Listing of 3rd Gen TSBs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Oct 10, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Is there a list of 3rd gen TSBs on this forum? I'd love to see if any of the TSBs address any issues that I've noticed with my car.
    Thanks!
    Swiick and Mainer like this.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Here is the list that I have copied so far from this forum. I am approaching 36k miles and did the same thing. I am taking my car in this week for the two brake upgrades.
    scedacity, Jin, CharlesJ and 12 others like this.
  3. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I think this would make a good "sticky" . A good complied list, JD!
  4. The Critic
    3,193
    2,333
    CA
  5. El Dobro
    El Dobro A Member
    7,086
    3,263
    So, the 11th digit of the VIN tells us which plant the car was manufactured at?
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes, the Japanese plant codes are:
    [FONT=verdana, geneva]0 = Tsutsumi plant line # 1
    1 = Tsutsumi plant line # 2
    5 = Fugimatsu plant
    [/FONT]
    4 people like this.
  7. tumbleweed
    4,067
    692
    Eastern Oregon
    Here are some more TSBs:
    Note: The "Pulling to One Side" TSB does not list the Prius but was included with Prius TSBs on the Toyota web site.
    Princer, subjective, RAP and 7 others like this.
  8. El Dobro
    El Dobro A Member
    7,086
    3,263
    Great, that comes in handy.
    Fyretuck and Jin like this.
  9. Bullet220
    Bullet220 New Member
    17
    Renton, WA
    Thanks for the summary!
  10. Bazil
    Bazil New Member
    44
    Erina N.S.W. Australia
    I
    My VIN label says , Plant = C25, any clues?
  11. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    VIN label could not say C25. To identify the Toyota's plant 2 digits are important only. 1st and 11th. For Prius the 1st is always J (=Japan) and 11th as Tumbleweed wrote few posts above. All Prius VINs should start JTDKN36U.....
  12. Bazil
    Bazil New Member
    44
    I
    Inside the L/H door opening on the "B" pillar is a label with model, frame number (VIN) colour, trim, date built and PLANT, which in my case is C25, I kid you not.
  13. UoD
    UoD Junior Member
    96
    Southeast USA
    Here is a link to what he is referring to when he says "plant c25" (from a Toyota Estima .. not a Prius .. but, it was all I could quickly find)
    Estima T & L - Estima Owners
    It's not in the actual VIN --- its on the other info plate.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    done...but we need a good way to keep them all listed in one spot. If someone will let me or the mods know when there is a new one we can add it to the top.
    Jin and jdcollins5 like this.
  15. wick1ert
    1,311
    183
    Delawhere
    Not to put the onus on anyone, but maybe Dianne could help us keep the list up to date? Aren't dealers typically the first to be aware of the TSBs?
    Sorry Dianne, but there's just so many good things said about you and you're so knowledgeable that your name jumped into my mind :)
    This is an area that I think it would be good to have on a page all by itself that only mods can update. TSBs and RECALLs as a possible section. Then a link with the PDF and a brief summary of what it represents. Maybe I'm taking it a little overboard, though. Sometimes I come up with a good idea, but the execution is a different story lol.
  16. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    There was also one for a headlight condensation issue, appears to be T-SB-0284-10. I don't have the pdf, but edmunds.com shows:
  17. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    :( Just saw the one for the XM Satellite Radio issue; I have experienced that issue myself, but now I am way out of warranty (60k miles). I don't think I would want to pay to fix it unless it was cheap enough, but I have a feeling it would be pricy. It doesn't happen enough to be too annoying, but it would be nice to fix...
  18. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Seilerts just recently added the latest TSB about the Engine Knocking at Startup. I have added it below.
    compac likes this.
  19. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    That TSB is not for the knocking that everyone is complaining about.., it resolves a droning or buzzing/vibration noise in extremely cold temps..., not the brief knocking most people are having on a cold startup...
  20. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Seilerts indicated that it was for the Engine Knocking. Why are you saying that it is not? Your source?
