in line, by the time I was tucked back in my lane, 93 MPH
  3. El Dobro
    El Dobro A Member
    7,088
    3,270
    I had it up to 80mph once, still breaking it in. The speedo was reading 1 mph more than the reading on the GPS I was using.
  4. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Brief bursts of high 80's on my recent trip to NC from VT. Car felt fine, but I could feel my insurance rate tingling.
    Generally I travel at 68-70mph on the highway (65 limit here)
  5. Mark57
    2,945
    2,740
    OK
    113 mph on the GPS (115 displayed) for about 5 miles, flat access restricted road and no other traffic. I am not proud of it but I got the phone call you never want to get. My very upset Dad called and said Mom would not last the night, get here right now. Saying goodbye was very important to me. I dropped to 80 mph (10 over) once I caught the other traffic. The car was rock steady and still pulling right up to the limiter kicking in.
    Wolfstar and Daddyjeph like this.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm sorry, Mark. :(
  7. Mendel Leisk
    41,824
    Sorry, but I can't think of anything nice to say: I just hope that when the inevitable happens you don't maim or kill anyone else. Hopefully between now and then you get busted and pulled off the road.
  8. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    My 2010 tops out at an indicated 116, where the speed limiter chip shuts the engine down. Still pulling hard enough so you can feel it nose over as the speed limiter shuts the engine down.
  9. MariaEvri
    MariaEvri Member
    122
    Limassol - cyprus
    My fastest was 125-130km/h km/h when I was following a car that was supposed to show me how to get somewhere
    my usual highway speed is 115 km/h and my usual city speed is 60 km/h
  10. Jaquimo
    Jaquimo Paraglider, Prius glider...
    96
    Bloemfontein, South Africa
    My grandmother taught :nono: me that if I can not say :blabla: something nice :kiss: about someone :gossip: then I should keep my mouth :tape2: shut... :tape: :focus: :p
    striker308 likes this.
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    My fastest on a long straight back road to Swan Hill was 130kms/h on the speedo. I backed off voluntarily so didn't feel the limiter cut in.
  12. alfa737
    alfa737 Member
    126
    27
    i did not know that the engine can shut down.
    At 115 mph I dident feel the limiter chip shut down the engine.. now i have to try it again tommorow and take it past 116 mph to see it kick in...
    i am curious to see if that happens,
    also the car has 3000 miles on it now so can i consider it broken in?
    Daddyjeph likes this.
  13. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    115 for me - toll road driving (good conditions) - also got it to 115 on a local ex-marine base runway a few times (surprised it made it up to speed in that distance)...
  14. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    90-something
  15. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    alfa737
    Jaquimo
    Mark57
    Jon Hagen
    rrolff
    For those of you who actually got yours to 110+ What size/brand/model/speed rating tires were you using and what was the cold pressure in PSI?
  16. Mark57
    2,945
    2,740
    OK
    Michelin Primacy MXV4 195/65R-15 91H RRBL
    H rated to 130 mph / 210 km/h
    Cold PSI=42/40
    They had ~5,000 miles on them and were at ~100% tread depth.
    My situation was extreme and I don't recommend or condone it, nor am I proud of it.
  17. Jaquimo
    96
    Bridgestone Turanza 195/55/R16 87V @ 35 PSI (240 kPa) front, 33 PSI (230 kPa) rear
    87 = 1,201 pounds (545 kg)
    V = 149 mph (240 km/h)
    It was before I upped the pressure to the current 42/40 PSI (290/280 kPa).
    Why are you asking?
  18. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    My Prius seems to be extra squirrely lately and I don't know if that has to do with the tires.
    It still tramlines like crazy whenever grooves are present and you are driving over 55 mph.
    Pressure is 42/40. I don't know if I want to take it too fast.
  19. alfa737
    alfa737 Member
    126
    27
    I have the stock tires 15in that came with the 2011 prius 2. it is usually in the morning when going to work and no performance mods done to the car. sorry i dont have specific numbers for the tires.
  20. Silentum
    Silentum It's a mini Space Shuttle!
    Palm Coast, FL
    I
    I have reached 120 twice now on flat I-95 with no tricks, just on my own. The pedal feels like it has more room to go but if I take off Full Power and try I can only get to 109. Nothing about my 2011 Prius is modified, all stock, base model.
