Love the UV glass in Gen III !
Discussion in 'Gen 3 Prius Main Forum' started by wwbarr, Aug 27, 2009.
  1. wwbarr
    wwbarr Junior Member
    San Diego
    Has anyone noticed the level of solar heat reduction in the Gen III over the Gen II ('07) ?
    Our Gen III's seems to filter the heat of direct sun through the windshield and driver/passenger side windows much better than our Gen II model V. If this is the UV glass, we'll never buy another car without this type of glass and built-in sun protection !
    For the most part, what we noticed was independent of the affects of the A/C since much of it was the potential sun burn and skin temp on the tops of our thighs when the sun was beating straight down.
    We noticed a significant difference while driving through the 4-5 hour central valley I-5 stretch (in Calif. from SoCal to Bay Area) this year in the Gen III over last year in Gen II (and over 2 years of day to day in the Gen II in SoCal) during summer when outside temps were close to 95-100 degrees [F] on both trips. Most likely, it was probably a few degrees [F] hotter this year in the Gen III.
    For us at least, this was a very very pleasant surprise benefit amongst the bevy of minor refinements throughout the new Gen III. :cool:
  2. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    I've noticed this as well, and so has my husband. Very pleasant bonus from such a great car!!!
  3. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    I love this feature. I held off tinting my Prius wanting to see how well this worked. It works amazingly well, to the point that I am not going to bother tinting it. The heat reduction is the same as our other cars WITH tinting.
  4. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    FYI, here are the Gen III glass specs:
    10 people like this.
  5. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I think you will find that all glass blocks UV radiation. You can't get a sun tan through a glass window for example, but I believe IR passes through glass rather well or a "glass house" for plants wouldn't work. I think you may be noticing the reduction from IR (heat) from the factory tint.
  6. mccats
    mccats New Member
    44
    Midwest USA
    Neat. The glass specs are very interesting!
  7. Tideland Prius
    16,601
    Nice to see that the HSEA glass has been improved over the Gen II. Our Gen II also has better HSEA glass over our 02 Camry (which of course is much better than our 00 Corolla which had none of that technology). The heat reduction is noticeable.
  8. eddiehaskell
    eddiehaskell Member
    233
    51
    Charlotte NC
    I think the factory windows have just enough tinting...not too dark and not crystal clear.
  9. concertinajohnnyboy
    104
    Minneapolis
    I'd have to agree. And, this is why I don't feel a need to tint the windows in the GIII.
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's still light enough that people ask "Are you going to tint your windows?"
  11. grahamy
    grahamy New Member
    73
    Raleigh,nc
    I had the windows tinted and asked for 35% in the rear but after checking the existing tint, FormulaOne limited the tint to 45% to keep within NC law.
  12. pfreeus
    pfreeus New Member
    62
    CA, USA
    Based on RRxing's chart showing the windows have a solar heat reduction rate, would adding ceramic tint noticably improve the solar heat reduction further? I am thinking of getting ceramic but if there isn't going to be a benefit then I would just get regular tint and save money.
  13. grahamy
    grahamy New Member
    73
    Raleigh,nc
    2 people like this.
  14. pfreeus
    pfreeus New Member
    62
    CA, USA
    Thanks. Was thinking of using Llumar Stealth ATR 30. Has a 50 percent solar heat rejection. So using the hatch back window that already has a rejection of 51 percent, I'm thinking it would reject about 75%. Is my math flawed?
  15. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Same here. I would have preferred it a bit darker but its OK and I sure didn't want to have to take it off when inspection time rolls around.
  16. F512M
    F512M Member
    415
    Laguna
  17. amj12
    amj12 New Member
    So Cal
    Anyone know if it blocks UVA and UVB?
  18. thecardude
    thecardude The Car Dude
    Newark
    I noticed too...and it is VERY interesting!
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    kinda makes sense. I mean if you are going to present Prius, and even offer a Prius with a solar powered sunroof designed to keep it cooler, under the flag that Prius is designed to be energy efficient, then it just makes sense to use glass that aides in Prius cooling efficiency.
    Infact, perhaps Toyota needs to think about improving it even further AND using it as an advertising point.
    The thermal and heat blocking properties of the glass are for me more important than "water repellant" properties that Toyota has touted in the Prius.
  20. korkiley
    korkiley Junior Member
    korkiley
    But I've read recently that although it blocks UV A, it doesn't block UV B. I can't verify that though.
