Pictures of Body Side Moldings
Discussion in 'Prius v Accessories and Modifications' started by M8s, Nov 18, 2011.
  1. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    I installed body side moldings (bought from the PCShop) yesterday. Here is a picture of the result.
  2. M8s
    614
    113
    33
    Here's a picture from a different angle.
  3. registered
    registered New Member
    Vancouver, Canada
    That looks pretty good, but I don't understand the point of the moldings. I understand that you get dings in the moldings instead of in your door, hopefully. But you still have dings, and you can't just remove the moldings because the paint on all four doors will have faded differently where the moldings are. So don't you land up having to replace the moldings over and over again? Is that really much better than having to repair a door from time to time?
  4. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    The molding can absorb blows better than sheet metal. The molding will spring back, where the sheet metal will dent.
  5. M8s
    614
    113
    33
    Exactly, well said. Also, I think they dress up the plain-looking slab-sided doors a bit. It's my understanding that the moldings can be removed with a heat gun and a little rubbing alcohol but I've never had any need to remove them on my 2009s.
  6. eroeder
    eroeder Junior Member
    72
    22
    Dallas
    2018 Prius Prime
    As with other things like a rear bummer protector, it should be standard...
  7. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Agreed and fading shouldn't be an issue either.
    Mine has the chrome trim insert:
  8. dalspot
    dalspot One foot off the grid
    39
    Delaware
    I like the looks of them. Tho on my last car, they didn't help with a very bad dent that someone put in my door when they opened their car door, it landed about an inch below the door molding!
  9. Rh0
    Rh0 Junior Lurker
    33
    N. CA
    Does the molding sold in the PC shop have the chrome insert? If not, where did you get those from?
  10. tanasit
    tanasit Member
    399
    60
    Philadelphia
  11. BTBAM
    BTBAM Beatmaster
    Cincinnati, Ohio
    What source did you get the molding with the chrome? I found one site but didn't know if it worked for the priusv or not. (listed for '10-'11 prius')
  12. M8s
    614
    113
    33
    I'd check before putting BSMs for a liftback Prius on to a Prius v. The Prius v's doors are quite a bit longer than a standard Prius liftback's doors.
    I don't know the source for BSM with chrome.
  13. BTBAM
    BTBAM Beatmaster
    Cincinnati, Ohio
    Exactly. I won't buy from anywhere unless I know it's good for the v.
    Just debating the chrome lined vs standard BSM.
  14. tanasit
    tanasit Member
    399
    60
    Philadelphia
    The ebay link that I posted earlier clearly states that it is for the Prius V. They also shows the pictures of a black V with the moldings.
  15. BTBAM
    BTBAM Beatmaster
    Cincinnati, Ohio
    Must have completely missed that, thanks!
    Still can't gather my thoughts on if the plain or inserted with chrome looks better on the black V's
  16. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    Looks great. I did the same. I was curious where did you get the front spoiler guard. :)
  17. tanasit
    tanasit Member
    399
    60
    Philadelphia
  18. Danny
    Danny Admin/Founder
    7,094
    2,115
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I'll try to add the chrome-lined moldings to the PC Shop today. I have always had access to them, just didn't realize there was a market for them.
