Navigation Version information
Discussion in 'Gen 2 Prius Technical Discussion' started by kornkob, Dec 20, 2011.
  1. kornkob
    kornkob New Member
    128
    Wisconsin
    While there are many threads on Nav updates and hacks, my Google-fu has proven to be too weak to discover how one would determine what version of the Nav software a Prius currently has loaded.
    I'm currently looking at a 2009 Touring and am considering making the Nav update a point of contention during the negotiations with the dealer.
    Can someone point me to instructions on determining the version?
  2. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    To get your version number, hit the Menu button, then select "Map DVD" on the touch screen (top right). Likely it will be ver 7.1
    Also make sure the car is really a touring as lots of dealers say a car is one when its really not. The easy way to get a sense is to count the spokes on the wheels. If it has 7 then it has the touring wheels and is likely a touring model. If it has 6, then its not likely a touring model
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep. They're very commonly misrepresented. Look at the tire sizes. If it has 15" wheels, it's not a touring or someone put on wheels from a non-touring (doesn't seem that likely).
  4. kornkob
    kornkob New Member
    128
    Wisconsin
    Thanks for the extra tips on the model...
    and even more thanks for the info on how to determine current nav info. |
    Where would I find out what version of the nav is most current available?
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Toyota updates the Nav DVD once a year around October. The rev number is for the year. The latest Nav DVD update is 11.1 for 2011.
