Why is the charging port in back?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rebound, Nov 18, 2011.
  1. pfile
    pfile Member
    319
    35
    bay area, ca
    i think at public charging stations it could be awkward since those tend to be at the front of the parking space.
    i have a leaf and my service is near the front wall of the garage. so we have to back the leaf in to charge. having the port at the back actually works out better for us.
  2. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Exactly how I feel!
    I like the fact that there is less cabling. This means less resistance in the charging connection (or very heavy/expensive cabling) and a more efficient charging operation.
  3. skm009
    skm009 Member
    132
    Ohio
    I would prefer it in the back. Works perfectly for my garage.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The electricity already traveled many miles to your house, and it travels from the battery to the engine in front -- a few feet more wont hurt.
    There are more and more public charging stations. Oakland Airport has a bunch. What if there's charging at an airport or shopping mall or your office? Will you really want to back into those spots every time?
    The charging port should be in front.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yeah, I think it was cooler in the front but I prefer it in the back as well.
  6. calbear
    calbear Member
    180
    30
    SF Bay Area
    Thanks - that's a great idea. Hadn't thought yet how I'd run the circuit, but I was only thinking in 2D. Going up and over would be easiest for me too, so this is very helpful. Thanks again!
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I also remember seeing a post from Prius Team reminding us Americans that Toyota is kind of an international company and that Prius will be sold internationally. Feedback from Americans is thrown into the same pot as the consumer feedback from the rest of the world. I can understand the variances between right-hand and left-hand steering wheels but completely reconfiguring the wiring of the car is not likely to happen based on the wishes of a single region.
  8. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Have you seen the price of 12AWG copper? They save about 12-15 feet of 12/3 + the 20AWG pilot wire, not to mention the weight saved for that cable as well, and the reduced labor costs, since the charging port is now located right by the actual charger and battery pack. It was a cost savings, weight reduction and reduced labor cost move.
  9. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    I like where it is in the Leaf. Essentially keeps the plug out of the way in the tight garage. I can still walk around the car without bumping into the plug. For people with larger garages, it may not matter much.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It literally sounds better. In the prototype, the charger electronic is placed under the passenger seat. Cooling fan can come on and make noise.
    Moving the charger port to the rear also allow them to put the inverter under the battery pack. I doubt you'll hear the fan anymore but then who sits in the car while charging right? At least it frees up the space for audio amp or Nav that are placed there normally.
  11. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    My garage is already prepared for the "up and over" set up. It was not hard, it is out of the way, it does not require a long cord and it is handy no matter where the plug on the car is located.
    This simply turns out not to be a big deal.
  12. timdsd
    timdsd Junior Member
    46
    San Diego, California
    I have a very old house on a skinny lot in San Diego - the houses are very close together. The driveway on the right side of my house runs a few feet from my neighbor's house. I wonder if they've got any outdoor receptacles. Hmmm... Think I'll go take a look.
  13. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    I just hope I don't damage the cord- or get it stollen at a charging station . Wonder how much it is to replace?
  14. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Yes there are outside charging stations for residedential usage.
  15. timdsd
    46
    Sorry I wasn't clear. I meant that I wondered if my neighbor's house has any outdoor receptacles already installed. Free electricity! Just kidding, of course.
  16. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    There are already cables that run from the front to the back present. This is how the batteries get charged from the inverter, and how power goes from the battery to the inverter.
    I think it would be trivial to have the charge point in the front of the car, or on the side in front of the driver door. I agree that this is more natural and preferable.
  17. lensovet
    2,615
    496
    Burlington, NJ
    another thing that was mentioned was that if you have curbside chargers, it actually makes much more sense to have the charging port on the passenger side.
    also, people who are wary of backing into your garage? guess what, backing into your garage is safer than backing out of it. and most of the world parks this way already.
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Little off topic, but would you typically leave the PiP plugged in all night long? IOW you leave it plugged in at home whenever you are not driving it?
    Not to be negative, but seems to me there would be a lot of plugging and unplugging to the port. Too bad it's not at least on the driver's side. Well, in Japan it is. Obviously there is a level of commitment required to actually use the plug regularly.
  19. lensovet
    2,615
    496
    Burlington, NJ
    Huh? How are those not the same thing? Presumably you'd plug it in whenever you can to maximize EV range, no?
    And I'd think these things are designed for tens of thousands of connects/disconnects. Regardless in CARB states you have a long enough warranty on these components that it really shouldn't matter.
  20. iRun26.2
    824
    169
    United States
    The connector is supposed to be able to withstand being connected and then disconnected once a day for 27 years. This should be more than enough for most people.
