when is it time for an Oil Change + filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ucsmfu, Oct 12, 2011.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    just want to know the limits for the prius,
    Most people change their oil and filters every 5-6k or 3 months.
    My delarship told me prius is very low maintenance, 2 oil changes 1 year and that should be it.
    What do you guys think ?
    inputs or thought ? I want to maintain it well, and which oils do you guys use ?
    thanks
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Dealer recommends oil change every 10k miles, and tire rotation can wait until then but you're welcome to do it at 5k like normal. Uses (I believe) 0W-20 oil, not sure what the dealer uses, obviously full synthetic is best, but the engine will last longer regardless because half the time it isn't running! :p
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Canada has a different OCI than the US. I first changed my at 1,200 just because I was dying to do it, than at 5K, 12.5K and I will do it next at 20K and probably stick with a 7.5K interval.
    Using M1, 0W-20 as specified.
  4. ETC(SS)
    7,379
    In Canada....it's 5K, at least the last time I looked.
    I do not know....maybe it's the climate.
    Down here in the USA, it's 10K.
    All of those are in miles, BTW. I'll let you do the math.
    Your call, but if it were me....I'd do what your maintenance schedule says to protect your warranty at least for the first 60K.
    Sorry.....those are miles again too.
    Good Luck!
  5. DonVentura
    DonVentura SoCal Prius Driver
    78
    Ventura, CA
    Every 10K miles, which for most is once or twice a year as you were told. Always use synthetic 0W20 (I use Mobile 1 which you can get for about $28 for 5 qt. jug)
  6. Mendel Leisk
    41,946
    Canadian schedule is 6 months or 8000 km, whichever comes first. Best deal I've seen on 0W20 is at the dealership, Toyota's own brand.
    The Canadian Owners Manual has all the info in there, but it's a bit of a jumble, covering every Toyota model. I've broken it down here:
    http://priuschat.com/forums/gen-iii...2010-prius-maintenance-schedule-canadian.html
    There's a few typos still, the transaxle fluid change interval is a little different I think. FWIW, a lot of owners do transaxle fluid change much more frequently, anyway.
    Other things need to be taken with a grain of salt. The cabin filter for instance. I just checked ours at 12 mo / 16000 km: it's pretty clean still, I just blew it out with compressed air with a little brushing and put it back in, for now. Likely will change at 2 year interval.
    Addendum: The service intervals are not actually in the Owners Manual, they're in the smaller book (called Owners Supplement, or something like that?) that you should have received. Again, it's spelled out in there, but the only practical way to make sense of it is to go through it line-by-line, and transfer the various bits of info into a chart. It's really a poor presentation.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    If you're curious, you could always get the an oil sample tested at the interval of your choice. I've used Blackstone Labs before.
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    yes on synthetic oil every 10K or 6mo, whatever comes first
  9. ucsmfu
    1,498
    420
    canada
    hey Mendel Leisk, i noticed in ur avatar that u live in Vancouver as well ?
    is there any local prius meets ?
  10. Mendel Leisk
    41,946
    Not that I know of, though there could be. I'm not much of a joiner, LOL.
    They are extremely common, seems like somewhere around 1/3 of the cabs are Prius, maybe more.
  11. ucsmfu
    1,498
    420
    canada
    hey, do you do your own oil changes as well or do you bring it in to the dealer for maintenance ?
    thanks
  12. Mendel Leisk
    41,946
    Do them myself, 2 so far.
  13. ucsmfu
    1,498
    420
    canada
    is there a diy video for that ?
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
  15. cyclopathic
    3,292
    547
    2014 Prius c
    the MOM (or in this case COM) recommends changing oil at 5K, 10K and then every 10K if synthetics are used.
    we have a Protege with 380K, no engine rebuild, which gone through life with 10K oil changes on M1. I'd bet Prius can up it.
  16. tumbleweed
    4,067
    692
    Eastern Oregon
    What viscosity oil does your Protege use? I have no doubt the the Prius engine is capable of many long dependable miles with 10K changes but I am still a little uneasy about using 0W20. I am using M1 0W20 but I find myself tempted to switch to 0W30 or even 5W30.
    From what I have been able to learn the only reason manufacturers are using 0W20 is to get good numbers on the EPA fuel mileage tests. EPA regulations state that only the oil viscosity used in the mileage test shall be recommended for use in the vehicle.
    However there is a brief statement in the owners manual (page 560) which would seem to allow for higher viscosity oil.
    "An oil with a higher viscosity may be better suited if the vehicle is operated at high speeds, or under extreme load conditions."
    Unfortunately they don't give us clue what high speeds or extreme load conditions would be.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    0W-30 will do no harm except a bit worse gas mileage. There is no benefit to a 5W-30 over a 0W-30 as long as you are using a good quality synthetic.
    Based on lack of toasted Prius engines in the Southwest US, 0W-20 seems to be adequate, but if 0W-30 buys you some peace of mind, go for it.
    What viscosity does Toyota recommend for Australia and Southern Europe?
  18. tumbleweed
    4,067
    692
    Eastern Oregon
    Nice monkey.
    I guess I'll just stick with Mobil 1 0W20, both UOAs I have show no problems. As you said no toasted engines yet so it's probably is OK.
    I don't know what they use in Australia, 0W20 I think. We had one poster on here from Greece and he had trouble even finding 0W20 but I think he finally found an Amsoil distributor and was able to get it from him. Someone posted that in Germany they recommended 5W30, but that's unconfirmed.
    Windstrings who still posts here occasionally was using Amsoil 0W30 and changing at 25K mile intervals. I think that is still working OK for him.
  19. Mendel Leisk
    41,946
    I read somewhere 0W20 spec'd engines might also be using closer tolerances, and the thinner oil works better with tight clearances.
