Lost all keys (FOB) Genii Prius, in Atlanta GA on thanksgiving day.
Discussion in 'Gen 2 Prius Main Forum' started by timtim2008, Nov 23, 2011.
  1. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    Lost all keys (F-O-B in a Genii Prius, in Atlanta GA on day before thanksgiving.
    what can i do? Im located in atlanta, anyone recommend a locksmith? or will i have to wait until friday, when (if) dealer opens.
    and how much? :(
    05 Prius
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    Unless you get lucky and find an automotive locksmith that can do an immobilizer seed reset, you are looking at a dealer visit. Cost expectation is $300 at the absolute barest minimum, which includes a seed reset and a new key. More than likely you will be quoted $400-$500 for 1 key, and $250 for each additional. An automotive locksmith is unlikely to be significantly cheaper, i.e., this is not something that can be fixed for $50. But, you do not need to spend $1500+, as often happens when a service advisor quotes for a new immobilizer ECU, which is not necessary.
  3. richard schumacher
    7,686
    1,068
    United States
    I've nothing to add. Are you willing to say how they were lost?
  4. Stormy Steve
    Stormy Steve Junior Member
    Rockmart ga
    Rome toyota today,300.00 for fob and prigram,bit if it didn't work,no refund,I said,the tech says it's the fob,u order a fob,it's here,I'm here,I have the 300.00 you warranty your repair.No sir ,you will eat the the cost if we are wrong.
    I drove home with my old non working fob.
    Sks fob.
