Fuel Door Won't Open
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Atwork, Oct 23, 2007.
  1. Atwork
    Atwork New Member
    27
    Queen Creek, AZ.
    Wondering if anyone has had this happen....for the last week or so my prius is flashing a quick needs maintenance when the car starts, different than before. Then when I needed to refuel, the door would not open, no matter how much I pressed the little lever by the drivers seat. Bad, because I was at a station with one pip and no way to refuel, nearest dealer not near enough to reach with the gas remaining. Anyway, I attempted to open it with my fingers, a nail file for some leverage and did eventually get it open. That was two days ago. Today when I start up my car the needs maint. is just on, period. No oil change etc. is due right now. Any thoughts? Thanks.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You don't press the lever for the fuel door, you pull it up!!!
    The Maint Req light flashes before it reaches the 5000 mile mark and then stays on. Most likely it was not reset at the last oil change
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    The light and the fuel door aren't related. Resetting the light is
    in the owners manual. The fuel door sounds like a problem, though;
    it's not hard for the latch piece to get bent out more so that the
    pin doesn't release it when you pull the cable. Or the cable itself
    could have busted -- have someone watch the little door pin while
    you pull the handle and see if it still moves.
    _H*
  4. Atwork
    Atwork New Member
    27
    Queen Creek, AZ.
    <div class='quotetop'>QUOTE(firepa63 @ Oct 23 2007, 12:17 PM) [snapback]529344[/snapback]</div>
    Yes, push, pull, I'm at the computer and not at the car. No routine maint. is due, which is why I was wondering. I'm familiar with the routine maint. reminder, this is different.
    <div class='quotetop'>QUOTE(hobbit @ Oct 23 2007, 12:17 PM) [snapback]529345[/snapback]</div>
    Good idea, I'll try that. Thank you!
  5. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(Atwork @ Oct 23 2007, 12:39 PM) [snapback]529355[/snapback]</div>
    So. Which light is on? Is it the maintenance required light? The check engine light?
    I think the reason that firepa suggested the Maint Req light is because your description sounds like exactly what happens when it's been 4500-5000 miles since the light was last reset.
    The Maint. Req. light is just simply a counter that tells you when 5000 miles have elapsed since it was last reset (hopefully at your last oil change, but some dealers have been known to forget to do it from time to time). The Check Engine light can indicate a lot of different things and potentially can mean a more serious problem with the car.
  6. aaf709
    3,862
    2022 Prius Prime
    You might try to lube the pin area once the door is open. Dirt and the like may be clogging up the works.
  7. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I'll parrot the "maint req'd" light comments, but add that if you're on a slightly different maintenance schedule than the recommended, e.g. you do oil changes every 3-4000 miles instead of 5 (or, gasp, longer than 5,000 mile intervals :) ), and/or you don't have service done at a Toyota shop, then that light won't be in sync with when you do service.
  8. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(hobbit @ Oct 23 2007, 10:17 AM) [snapback]529345[/snapback]</div>
    When I experienced a similar problem, the cable and the pin worked just fine, but the spring that pushes the door open was missing. If that were to be the case, you need to have someone pull up the lever while at the same time you push in the hinge side of the fuel filler door.
  9. Atwork
    Atwork New Member
    27
    Queen Creek, AZ.
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Oct 23 2007, 01:14 PM) [snapback]529376[/snapback]</div>
    Ah, good to know, thanks!
  10. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    If you don't have a second person handy, you can hook the release lever under the driver's shoulder belt to hold it up while you push the fuel door open.
  11. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    <div class='quotetop'>QUOTE(aaf709 @ Oct 23 2007, 12:51 PM) [snapback]529364[/snapback]</div>
    Yup! It's quite normal for a spring/hinge to dry up after awhile. A squirt of WD-40 will make a world of difference.
  12. stormyronwhite
    stormyronwhite New Member
    Florissant, MO
    Re: Fuel Door Won't Open
    Thanks for the tips, you Prius owners. It is Thanksgiving Eve at 11:23 and I just got back from the filling station AFTER following this specific detail about propping up the lever. It worked beautifully. I can work out the kink after Thanksgiving, thankfully. Now we head 300 miles away to my Mom's 90th birthday celebration!!!
  13. gramps
    gramps Member
    199
    45
    Southeast Texas
    Thanks every one.
    I have been having the same problem. I guess it needs lubrication.
    I fill up so infrequently that I always forget to try to fix it.
