Beep when shutting off car ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Azipod, Dec 18, 2011.
  1. Azipod
    Azipod Member
    139
    NorCal
    Recently, my 2007 Prius will make a "BEEP" when I press the POWER button to shut down the vehicle. This doesn't happen all the time, but only 1 out of 25 times or so.
    Other than the beep, I can't seem to figure out what's wrong. Everything seems to work as normal.
    Does anyone know what the BEEP is referring to?
    Thanks.
  2. KD6HDX
    KD6HDX New Member
    256
    Chino Hills,CA
    Might be the battery in the key- fob getting weak...maybe? I have had luck replacing the batteries. Look up threads on that for help.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Yup. It's the key fob battery.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  5. Azipod
    Azipod Member
    139
    NorCal
    Thanks for the quick replies guys! I'll get the batteries replaced when it starts beeping more frequently. Thanks again.
