Passenger Seat Breaking Apart
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by volvoswede, Oct 26, 2011.
  1. volvoswede
    volvoswede Junior Member
    26
    idaho
    wondering if anybody has this problem of foam coming out of seat due to a plastic rib coming loose (hard to describe:)). Passenger seat, just light, normal use and only 12,800 miles on 2010. Should dealer honor warranty?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If it's obvious the stitching is coming out and that's causing it or if you're trying to describe that the hard plastic on the side of the seat has worn into the seat causing the problem then sure they should cover it.
    If it looks like something you were wearing may have pierced the seat and caused a hole or rippage which is leading to the problem, I doubt they'd cover it.
  3. RRxing
    RRxing Senior Member
    2,548
    1,825
    NEPA
    I had this happen on the front underside of the driver's seat. They replaced the seat foam and leather under warranty. I still check it now and then to see if the plastic strip is coming loose but it seems to be working fine. See the dealer to see if they can re-seat the plastic strip (mine couldn't). They ordered the parts on my next visit for an oil change. Good luck.
    By the way, if your issue is the same as mine, then your thread title seems a little alarmist.
  4. volvoswede
    26
    idaho
    Thanks, my description is bad, it looks like a plastic rib keeps the fabric "tucked in" and that's come loose or broke, allowing the foam to start comingl out. The seat is not pierced in any way. It's where the leather meets the plastic rib. I was just wondering if anybody else had a seat like this deteriorate?
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Is the plastic rib the one under the front part of the seat that keeps the seat ("leather") pulled down and should be attached to a metal lip? My plastic strip is coming off the metal lip. I was trying to reattach it the other day without success.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Got to be covered.
  7. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    Can you take a photo of it with your camera?
  8. JJ742
    JJ742 Junior Member
    29
    Maryland
    I have the same problem on my driver's seat. I can re-attach it but it just comes back off within a few days. I'm taking it in for service later this month so hopefully they will resolve it.
