Is coasting in neutral a problem?
Discussion in 'Gen 2 Prius Main Forum' started by aarons12, Apr 17, 2004.
  1. aarons12
    aarons12 New Member
    704
    long island, NY
    that's not just a prius issue. that went away a long time ago when they started to put safety brake interlock into the ignition system - i.e. you have to have your foot on the brake and be in park to start new cars...
    that was started back when people who couldn't handle high-revving audi's kept driving through the backs of their own garages (sorry, i still agree with audi that this was a driver error issue, not something wrong with the cars)
  2. randalla
    randalla Member
    370
    Lexington, SC
    There is always the possibility of someone or something crossing your path while you're coasting in neutral and suddenly don't have the time to remember to shift the car correctly back into drive at the same time when you have to mash the accelerator.
  3. rydot
    rydot New Member
    52
    Culver City, CA
    So that you can speed up to hit them??? ;)
    (j/k)
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    You can - foot off the brake, press the Power button twice to get to the IG-ON mode, from there you can drop it to neutral. No ICE operation, no Ready, just the ability to roll the car.
    Note - DO NOT TOW THE CAR THIS WAY. IF you do, serious powertrain damage could occur since any power generated isn't managed. Also if the wheels exceed a certain speed, MG1 could be overspun since the ICE can't start in this mode.
    hope this helps!
    -Rick
  5. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    It is "generally accepted" that it is unsafe to have the car moving and be in neutral (or leaving the clutch depressed longer than needed to shift in a manual car). While I can't totally explain why this would be unsafe, it is not recommended in every car owners manual or mileage improvement book I've ever read (e.g. How to get more miles per gallon)
  6. Ray Moore
    Ray Moore Active Member
    857
    52
    I have come to the conclusion for myself that it is perfectly safe to the 2004 hybrid system to coast in neutral although I no longer do it above about 42 mph. Much of my commute is on empty back roads where driving safety is not an issue. Since control of the power split device is by wire, I see no problem to the system by shifting back and forth between D and N. I welcome constructive discussion to the contrary.
    YMMV
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi Ray,
    The owner's manual in Towing section says...
    "Towing in this manner may be done only on hard-surfaced
    roads for a short distance and at low speeds."
    Japanese manual states the upper limit is 30km/h(18.75MPH).
    Also, please note that the transaxle Oil Pump is driven by ICE, therefore
    there maybe lack of lubrication in neutral.
    CORRECTION: I think I was wrong about the lack of lubrication in neutral.
    I think driving in neutral is not recommended.
    Regards,
    Ken@Japan
  8. Ray Moore
    857
    52
    Thanks Ken,
    I always injoy reading your posts. What do you see as the difference between coasting deadband in N or deadband with careful pedal control. Are both conditions controlled by the ECU based on inputs by the driver. How is the transaxle lubricated when Ice is off. When coasting in N, the ice will still run when required by engine temp. It doesn't seem as if N is different from feathering as far as the car is concerned but I'm still far from full comprehension of this wonderful system. Thanks for your time.
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi Ray,
    Sorry, but I've never tried to coast in neutral because I believe it is not designed for that.
    The transaxle contains 3.8 liter of oil and the minimum lubrication is done without the oil pump. I think I should correct my previous post describing the lubrication is maybe a problem.
    Anyway, I was told cornering in neutral is unstable than some power on wheels many years ago. I believe you won't do such risky cornering, however I still think driving in neutral is not recommended.
    Regards,
    Ken@Japan
    PS. It looks QUOTE TAG is not working. Any suggestions?
  10. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Ken -
    It looks like you have "Disable BBCode" marked in your profile, so it is by default disabling the BBCode. I went into your post and unchecked the box for BBCode, but you need to go into your profile and change that setting for the BBCode to always work by default.
    Danny
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Ken,
    You must uncheck "Disable BBCode in this post" You may have inadvertently set your default to Disable BBCode in your user profile.
  12. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Danny, also Evan,
    Thank you for your suggestions.
    Hope this post is OK using the QUOTE TAG.
