TMC Starts Taking Orders for Soon-to-be-launched 'Prius PHV' Plug-in Hybrid in Japan
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ken1784, Nov 29, 2011.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Vehicle Has EV Cruising Range of 26.4 km, PHV Fuel Efficiency of 61.0 km/L
    Nov. 29, 2011
    Toyota City, Japan, November 29, 2011—Toyota Motor Corporation (TMC) began taking orders today through Toyota dealers around the country for the "Prius PHV" (plug-in hybrid), a gasoline-electric hybrid vehicle that can be charged using a household electric outlet. TMC will launch the vehicle in Japan on January 30, 2012.
    read more
    official JP Prius PHV site (Japanese language only)
    JP Prius FAQ site (Japanese language only)
    Ken@Japan
    4 people like this.
  2. hill
    8,803
    Thanks Ken - are there any rumors of a PHV Prius v Plug yet?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    That's about 3 kWh (26.4/8.74) usable power from the 4.4 kWh battery pack. I am not sure if it includes the charging loss. The electric power consumption rate is under JC08 test cycle which is less aggressive than the EPA cycle.
    As for comparison, Leaf's electricity consumption under JC08 come out to 8.33 km/kWh (200km/24kWh). PiP can go further than Leaf for a given amount of electricity!
    Mitsubishi MiEV can go 9.09 km/kWh. It is a smaller and lighter car without gas engine so it is more efficient.
    Under EPA figure, MiEV is rated 30 kWh/100mi and Leaf with 34 kWh/100mi. PiP should be between the two so my guess would be 32 kWh/100mi.
  4. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    No rumor of a Prius v PHV yet.
    Ken@Japan
  5. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The 3 kWh is AC consumption value for charging, therefore it includes the charging loss.
    That's correct.
    The other spec says PiP is 114 Wh/km and Leaf is 124 Wh/km.
    Ken@Japan
  6. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    This same news release said that Toyota will raise Prius (2012) prices when the c hits the market since that car will be the entry piece and they can increase Prius profit margins. It will be interesting to see if the the great deals on the 2011's will tighten up as the inventory gets depleted?
  7. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    This is confusing. I assume the Prius HEV is different than the Plug-in Prius launching in the US. Does this mean the US version will also get the slightly higher EV range?
  8. Tideland Prius
    16,555
    YMMY. It's the same reason why the Prius has a higher mpg rating than what the EPA gives. It's a different testing method.
  9. Trollbait
    12,534
    Plus, in North America the EV cut off speed for the the Prius PHV is 62mph. In Europe, and likely Japan, it's 58mph. This will likely have a effect in the different tests.
  10. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    I'd like to see the graph of speed vs distance. Hopefully, with careful driving we can push that EV range to ~20 miles.
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I don't know where you get the 58 mph number, but the JP press release says the EV speed is up to 100 km/h (62 mph).
    Ken@Japan
  12. Trollbait
    12,534
    I remember reading that the EV to hybrid switchover happened at 58mph for European models. Perhaps it was a conversion error of the 100km/hr.
