Poor MPG, dealer said to change bearing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Korozive, Dec 18, 2011.
  1. Korozive
    Korozive Junior Member
    Montreal
    Hi everyone,
    I'm sorry if the text is long, I'm trying to sum everything for a good troubleshoot.
    I just bought my second Prius. I have all the records and maintenance from the dealership.
    I have one issue that I'm not sure with , I hope you will be able to help me.
    My fuel consumption is very bad. I used to do 4.5L/100km with my other one but this one goes around 5.9L/100km.
    On the last inspection from the dealership, they said I needed new front bearings (hubs). I saw the car on the lift and the person asked me to put my hand on the coil spring to feel the vibration. He explained me this vibration is caused by the bearing. I still agree with this statement.
    Where I'm not sure about is ... even on the highway it's still silent and I don't hear any noise coming from a bad bearing. On "D", my prius coast really fast, so I guessed it was really the bearings.
    But then I tried to coast on "N" and it was a really normal decel rate ... like if the problem wasn't the bearing but something in the transmission or regen braking.
    What could it be ? My hybrid system is still under warranty.
    Thanks
  2. Korozive
    Montreal
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    5.9L/100km
    - What fuel economy are you expecting and why?
    5L/100km, because I was doing this with my other Prius
    - What are the approximate outside air temps?
    Minus 7 degrees, but I only consider when the engine is warm
    - How long are your trips?
    35 min
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    50/50
    - What region/state are you in? (if you haven't set your location in your profile)
    Montreal, Canada
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    flat, gentle hills
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    No
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    I don't know. Open to suggestions or link (new to forum)
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    Brand new winter tires.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    Nokian 185-65-R15
    - What are your tire pressures?
    35 psi all around
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    Other Prius , same year, model , 1 month ago.
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    as smooth as possible.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    I have to, car is stock
    - Are you driving using D or B mode?
    D, what is B ?
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    Everything off
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    See youtube link. Slowing down pretty quickly on D , but I then noticed on N it was a very normal deceleration.
    Only bearing like dealer said or something else ?
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    What was happening to originate a vibration? Turning the wheels? Or try to make a wheel wiggle?
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Start by doing some manual (litres used, kms traveled) calculations, the MFD result might be off. You may need to average it over several tanks to get an accurate measure.
    When I first got my S/H prius the displayed consumption was mostly around 5.5 to 6.0 L/100km, but when I actually measured the litres and kms and did the manual calculations it was actually under 5. Interestingly over time the displayed value got more and more accurate, and now it actually reads just a little bit optimistic, but still pretty close.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    When it is cold outside, the engine cools off faster, so it has to run more.
    0.2 - 0.3 l/100km difference at least is to be expected with winter tires, especially at your under inflated pressure.
    The more electric you use, the worse your fuel economy will be.
    You don't have to... Your answer doesn't make sense. Warming it up or putting the HVAC on a high temp makes the engine run more, and reduces your fuel economy. You are using some litres per 0km which means you get 0 averaged in. That is never good.
    You really should read your manual. You only have 4 modes in the Prius. Park, Neutral, D-Mode which is normal Drive, and B-Mode which is engine braking.
    Also, you are getting about 40mpg. In what world is that poor for using winter fuel in -7C weather?
  7. Korozive
    Montreal
    Thanks for the answers
    I agree winter gas might be less efficient than summer gas because of additives into it. But I disagree on the other part. Let say you're driving at 65 mph during the summer (+20C) or during winter (-15C). Your engine should be at the same operating temperature. The difference is the opening of the thermostat (I'm talking about general mecanic, since I know nothing about Prius)
    Wow , I thought 35 was more than expected (35/32 written in my door). What pressure do you have ? For the .2-.3 worse , I had another prius with also brand new winter tires so I can compare apple-apple.
    Really ? How come, I thought the point of having a hybrid was driving on batteries at low/constant speed.
    Didn't read carefully, sorry. Not really, I press start then I drive slowy (engine rev low). I never press the gas so it revs fast.
    Thx. So in B mode it's the engine and not the regen brakes ?
    Well it's not only about mpg. I know as a fact my car slows down at a anormal rate. I have to give more "load" in the gas pedal for the same commute. I have a video showing the speed but I can't post it since I have < 5 posts.
    Thanks again
  8. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Any energy lost has to be made up by running the ICE (Internal Combustion Engine) more. Heat is lost faster in cold weather.
    Most of us run at 42 PSI in the front and 40 PSI in the rear (as long as that is below the rated MAX of your tires) to get better MPG, Treadwear and handling
    Any energy used from the battery has to be replenished by the ICE (or indirectly via regenerative braking). The process of saving energy in the battery and then taking it back out is not terribly efficient which is why he said to try to NOT use electrical energy and save MPG. The main benefits of our Hybrid Synergy Drive (HSD) are:
    1. The ICE can be smaller - More MPG - without sacrificing overall performance and can be an "Atkinson Cycle" engine
      1. Higher peak efficiency
      2. Low torque at low RPM but the electric motors cover this flaw
    2. Regenerative braking to avoid wasting energy when slowing down
    3. Always operating the ICE at a high efficiency operating point
    Actually a combination of both in B.
    JeffD
  9. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Korozive - Give this a try for a week or so - forget that you are driving a hybrid and drive it like a regular car that you are trying to maximize fuel economy with - still be gentle on the gas (but not overly so) and think ahead to avoid heavy braking. I know that it is a bit counter intuitive, but your mileage might tick up a bit.
