Plasmacluster in european Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by stealth_mode, Nov 25, 2011.
  1. I love it - i believe it does what it should
    50.0%
  2. I like it - I don't believe it works
    25.0%
  3. I like the idea - but i think it harms humans
    0 vote(s)
    0.0%
  4. i don't like it - it pollutes the air with ozone an ions- switch it off- it will eventually kill
    0 vote(s)
    0.0%
  5. i don't care whether or not using it
    25.0%
  1. stealth_mode
    stealth_mode New Member
    Switzerland
    I am trying to equip my euro-Prius with the plasmacluster. The full loaded package in EU doesn't have the PC - i like those gimmicks and believe it works an will not kill me and my family.
    so here is my project:
    I ordered the "ion generator" (88051-12010).
    Now I want to bench test the unit before tearing apart my car ;-)
    did any one do this before?
    did any one bench test the ion-generator before?
    does any body have a wiring diagram of the PC-unit (not the Prius)?
    does any body know the switching condition (pin1(PCSW) and pin4(PCD1) to trigger the modes (stop, clean, ion-generation)?
    it should be easy to measure the two signals accessing plug LI2 just above the upper glove compartment (pin9"light green" and pin 7 "Pink").
    it is accessible without tools - I did it -
    but unfortunately the EU Prius doesn't have the Harness installed that goes to the A/C Amp Assy and I do not know if the EU-Prius is programmed so it would communicate to the ion generator.
    And the A/C Amp plug (L17-17-36) isn't accessible that easy.
    I am looking forward to discussing that issue
    any thoughts?
    T.
    SFO likes this.
  2. stealth_mode
    Switzerland
    Any thoughts?
  3. LVPVS
    LVPVS New Member
    Europe
    Any progress with this project?
    Thanks.
