SSC 50P vs TSB EG047-04
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by markl_me, Dec 1, 2005.
  1. markl_me
    markl_me New Member
    Portland, Maine
    Help - I received notice of the SSC 50P campaign (for engine stall problem). But in May '05 I had TSB EG047-04 applied for the same problem. Wondering if they were the same ECM reprogramming I called Toyota at the number listed in the SSC notice [ (888) 270-9371 ]. The person I talked with said the reprogramming was the same so it didn't need reapplication (but the dielectric grease needed to be applied because it wasn't part of the TSB).
    So I called the dealer to schedule, and they said the ECM needs reprogramming. When I called them on it, they backed off, saying "Well, you may be right, we'll look into it." FYI, this dealer is less than credible in my mind - they can't even change oil without overfilling, even when I warn them of past (mal) performance.
    My questions:
    1. Anyone know if the TSB and SSC reprogramming are the same or different?
    2. Anyone know a Toyota number where a definitive answer can be obtained? The person I spoke to on the 888 line was not real convincing.
    3. Anyone know if there's any harm in re-applying the ECM reprogramming if it turns out to be the same as what's already been applied via the TSB?
    Thanks,
    Mark
    Portland, Maine
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    Hi markl_me
    I suggest you search the forum on, say, "50P" A few re-programming attempts have resulted in damaged ECMs - rare, but much trouble when it happens. Seems the scanners used by the dealers received faulty software early on. Take a look at "RECALL GONE BAD" in this forum.
    I have chosen to defer the re-programming until my dealer has successfully done several. I believe you will need the SSC 50P in addition to the previous programming.
  3. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    The reprograms are probably different. As I recall the EG047-04 was for a problem where the ICE failed to start and SSC 50P is for a running ICE stalling.
  4. markl_me
    markl_me New Member
    Portland, Maine
    jfschultz -
    I believe you are incorrect re: EG047-04 was for ICE failing to start. There was much discussion here and in Yahoo group Prius 2-G late last year and early this on stalling Prii. I know - my Prius stalled on my wife, and fortunately I had been keeping up and knew it was not serious. She restarted the Prius with little/no problem and continued running her errands that day.
    When I called the dealer seeking the EG047-04 because of the stall, they said (correctly) that it would depend on the error codes in the computer(s). When I got the car back, they said I was right - EG047-04 flash reprogram was needed.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Information like this *should* be readily available from Toyota,
    but this is one of the areas where they're astoundingly balky and
    given to obfuscation and "just trust us"ism. Why the hell shouldn't
    I be able to know the exact rev of their code that I'm running
    in my ECUs, and where's the changelog I can read to determine if
    I really need a given set of fixes or not? Arrrgh. If they'd only
    provide that then you'd immediately know if SSC50P == EG047-04.
    _H*
