Hybrid / Prius article in Electronic Design
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by baxsie, Nov 28, 2005.
  1. baxsie
    baxsie Member
    141
    Spokane, WA
    Success Story
    Setting The Standard For Hybrid Cars
    Synergy between gasoline-engine, electric-motor, and battery technologies vaults the Prius hybrid gasoline-electric vehicle to high fuel savings and low emissions.
    With its sports-car look, avionics-like dashboard display, and an eerily silent and smooth start, it's no wonder that the Toyota Prius hybrid gasoline electric vehicle is one of the fastest-selling cars of its type.
    You may have to click through one ad to see the article, but no registration should be required.
    ("web" version, have to click to see the images)
    http://www.elecdesign.com/Articles/Article...1347/11347.html
    ("print" version, images collected at the bottom of the article)
    http://www.elecdesign.com/Articles/Print.cfm?ArticleID=11347
    Sample image:
    [Broken External Image]:http://www.elecdesign.com/Files/29/11347/Figure_04.gif
  2. tideland_raj
    tideland_raj New Member
    108
    Sunnyvale, CA
    baxie,
    Thanx for the article, was nice. I learned a thing or two... that the Prius doesn't have!
    1) no starter (ie, as long as we have battery power, we can start the engine). This is good, since a good number of car malfunctions are bad starters.
    2) no transmission. I thought the Prius had a CVT... but apparently, it effectively has NO transmission, reducing power loss and... more importantly, again reducing the number of potential malfunctions (I remember being in a auto-tranny failure in the left lane on I-405 in LA at rush hour... man was that a nightmare)
    Both of these mean... less trips to your repair shop/dealer! It also looks like the added complexity of the hybrid electronics seem pretty solid so far, so a net improvement in maintenance rating/costs :)
  3. tideland_raj
    108
    Sunnyvale, CA
    Hate to reply to myself, but are there any other major changes to the Prius that we can think of that might reduce the maintenance/ownership costs? I'd love to compile a list of these to spout off to my buddies about why they should join our "church of Prius" :D
  4. KMO
    KMO Senior Member
    1,998
    722
    Finland
    2023 Prius Prime
    Regenerative braking - much less use of the brake pads.
    The computer control of the engine ensures less stress is put on it, particularly when cold (the engine usually idles until it's warmed up while the battery takes over most of the work).
  5. MtnTraveler
    MtnTraveler New Member
    29
    Everett WA
  6. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Don't forget less engine wear due to less ICE run time and the fact that it's spun up to 1000 RPM before it starts. Graham's site is cool and worth a read. I checked it out earlier today and really enjoyed the information I found there.
  7. Tideland Prius
    16,587
    3 litre thermos that stores hot coolant to allow faster heating of the engine, reducing fuel consumption
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    No clutch. No alternator. Only one drive belt for water pump.
    The conventional vehicle has additional belts for A/C, oil pump of power steering and maybe super charger.
    Ken@Japan
  9. Charles Edward Walter
    Think about high trade-in price and possible use as a replacement power supply when electric power fails (see www.priups.com).
  10. cdavid
    cdavid Member
    142
    North Carolina
    Graham's prius link seems to be dead. Anyone have an update?
  11. joelparks
    joelparks New Member
    82
    Bedford, MA
