Why would Toyota elect to use "w" rated tires?
Discussion in 'Prius v Technical Discussion' started by Hurricane Gio, Nov 8, 2011.
  1. Hurricane Gio
    Hurricane Gio New Member
    Miami
    My wife's Prius V 5 came with 17" wheels, which look great. Now, I am fine with the low-profile 5o Series tires. By why the W rated tires? These are harder and rated higher than Z rated ones.
    H or even V rated tires are more than adequate on a Prius. ;)
  2. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I buy H- rated tires for all my cars. They are stronger than S or T ones and are still reasonably priced. Higher rated tires are wasteful on a Prius (max speed 104 MPH).
    JeffD
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Are they 'run flat' tires?
  4. Hurricane Gio
    Miami
    Nope
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Is there a load rating difference between the V and W tires? Is there even a lower rated version? available?
  6. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    OEM tires are usually of poor quality - it's not just Toyota by any means. I can only assume they're chosen for mileage ratings and cost. An extra few hundred dollars of profit on each car would really add up.
  7. Hurricane Gio
    Miami
    No idea. But i assume the 17" 50 series would be lower than the 16" 60 series tires.
  8. Hurricane Gio
    Miami
    My 93 Honda Civic Si came with nice OEM tires, as did my 2000 Jeep Cherokee ann my 2004 Ford Explorer. All came with TOL tires, IMO.
    Now my 2011 Subaru Outback, comes with ok OE Continental tires.
    The Toyos on the Prius v 5 look nice and so far feel great. Toyo makes some nice tires.
    My point is why put High Performance Street tires on a Hybrid wagon?
    Same with my neighbors, Mazda 5. Falken HP Z rates low profile tires.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    There are not a lot of cheap LRR 17" tires out there so maybe these were as close as you could get to LRR while still being cheap. I would think that price negotiations between the two manufacturers also played a large role in the decision.
  10. qbee42
    3,079
    With the Gen II Prius, Toyota specified higher rated tires because of the weight of the front end. Perhaps they did the same with the newer Prius.
  11. Hurricane Gio
    Miami
    I guess thee are super cheap tires. But I found plenty of reasonably priced tires by Michelin, Goodyear, BF Goodrich, Kumo, Cont, Pirelli, Yokohama, Dunlop and Bridgestone in a V rated tire. Even a few H rated form Michelin!
    Hopefully we can get 20K out f these OEM tires.
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The primary market for those sized tires isn't low performance cars.
    Higher speed rated tires usually give better handling and some people get the 17 inch option for the better handling.
  13. Hurricane Gio
    Miami
    Speed rating are about maximum speed compared the the vehicles load.
    Speed rating
    The speed symbol is made up of a single letter or an A with one number. It indicates the maximum speed at which the tire can carry a load corresponding to its Load Index
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    I think a lot of people will switch out the worn oem tires for the Primacy MXM4 once they read the reviews.
    There are a lot of tire options out there. Some are cheap, some perform well, some are very efficient and some have great longevity. You usually only get to choose 3 of those 4 characteristics. :)
  15. Hurricane Gio
    Miami
    Not a normal driving speeds. No really. I have had HR rated tires handle better than Z-Rated tires when I had my Rice Burner Honda Civic Si back in the day. that's not true. its about top speed!
    So why would toyota design a car to use 15-16" wheels, then be forced at the FACTORY to put HP/LP tires to get 17" to work? Design the car with the max wheel sized desired form the factory, add use the appropriate tires. No if some looking for AFTERMARKET wheels, then they can cram 18' or 19" wheels if they want.
    Look at the Venza. Stock 20" wheels and they are NOT HP/LP tires on any model. IMO, Toyota messed up here with factory 17" wheels with a W speed rating. Toyo could make the same OE tire for Toyota cheaper and a more appropriate speed rating.
  16. Hurricane Gio
    Miami
    that's the tire I am thinking of. I love Michelin tires and prefer them over any other one. Can't wait to ditch the Conti tires on my 11 Outback.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    They come in both V and W ratings. :) I got the V, obviously.
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Most 20 inch wheels are sold for the bling factor.
  19. Hurricane Gio
    Miami
    Sure. But I am taking about OEM, not AM. Look at the Venza the the Infinity F series SUV.
    20" regular profile tires.
  20. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You didn't know Prius v can hit 149 mph? j/k
