TK Dual Exhaust Installed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Ragz, Oct 10, 2011.
  1. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
    It looks good! How much does the whole cat back weigh and how does it affect your MPGs?
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    It looks really good. If I were serious about aftermarket exhausts, however, I would look into GReddy exhaust systems, like this TRUST exhaust:
    WOOT!!! It feels good to be back!!! College applications are SOOOOO close to being finished, so I might just get back into this Prius thing. :D
  3. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    Ragz, are your sure it's cat back exhaust?? Mines is only rear section not even close to my cat
    BR
    Robert
  4. Ragz
    Ragz Active Member
    210
    110
    New York
    Thanks for the comments, I am not 100% sure it goes all the way to the catalytic converter, but it replaced the whole tailpipe, muffler and the section of pipe about 21/2 feet long to the first bolts. I assume that is where it attatches to the cat. As fat as weight and mileage, i can only tell you it is probably double the weight if the single exhaust, which is not heavy. This is my first tank with the new pipes so i will let you know. I will say I get alot of looks.
    32K-This weekend for the tail lights
  5. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    I gotta do my tails, too, but can't find the tools ANYWHERE here. I bought a kit for interior work that has all those tools, almost a month ago.....but still haven't received it.
  6. remco
    remco Junior Member
    Warwick, Rhode Island
    I took the short cut and added the dual exhaust tips for $35.
  7. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Interior removal tools - walk into Harbor Freight.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    If you have arthritis like you said you do, you should get them professionally installed.
  9. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I think it looks good, the whole car does actually.
    I installed the Tom's exhaust on my '06 Prius and it sounded nice, not farty or sharp at all, and not loud either. Just a remarkably deep, quiet note that went well with the car. I liked the appearance of the single oval tailpipe, too.
    Aesthetically, yours is very pleasing. Don't know if it's a bit too stylish for my taste—functionally speaking, four tips is a lot—but the pics look great.
  10. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Looks very nice. However doesn't it make it more odd? I mean now you have an audible "growl" when the engine is on like a normal car, but when you pull up to a light, it goes away. Are people looking "did the car just stall?"
  11. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    My dealership said they'd do it. Is it safe for them to do something like that? My concern is someone scratching up the lenses.... It's similar to a shiny black piano-ish finish, and I have a suspicion that they will scratch easily.... I have this picture in my mind of them laying them down, face down, on the concrete garage floor in the service dept...
  12. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
  13. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    So none of the ones in that kit I bought will be useful for the tail lights then?
  14. You could probably use one as a shoe horn and another as a back scratcher. Sorry man...:(
  15. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    lol.... A person never has enough good shoe horns....
  16. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    What are you referring to, "college applications.....??
  17. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    If you don't trust them, then use the body shop that you have "trained." After all, you're trusting it to install the Fledermaus kit you're getting.
    It can still work if it's thin enough to insert into the gap. Heck, even a sturdy 99 cent plastic putty knife can do the job.
  18. Ragz
    Ragz Active Member
    210
    110
    New York
    Thanks for all the comments. Different is good, some more different than others, but that is what this forum promotes. Everything I have done began with this forum.
    "Some times you just feel like a nut, sometimes you dont"