    Another poster converted the metric to english and said that you are getting around 40 mpg - to me that is about the low end of what I expect. Here in Philly it has been in the 30's to 50's for the last few weeks and I'm seeing mid 40's. My tires are all seasons that are a year old and inflated to 42/40. I'd figure the tires and the colder weather up there are good for a few mpg's and a bad wheel bearing likely would bring it down a bit further.
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    At low speeds the engine has a hard time maintaining proper operating temperature when it is very cold out. As such, when you come to a stop light or you are gliding (engine off) to a stop or down a hill, the engine will either remain running when it wouldn't normally be running if it was warm out or it will cut your glide short by turning on the engine to warm back up.
    e.g. On my work to home commute I drive down a long hill (1,200ft. to 250ft. for about 6 miles). In the summer months I can glide down a lot of this hill with the engine off. In the winter when it is <40Fdegrees I can only glide for so long before my engine temp drops so low that the engine turns back on. This drops my mpg from 9999 to about 150mpg. That is a pretty big difference in total mpg and how it contributes to a lower number on my tank average. The same can happen when gliding to a stop light/sign. In the warm months you may be able to glide for up to a mile before coming to a stop but in the winter the engine may kick in much earlier and ruin mpg.
    Were they the same tires? Different tires will exhibit difference rolling resistance characteristics. Depending on the tires you could lose 4+mpg just by switching models/brands.
    This has already been covered above but remember the laws of thermodynamics! You cannot transform energy into different forms with suffering a loss. So using battery power which is derived mainly from gasoline requires an extra conversion which ultimately leads to a loss of overall MPG. Use the gasoline engine more and glide (no engine, no electricity) as much as possible.
    Accelerate briskly to get up to speed. Then lift off the throttle and reapply gentle pressure to maintain desired speed. Buy a ScanguageII to assist you in finding the sweet spot for acceleration. Many have found that accelerating briskly is better for mpg than driving super slow off the line.
    This could be another issue with the tires being different (if they are) and new. It could also be a bearing issue. I've never had a bearing failure so I don't know much about it's affect on inducing extra load on the vehicle but it makes sense.
  11. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  12. Korozive
    Montreal
    Ok guys,
    I did the test this morning. Here's what I got.
    Car has 148 000 km (92 000 miles)
    ACC : 11.8v
    LOAD : 11.1v
    READY : 13.6-13.7v
    So I should change my aux. battery ? How long does it take for a first time ?
    Is it covered in the 100,000 miles hybrid warranty ?
  13. ursle
    ursle Gas miser
    1,049
    192
    NH
    If you look at the battery and it's not an optima yellow top it should be.
    If your wheel bearing are shot the noise and vibration would be evident.
    As it's cold A)your gas tank bladder has shrunken stealing 2 or 3 gallons of room, that will skewer your calculations. B)10%+ reduction in mileage due to cold weather, everything turns harder.
    Snow tires are going to cost you 3-5mpg.
    Is your emergency brake hanging up?
    Are your ice air filter and cabin air filter clean.
    Is your oil 2/3rds up the dipstick and not overfull.
    Possibly an intermittent firing spark plug.
  14. Korozive
    Montreal
    * edit *
    I called the dealer since my 120$ inspection was last month. Battery is OK, they checked it.
    It's only noticeable on the lift with the hand on the coil spring. So it's not the time yet , maybe in 5000 km (and it costs me 1-2 mpg right now which I'm aware of)
    Talking about temperature, does the batteries stay cold when driving ? Or what temperature they get to ?
    Thx. But all of my calculations were made with winter tires (other prius)
    No, on Neutral it slows down at a normal rate, so e-brake looks fine and works fine.
    They were changed at the dealer few months ago.
    Oil change was 1000km ago at Toyota. Will check tonight to make sure.
    Thanks for your input.
    So far we're looking for What affect my mpg ... but on D the car slows down quite quickly so logically it's not related to the weather (because on N everything looks great).
    * edit *
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Remember that the Prius is supposed to slow down to some extent when your foot is off the gas, even in "D" mode. Sure it's more pronounced in "B" mode, but there's definitely a "by design" simulated engine braking in "D" mode.
    Korozive, can you confirm that you get an "engine braking effect" in both "D" and "B" mode, with the "B" mode effect being about double that of the "D" mode. Perhaps you are somehow effectively stuck in "B" mode all the time?
  16. seilerts
    3,326
    1,520
    Santa Fe, NM
    WE are telling you to replace your battery based on your test. 11.1V at Ig-on is a severly weakened battery. It is within 0.5V of not starting. There's a good chance the DC converter is maxed out trying to charge that brick, and that extra energy has to come from somewhere.
    If the technician could not demonstrate axial play in the bad wheel, then I don't believe the wheel bearing diagnosis.
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    I wouldn't trust the dealer. We have had many people come in here and say the dealer said their battery was fine but when they checked it themselves with a digital volt meter and found they had less than 12.2v. IMO anything below 12.2v is time for a new battery.
  18. Flying White Dutchman
    4,376
    313
    if you dont trust us then go on google and lookup what normal and BAD voltages are for your 12 volt battery and you will see....11.8 is not that good.
    then tell you dealer that you never return there:p
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    +1, a wheel bearing bad enough to cause a serious fuel mileage loss would be making a lot of noise and then shortly self destruct.
