This is PROGRESS (rear sway bar DIY)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by macmaster05, Oct 22, 2011.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Wow, what a day it was! As some of you know from this thread http://priuschat.com/forums/gen-ii-prius-modifications/53494-rear-sway-bar.html, this morning I tried to install a rear sway bar and practically gave up. Before I go any further, I’d like to personally thank NeoPrius, LIPriusFreak, Daves09Prius, F8L and wick1ert for their suggestions and kind thoughts this afternoon. The following is a 50/50 story and DIY explanation for installing a 24mm PROGRESS Rear Sway Bar for 03-08 Corolla (62.2150), that fits the Gen II Prius.
    The Story
    This morning, a neighbor (who actually owns THREE Priuses) saw me working in my garage and asked what I was doing. He explained that he had a friend with a breaker bar that might help do the job. At that point, I thought nothing of this, since I’d just broken my ratchet and was determined to go to a mechanic to install this bar for $40, which I now know is a great price. :)
    Late in the afternoon, my doorbell rung and to my surprise, there was my neighbor and his pal, Joel, (he must have been at least 70 years old) with the breaker bar. Though I tried to politely decline, they eventually goaded me to try it out and his friend even offered to help me (my prayer had been answered!). So we went out to the garage. Joel was incredibly nice and I’m so glad I didn’t decline his help because I learned he’d driven an hour to come here and visit his friend/my neighbor. He explained to me that he’d been a mechanic all his life and had all the tools in his car, so we got them out and got started. It was seriously shaping up to be my own lame version of “Gran Torino.”
    The Install
    Joel slid under my lifted car and used the breaker bar to loosen the top nut. It turns out I was sort of doing it wrong all along – First tip: you want to loosen the top nut, not the bottom which is actually the bolt head. Previous DIY explanations didn’t distinguish this. Anyways, Joel had that old-man power and loosened the left side with ease. He let me try the right side and yup, it was easy! Second tip: Use a breaker bar. Ratchets aren’t made for that kind of torque. That’s why mine broke. Lesson learned.
    I removed the stock sway bar just as Joel had to leave for dinner at my neighbor’s. At this point, I felt OK to do the rest myself. I put the PROGRESS bar in place and used a socket wrench to tighten the nut. It helped to hold, or at least watch bolt head (bottom part), to make sure it wasn't turning with the nut. Once both sides were tight, now they just needed to be adjusted with a torque wrench.
    The Corolla TRD rear sway bar instructions (posted somewhere on this forum) specifies a torque of 144 ft-lbs. Well, 144 ft-lbs is A LOT of torque and my skinny arms couldn’t tighten it that high, so I started low. 20 ft-lbs *click*, 50 ft-lbs *click* 80, etc etc…I eventually got it up to 120 ft-lbs and I couldn’t pull any harder. I just learned from NeoPrius that the factory specification for the Prius is actually 110 ft-lbs NOT 144. That means I am okay. YAY!!
    As far as the rubber stopper piece that goes between the sway bar and underbody, my dad shaved it with a rotary saw to get it to fit. We wedged it back in there even though it’s not sitting completely flush. It’s pretty tight in there, but there’s a chance it can pop out while I’m driving.
    I didn’t get to test the sway bar very much because I only drove my parents out to dinner afterwards. They don’t like it when I drive hard and fast, so I have yet to test the true difference it makes. For now, I can say that my head doesn’t tilt as much during turns.
    The End
    It practically took a village to install this thing (Joel, my neighbor, my dad, and me), but maybe it was for the best. Not only did I finish my project, but I also learned how valuable a community can be, whether online or in real life. You’re probably thinking why so dramatic? It’s just a sway bar! True, but know that I had taken today off of work to try to get things done, and I learned a whole lot more than I ever expected. This is PROGRESS.
    PS – now I have a Touring sway bar if anyone wants to buy it. I’ll make it extremely cheap, just send me your offer. It goes to the most attractive person. ;)
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Great story, bru. :)
    I 'mglad you got it installed and even more so that your neighbors got involed and you had fun.
  3. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Glad you got it done!!
    You really hit the nail on the head about the community thing. I feel like that sense or feeling has diminished some over the years. I still try my best to help out someone when I see they need it. Really, what's 5 minutes or so of my time if it helps someone in need? It's nice to see that sense of community there for you.
    The last couple years, me and the guy across the street have teamed up to deal with the snow. 2 winters ago, we had all those darn blizzards and record snowfalls. We always helped each other, then would move up and work on the neighbors. That was when I had an old school, 1980s Toro snowblower. Now I've got a nice, big 24" wide clearing, 20" deep snow thrower.
    2 people like this.
  4. macmaster05
    4,050
    730
    I was talking to my good friend yesterday before things started looking up... He said he knew exactly what I was talking about and going through - that if it hadn't been for his dad, who is mechanically inclined, he would've given up several times. He said that modifying suspension is tricky and that he and his dad used to do crazy MacGyver stuff to get things done, using any available tools and random crap. But ultimately he urged me to not give up even though I had.
    Now I know exactly what he was talking about. It turned out just like he said. Kinda cool...
