2004 MFD year replacements. What year can I use?
Discussion in 'Gen 2 Prius Main Forum' started by MisterMan, Oct 31, 2011.
  1. MisterMan
    MisterMan New Member
    So Cal
    I have a 2004 Prius and I'm looking at replacing the MFD unit. Do I have to use a 2004 or can I get a newer model like a 2009? I don't have NAV or anything upgraded or hooked up to this MFD. I am going to try the re-sodering that I have read about in these posts but if all else fails, I will need a backup plan.
  2. hill
    8,732
    You're good to use between 2004 - 2006 .... after 2006, you're going to be disappointed when it comes to receiving 100% compatability.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I don't think you can use the 06. That was the year that the MFD changed to a higher resolution. You want an 04 or 05.
  4. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
