2009 only 260 miles per tank!?!?!?!
Discussion in 'Gen 2 Prius Fuel Economy' started by srw1969, Oct 27, 2011.
  1. srw1969
    srw1969 New Member
    Chicago
    I have been a happy 2009 Prius owner for 2 weeks now but am a bit concerned with the fuel capacity I have been experiencing.
    The first tank I went to fill-up when there were three blips left on the fuel guage and the tank only took 5.7 gallons. I wrote this off as I did not know how much gas was in the tank when purchased (the guage was on full). The mileage was around 250 miles.
    Today I had to stop again for gas. There were 3 blips left on the guage and the tank again only took 5.4 gallons. I am not concerned about the MPG, but with the tank only taking around 5 gallons.
    Could there still be that much gas left in the tank with only 3 blips left on the guage?
    I have read many posts about the bladder tank and not being able to fill to the 11.9 gallon capacity, but I expected to get close to 400-450 miles per tank.
    Should I be concerned with this?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    What happens if you run it down to 2 or 1 pip? I almost never fill when down to 3. (Get gas immediately if you hit 1 pip.)
    I've never put in more than 9.975 gallons in my Prius that I've had since January 06. I think I was down to 1 pip, but don't recall if it was flashing.
    The inclinometer might be out of calibration, but I'd suggest not mucking w/that, for now.
  3. Tideland Prius
    16,554
    The only time I can get 500 miles to a tank on a 2nd Gen is if I run it down to 1 pip (after 1 pip, it will blink. That's the equivalent of a low fuel light). If I take it down to the blinking light and drove around for a while, then yeah it'll be closer to 900km (~560 miles).
    At 3 pips, you may be able to squeeze closer to 300 miles during the summer. It sounds about right if your mpg is below 50mpg (around the high 40s). Just a heads-up, it will get worse during the winter.
    The gas gauge is also not linear. I found that it drops slower in the first half and faster in the second half so half tank isn't necessarily 5 pips.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    YUP normal. My 2010 gets 400+ miles to a tank. My wife's 2008 gets between 250 and 350 max.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    It all depends on your mpg and how low you want to run the tank down. At 45mpg you could run it down to 3 pips and still go another 150 miles or more before the low fuel light comes on. IE you can get 350 miles on a tank at 45mpg or so. I used to always fill up at 2 PIPs which gave me about 350 miles on that tank. This summer I put my 15" tires back on and practiced mild hypermiling at was getting over 500 miles to a tank at 55mpg-57mpg. I could get 9.5-10 gallons in the tank if I ran with the low fuel light blinking for awhile. I don't recommend that though.
    Moral of the story? Drive more efficiently and wait until you get down to one or two PIPs before hitting a gas station. 350-400 mile tanks will become normal.
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I'm so glad the Gen IIIs don't use bladder. I've driven 50-70 miles on blinking pip all the time before filling up. 600 miles to the tank and 10.5-11.5 gals on the fill up.
  7. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Agreed. It depends a lot on how efficiently one drives.
    Looking at my records, when I was living in WA and had very short drives, coupled w/very cold weather in some months, I'd be lucky to get >41 mpg on a "tank" and my "tank" be good for 250-330 or so miles, depending on my FE and how low I ran it (usually down to 2 or 3 pips).
  8. srw1969
    srw1969 New Member
    Chicago
    Thanks for the responses guys! I'll continue to montior and let the tank run down to 1 or 2 pips.
  9. sidecar
    sidecar Member
    342
    45
    Australia
    my 2008 is on 2 pips left on its first tank and Ive 800km on it at 4.1 lt/100km
    57.37 US mpg
    Ive only had the car a fortnight and have no idea what Im doing !
  10. cwerdna
    12,544
    2,124
    SF Bay Area, CA
  11. sidecar
    sidecar Member
    342
    45
    Australia
    Im told its a solid fuel tank,
    the Australia specific manual says its 45 ltr
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah there's no bladder in your tank so it's pretty safe to drive it until the last pip blinks. Mine is very repeatable, I usually go somewhere about 950 to 980 km per tank. My all time record is 1042 km.
  13. sidecar
    sidecar Member
    342
    45
    Australia
    I chickened out at 852 when I noticed only the last pip was alight.
  14. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    at 60 MPG or thereabouts my Gen II gets about 350 to 400 miles on a tank when I fill up at 2 pips.
    I wouldn't worry about running it down to one pip, no need to push it and deal with bladder inaccuracy. Just fill it up at 2. I don't even pay attention to how much gas goes in, I just watch my MPG and refill the tank as needed.
    If you are worried about range put more air in your tires. See this info from another PC member
    I try to air up as close to 70 degrees as I can after the car has been sitting several hours and let the PSI float higher/lower as outside temps dictate.
    The PSI I choose from is:
    50/47 high (short trips or warm winters)
    48/45 med (long trips or summer use)
    45/42 low (winter below freezing)
    But I have 51 PSI sidewall max tires. If I had 44 PSI I'd probably make that
    45/42 high
    42/40 med
    40/38 low
  15. Tideland Prius
    16,554
    Umm, I believe it's still 45 litres regardless of where you are. The ability to pump 60 litres if I recall was if you tilted the car towards the passenger-front side and fill to the brim.
    Mate, as long as the last pip isn't blinking, you're good. The blinking pip is the equivalent of the low fuel light and with Toyotas, that's typically 10 litres to go. At 4.1L/100km, you can easily go another 100km with 5 litres to spare (being pessimisstic with 5L/100km obviously).
  16. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Interesting... I wonder if ken1784 was in error then about the JDM Gen 2.
    Ahh yes, regarding the tilting, you're probably referring to the special fueling technique at (from http://priuschat.com/forums/prius-h...lenge-japanese-hybrid-drivers.html#post868854). :)
    But it's a Gen 3 in the pic...
  17. Tideland Prius
    16,554
    I don't know. I remember that discussion on PC but the specs say 45 litres unless they modified the tank. I will say that 15 litres is a lot of extra fuel in the pipes!
  18. sidecar
    sidecar Member
    342
    45
    Australia
    ah excellent, thanks ...
    so much to learn with this car
