iPhone 4 iOS 5
Discussion in 'Prius v Audio and Electronics' started by tnsprius, Oct 26, 2011.
  1. tnsprius
    tnsprius Junior Member
    Portland Or
    Has anyone succeed in pairing the iPhone with the car. Bluetooth pairing always fails.
    Pruis 2012 V Model V with entune
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    In all of 20 seconds, no problem, but then there are already 2 possibly 3 threads on the 4s subject!
  3. Tideland Prius
    16,159
    No problem here. It's paired for phone and audio.
  4. tnsprius
    Portland Or
    I pickup my V on Monday. I am a tech person and this entune has a big learning curve
  5. pvogel
    pvogel '05 Five & '12 v
    87
    25
    Santa Clara, CA
    No problem here, my iPhone 4S paired perfectly with my v Five w/AT yesterday. I did run into an odd issue this morning showing the car off to a friend, it wasn't able to connect to the iPhone as an iPod via the USB cable. I know it pairs with whatever is there "first" (bluetooth or USB) but it was a little odd.
    Entune, what learning curve? Pretty straight-forward.
    Peter+
  6. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    I've had no problems pairing my iPhone 4 w/iOS 5 to my 3rd gen Prius! Worked seamlessly the first time.
  7. Tideland Prius
    16,159
    Ohh... then you might want to fix your profile. We've just added "2012 Prius v wagon" to the "My Car" list. Then choose whatever model you have (Two, Three or Five) and the package if any!
  8. pvogel
    87
    25
    Santa Clara, CA
    I figured out my odd issue -- still don't quite understand it. But if you have a DVD in the disc drive, it won't connect the iphone/ipod via cable, you get "unable to authorize iPod" displayed VERY briefly on the screen. Removing the DVD eliminates the problem. Posting here in case others run into the same problem in coming weeks.
    Peter+
  9. tnsprius
    Portland Or
    The learning curve is on the backend trying to learn all the nifty features and options. The front end is super easy and great. I did not get the advance tech package. I wonder why it works with the advance and not the standard. One iPhone we have the car can see it but fails and the other never shows up. Did you pair it from the iPhone to Car or Car to iPhone?
  10. pvogel
    87
    25
    Santa Clara, CA
    Pairing:
    1. Go to the phone setup screen so that the car becomes discoverable
    2. On the phone, go to Settings>General>Bluetooth, make sure BT is turned on, your phone is now discoverable as well
    3. The two will find each other, the car will generate and deliver a security key to the phone where you will be asked to confirm it with the number displayed on the car screen
    4. The phone is now paired and contacts will transfer to the car's phone book in a few seconds.
    Note that if you want to use the iphone as a bluetooth audio device as well, you'll need to pair it in the bluetooth setup screen as well. (And vice-versa). Older iphones/iOSes support fewer bluetooth profiles and may not support all the features of the v's bluetooth.
    Peter+
  11. tnsprius
    Portland Or
    I do not have a phone setup screen. According to the manual I hold a key on the wheel which brings up the Bluetooth setup button then when clicked brings up the bluetooth screen of options. The car when it searches it tries, it gives failed message. When the iPhone searches it fails with an unavailable error.
  12. pvogel
    87
    25
    Santa Clara, CA
    When the car searches:
    1. Is your phone's bluetooth screen (Settings>General>Bluetooth) displayed?
    2. Is bluetooth ON?
    3. Where (physically) is your phone at the time?
    Peter+
  13. tnsprius
    Portland Or
    1. Yes. I even cleared all running task including prefs app
    2. Yes
    3. Siting in drivers seat. I have held it under radio, steering wheel and on top of the cup holder.
  14. MBRGuru
    MBRGuru Member
    255
    26
    Try this:
    1. Go to Settings > General > Bluetooth on your iPhone. Make sure Bluetooth is on.
    2. One the Navi, press the Setup button.
    3. Press Bluetooth from the list of options.
    4. Press the Make This System Discoverable button on the screen.
    5. You'll see the car show up on your phone. Select it and accept the connection.
    6. Press Accept on the Navi screen.
  15. tnsprius
    Portland Or
    My car never shows up on iPhone
  16. MBRGuru
    MBRGuru Member
    255
    26
    PM sent. Some pictures, etc. would probably help find what's going on.
  17. tnsprius
    Portland Or
    Fixed!
    My house gets one bar of CDMA (Verizon) and no GSM service. While I was out today I decided to trying pairing again and it worked! You need cell service to pair the bluetooth. Thanks for all the help everyone.
  18. frocine
    frocine New Member
    Indiana
    We just got our Prius V (w/o Navigation) yesterday (we are first-time Prius owners)... in any case, my husband's iPhone 4 OS 5.0 paired magically with the Prius. However, my iPhone 4 OS 5.0 refuses to connect. It keeps saying it's successful, but then it keeps disconnecting & then trying to reconnect. But, every time it tries to reconnect, the display on the Prius restarts, goes out, restarts, etc.
    Has this happened to anyone? I assume this is an iPhone issue since my husband's phone works fine.
    Any thoughts?
  19. tnsprius
    Portland Or
    Yes there is some glitches with entune and ios5. It worked great yesterday and today it would not reconnect or pair.
  20. MBRGuru
    MBRGuru Member
    255
    26
    Have you tried to reset your phone, then attempt to pair it again? Perhaps the phone is in a bad state.
    What do you mean by "the display on the Prius restarts, goes out, restarts, etc."?
