How to make a backup Copy of Original Nav DVD
Discussion in 'Gen 2 Prius Audio and Electronics' started by homenet, Oct 25, 2011.
  1. homenet
    homenet New Member
    ca
    Hello!
    I have a 2005 Prius and the original NAV DVD in the nav. system.
    I want to make a backup copy of this DVD for safe keeping.
    I have DVD DL recorder and DVD+R DL blansk.
    Can I use Nero 7 and use Copy DVD feature?
    Thanks.
  2. scythefwd
    scythefwd Junior Member
    VA
    Create an image from the disk... that way you can burn it anytime you want. Barring any trickery on the DVD manufacturer (like dropping a fully blank track in the middle of the disk with a track redirect at the end of the track prior), nero will copy it fine... I've only had 1 DVD, and it was a software DVD that had that blank ring right through the middle of it... nero, roxio, k3b, brasero.... none could copy it.
  3. homenet
    homenet New Member
    ca
    I am using Imgburn and created the inage of my original nav disk.
    Now when I try to make the disk, Imgburn says shows the follwing error:
    E 15:35:08 Optimal layer break position must be a multiple of 16.
    E 15:35:08 Optimal L0 Sectors: 1,986,340
    E 15:35:08 Next Largest Acceptable Value: 1,986,352
    E 15:35:29 Operation Failed! - Duration: 00:00:21
    on the left window of Imgburn for source it syas
    Sectors: 3,972,560 ( Mode1/2048) (LB: 1,986,340)
    How to change the sectors as complained by the Imgburn above.
    My drive is: HL-DT-ST DVDRAM GSA-H40N RG01 (ATA)
    Current Profile: DVD+R DL
    It is an LG drive. I also tried to chagne using the book but it give me errors.
    Thanks.
  4. scythefwd
    VA
    try using something a bit more known.. like nero (the trial is free), roxio ex cd creator, etc.
    When you create the image, any errors? It could be using a truly blank track like I mentioned in my original post.
  5. homenet
    homenet New Member
    ca
    Thanks for the input.
    I finally got it working.
    What I did was first copied all the contents of the original dvd into a directory and then used Imgburn to recreate the image. The burned that image and it worked.
  6. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    That's great. I could never get the copy to work like the original in my 2006 prius.
  7. mycotopian
    mycotopian New Member
    does the brand of media matter when burning?
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