    Ken@Japan
  13. Frank Hudon
    Frank Hudon Senior Member
    4,147
    in the Prius the PSD (CVT) is essentially a standard tranny with 3 moving gears that are constantly meshed. The sequence is all stopped, 2 moving and 1 stopped or all 3 moving. If the car is moving and you put it in neutral all it does is take the computer out of the circuit. As stated it's not a good idea to do that as it's possible to overspeed the main drive motor. This is a good url of a simulation of the Prius CVT
    http://homepage.mac.com/inachan/prius/planet_e.html
  14. Ray Moore
    857
    52
    The way I understand it, the motor would not be overspun. The generator is the part that is more vulnerable to that. Why do you think that the computer would no longer function as a part of the system while in neutral? I believe the computer is what is functioning to achieve neutral. Other than the towing warning,I see no warning from Toyota against coasting in neutral. It is likely that that warning refers to a condition in which the ECU is off. In that case, I believe the danger of towing above 42 or 71 depending on who you ask, would be inadvisable. I also think that there are factors that we are not yet considering. I wish the Toyota engineers could weigh in on this question, as it seems that currently, there are a lot of highly intelligent people who are just guessing, as am I. As far as that goes, the EV mod that some and perhaps I are doing, is as great a risk. Even though they have an EV button in Japan, doesn't mean that the system shipped to the US is programmed to safely allow it to be modded here. It probably is, but a risk nonetheless, until the Toyota engineer says,"Oh yeah, no problem" I have always suspected that Toyota left that button off the US model so that we couldn't use it to keep the engine off when it needs to run to keep emissions low. Since this could cause higher emissions under some circumstances, The button might have been left off in order to always meet california emissions standards. If you respond to the EV issue, let's split the thread, as I'd like to keep this one on the topic of neutral. Above, I mentioned 42 or 71. The generator was upgraded with higher production standards to be able to spin safely at 10,000 rpm which calculates under the old system to allow 71 mph but I recall that Toyota said that 42 is still the number. That would indicate that there are other factors that I am not aware of. Where is an engineer when you need one? Thank you all for your patience with this discussion and your input. I know that alot of minds are made up about this, but I would love to see the discussion continue.
    regards,
  15. efusco
    19,891
    1,196
    Nixa, MO
    Good points Ray. I just don't have the technical knowledge to answer. If you really have a lot of patience you might comb through the threads on this topic at the 2G Yahoo group, and maybe even at the Prius Technical group where people smarter than I discussed this at length.
    RE: your spectualtion on the EV, we may need to split this to another thread, but I fail to follow your logic about how using the EV to keep the ICE off could result in higher emissions. In fact, Toyota advertises the EV as a way to keep emissions down on the Japanese web site.
    I can also tell you that the functionality of the US cars moded to have an EV button function exactly like the UK/EU and Japanese cars and there have been zero reported problems from anyone that I know of that has performed the mod. Caution and concern are appropriate, but, in this case seem unwarranted.
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    with regenerative braking and charging, why would anyone want to coast?
    after all, unless you coasting down a hill that isnt steep enough to maintain highway speed while in gear, is that your reason?
  17. Ray Moore
    857
    52
    OK I'm going to throw some numbers at this. These are just representative guesses and were not arrived at scientifically. If I'm driving on a flat road with no wind at 40 mph and put the car in neutral I can coast for half a mile and still be going 33 mph. If I start at 40 on the same road and just take my foot off the pedal, in a half mile I'm down to 15 mph due to regeneration. If I take the energy I regenerated and use it to increase the speed of my vehicle I will only get back up to 20 mph before it is exhausted. The difference in my final speed represents the inherent losses in the conversion process. The coast can be achieved with "no arrow" pedal feathering but is harder to achieve and takes more focus. I realize my example has a hole in it but for this discussion it was close enough. The losses are substantial and the Prius will coast a very long distance on flat roads or gradual downhills. Happy Coasting
    Ray
  18. Frank Hudon
    4,147
    some where I read that the reason they recommend you don't coast in neutral is that the generator output is uncontrolled by the computer/inverter and there is the possibility of over maximum voltage going to the main drive motor as you return the gear selector to D. I can't prove it but I still wouldn't recommend doing it.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    for anyonw who would like to void their warantee for savings amounting to fractions of a penny... i say be my guest...
  20. Ray Moore
    857
    52
    In case anyone is wondering about this topic and how it is playing out, I thought I would update it at this time. My 2004 Prius now has 20,000 miles on the odometer. I have been using the coasting in neutral method for the life of the vehicle. I use neutral to coast at speeds up to 52 mph on back roads with no traffic, which makes up a large part of my commute. I have found no discernable problem caused by using this method and have never found any reason not to employ this method except for well intentioned fellow Prius owners who don't think it sounds safe. The max speed that I would employ this method would be less than 40 mph in the earlier version of the Prius, due to its lower max RPM of it's generator. There are no guarantees in life but I feel pretty safe with this one. I will come back here and update if a problem develops or I put another 20k on without incident.