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Matt,
    I hear you on the community kindness thing. Some neighborhoods are really united and others are not. When we moved into my new neighborhood I was confused as to how my lawn was being mowed while we made the transition from the old house to the new house. I later found out that one of my neighbors tends to mow both of his neighbors yards when after he finishes his own. Because each houses lawn is connected to one other neighbors lawn, it just makes sense to finish both lawns so they look uniform. So now when I do my own lawn I move to my nearest 3 neighbors and do theirs as well. Well, I did until we cut through my 100ft. extension cord and replaced it with a 50' cord. I need to buy a longer one so I don't feel like a chump. lol
    2 people like this.
  6. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Glad you got it on! Sounds like a nightmare, but you met some new friends, and are helping those on this website. Keep us posted as how the rear sway bar does, I'm interested in getting a progress rear sway bar myself, so any comments you have about it would be greatly appreciated!
    After I read your post, I was thinking, "breaker bar" Now why didn't I think of that!?
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    FWIW, 3/8" drive sockets are completely inappropriate for breaking loose or torquing large bolts. The maximum torque spec is 125 ft-lbs -- regardless of size. Compare that to 1/2" drive at 375 ft-lbs. Don't let the 3/8" drive Harbor Freight breaker bar fool you, as it will shear the square drive right off the minute you try to break loose a large bolt or lug nut.
  8. macmaster05
    4,050
    730
    Yeah, this is what Joel said too.
    I'm doing that in this thread http://priuschat.com/forums/gen-ii-prius-modifications/53494-rear-sway-bar.html. I think it's a more comprehensive and valuable resource for people who want every ounce of information about RSBs.
  9. NeoPrius
    NeoPrius Member
    182
    33
    Maryland USA
    Also don't forget to use a six point (rather than 12 point) socket. You can tell a six point socket by looking in the end of the socket - it should be shaped like a hexagon. They are much stronger.
  10. a_gray_prius
    2,927
    783
    IL
    Dude, did you WD40 or PBblaster the nut before taking it off? Helps a lot.
    Sezy likes this.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    I called about my bar today and the guy said they are back in stock now and mine will ship today or tomorrow. Either he is lying or Mac stole my bar by virtue of calling in his order vs. online.
    *shakes a fist at Mac*
  12. macmaster05
    4,050
    730
    Lol I think I owe you a better explanation, Justin. I called THM the day after I placed my order because I found on another website (forget the name already) the same bar for $95. I remember THM had a price match guarantee so I wanted to see if they could price match.
    The guy from customer service explained though that it probably wasn't a legit website and after looking at it more, I think he was right. He also said that $95 was ridiculously cheap and that they'd lose money if they sold it at that price. Finally he said he said he could ship it "today" since they had 6 in stock, if I kept my order with them. So I essentially said fine, forget the price match. It took 2 days before I got a shipping number from "Igor" in my inbox.
    I'm not sure where the mix-up could've occured other than them being lazy and not taking a careful look at every incoming order. Though I had a good experience over the phone, it's somewhat disappointing because even McDonalds can do a better job than that. Did you ever order the exact same meal as the guy in front of or behind you, but they still got both your orders?
    Anyways, you shouldn't have a problem now. And if something else happens, we got your back over here.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    No worries, brother. I was just giving you a hard time. I just want to get this bar on before the rains come so I can test it thoroughly. Then I will install the front bar. I want to test it after putting on the rear bar so I can better describe the changes to others whole are interested in this mod. I'm lying here sick from chemo so it's not like I could have installed it this weekend anyway. It better be here by next weekend though! *shakes his fist in the air*
  14. macmaster05
    4,050
    730
    Couple more things I noticed on my morning commute;
    The car feels normal now, closer to my old '89 Acura Legend, which might be underwhelming if anyone was expecting mini cooper/BMW/GTI-style handling. IOW, it doesn't feel like a performance car but it also doesn't feel like a Prius. The car also feels more steady at highway speeds. I used to grip the steering wheel really tight but noticed I was a lot more relaxed and loose today.
    So in summary, very very subtle improvement that's well worth $100. It won't make your spine tingle but it feels better than the sway-boat the Prius normally is, which I can't even imagine going back to now.
  15. NeoPrius
    NeoPrius Member
    182
    33
    Maryland USA
    Subtle? For my unmodified base model, it's more like dramatic than subtle. The car is actually enjoyable to drive now - very solid on turns and curves. Definitely well worth the hundred bucks - probably the best $100.00 I've spent lately. :D
    Daves09prius likes this.
  16. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Wouldn't you have two 50' cords? I don't see a problem here. ;)
    I agree, good neighbours can be a wonderful thing. :)
  17. wick1ert
    1,311
    183
    Delawhere
    Or at least 2 cords that combined would probably be just over 99' (unless they really chopped it up good). Couple that with his new 50' cord and the next neighbor could get done :)
  18. Sezy
    Sezy Active Member
    442
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Where can I find this sway bar ?.... Searched "Prius rear sway","Prius progress"and all sorts of variations. no luck
  19. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    THMotorsports.
  20. Daves09prius
    680
    161
    Gettysburg, PA
    Sezy likes this.
