Lack of DRL and auto headlight options in Prius v Three
Discussion in 'Prius v Accessories and Modifications' started by wizzard, Nov 14, 2011.
  1. wizzard
    wizzard New Member
    CA
    Just bought a v Three last week and I am so far very satisfied with it. This is the first Prius that We've owned. I was very surprised however that the v Three didn't have DRL or the auto headlight options which are standard in my 2000 Toyota Sienna LE. I consider DRL to be essential for safety reasons and the "auto" headlights are just convenient. Apparently these options are available only with the v Five. I wonder if these features are so expensive so as to have them only in the top model? Does anyone lese find the lack of these features to be an issue?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Try this:
    Start your v to Ready
    Turn on your headlights
    Power off your v
    open either front door
    30 seconds later your headlights should turn off
    Now just never mess with the headlights again.
    (The dealer can change 30 seconds to 0, 60, or 90 seconds)
    http://www.toyota.com/t3Portal/document/om/OM47674U/pdf/sec_06-02.pdf
    page 3 of the PDF, page 525 of the paper manual
    waldox, tdavisjr and wizzard like this.
  3. wizzard
    wizzard New Member
    CA
    Thanks for the tip. I will try it out an post the result.
    Received a bunch of manuals with the V. Still going through them.
  4. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    I too was very surpised there was no AUTO setting for the headlights. But Jimbo, according to your suggestion, wouldn't that mean your headlights are on all the time?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    No, Just when you are in Ready mode, and for 30 second after you leave your car. Not when it is off, except for that same 30 seconds.
  6. wizzard
    wizzard New Member
    CA
    Thank you JimboPalmer, it does work!
    I see that the times are customizable but couldn't find the instructions for customizing them in my V three. Can this be customized only by the dealership?Or is customization available only in the V five?
  7. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    What I meant my "on all the time" was when up and running in Ready mode. So even if it's a bright sunshiny day, your headlights will still be on?
  8. Tideland Prius
    16,623
    Correct. You'll be driving with your low beams & taillights on all the time.
    Dealer customisable. The Five just allows the owner to do it in the car rather than take it to a dealer.
    Even on the 2012 Prius, Toyota kept the automatic headlight option to the Four and Five trim levels. I don't know why it's supposedly a luxury feature (Toyota Canada does the same with illuminated vanity mirrors. It doesn't matter if you bought the base 4Runner or Sequoia, you're not getting illuminated vanity mirrors unless you buy the Limited trim level of the respective models)
  9. Wuster
    Wuster New Member
    17
    VA
    You can do it in the three.
    Once the car is on-
    -Push the setting button on the right of the touch screen
    -When the menu screen comes up, pick vehicle
    -When the vehicle settings screen comes up, scroll down one page and you'll see auto head light off setting.
    I found it on my three while pushing buttons to see what customization that I can do. :)
    JimboPalmer, anewhouse and wizzard like this.
  10. wizzard
    wizzard New Member
    CA
    I will try this and post the results. thanks for the suggestion.
    Edit: Tried Wuster's instructions an they worked. Thanks!
  11. cmjars
    cmjars New Member
    Los Angeles
    I have a Prius V model 5 and it does not have DRL. I called the dealership and they said for 2012 none of the Prius' will have DRL's.
  12. 2sk21
    2sk21 Member
    138
    22
    Teaneck, NJ
    I am a little surprised that they omitted the DRL from the Prius v. I have always been in favor of them. I am training myself to turn on my headlights whenever I start the car.
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    2sk21 you never need to turn them off, so you never* need to turn them on again.
    *I find I have to turn on the headlights again after every oil change, some folk just HAVE to turn off the headlights.
    :rolleyes:
  14. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    I don't find this to be a viable solution since all the interior console lights dim when the headlights are on, making the instrument cluster and audio screen harder to see in daylight.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  16. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    My Prius v 5 with ATP has an auto setting for the headlights that (if equipped, and I now know that mine is not equipped with DRL) performs the following function; "The headlights, parking lights, daytime running lights and so on turn on and off automatically (when the “POWER†switch is in ON mode). - from manual http://www.toyota.com/t3Portal/docum.../sec_02-03.pdf
    I thought I saw my prius v headlights were on during the day Prius v 5, but I was wrong. I must have been in the garage or just seeing what I want so see. The AUTO headlight setting just uses sensor to turn on lights when it gets dark outside. Copied from specification documents http://priuschat.com/forums/prius-v-main-forum/98162-2012-prius-v-press-release-materials.html
    Prius v Five adds –
    - LED headlamps with auto level control, auto-on/off feature and headlamp cleaners
  17. cmjars
    cmjars New Member
    Los Angeles
    Chazz8 Thank you I will look at it again today. Do you have any thoughts on my my XM Fuel button isn't working?
  18. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Toyota Prius+ 7-seater In Detail 2012 Commercial - Carjam Radio 2011
    This video shows the Euro version: Prius+ with DRL. I don't think even the Prius v Five has DRL.
  19. wizzard
    wizzard New Member
    CA
    I didn't know that the v5 had auto wipers. That is neat!
  20. Tideland Prius
    16,623
    It doesn't. European models have rain-sensing wipers.
