Gas engine turning on right after start, revving high, and a p3190 code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dragonpark, Dec 21, 2011.
  1. Dragonpark
    Dragonpark New Member
    Philadelphia
    Hello everybody,
    My girlfriend has a 2004 Prius with the nav kit and has been having some rather odd issues as of late, of which seemed to have started after she hit an animal. The gas engine in her car seems to be turning on right away when she turns the car on. The engine also sounds quite loud, almost as if it is revving. Her gas mileage has also dropped considerably, from 45-ish down to around 33 mpg. Also, upon stopping, the mileage gauge on her nav screen doesn't immediately go to 99. Instead it sits around in the 40s for a while before jumping up to 99.
    Now, she mentioned this to the tech at the dealer when she finally went to get the recall done on her water pump, but the guy said it drove fine and threw no codes. She then took it to another shop who said it threw a P3190 code, but he had never seen this issue and wouldnt know how to fix it.
    Now, I sure as hell don't want her to spend a lot of money trying to get this issue fixed as well... we don't have a lot of money. The only thing I could find while searching around (mainly on this forum) was that it could be a problem with the electric throttle body. Any body have any input on the thought? The throttle body seems to make sense to me, but she isn't totally convinced. She also has a 200+ mile trip coming up for the holiday season and it would be nice to fix the issue before that.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Has the air throat area and MAF been cleaned? Has the spring mechanism where the air intake actuates the throttle been cleaned and lubricated?
  3. pippijones
    pippijones Junior Member
    63
    Philadelphia, PA
    I'm the girlfriend and Prius owner.
    As far as I know, these have never been done, I'm not the first owner of the car and there is over 116,000 miles on it, so maybe it is time to clean it.
    I also wanted to elaborate a little bit on my conversation with the tech, he was telling me that the engine is revving loudly but there isn't any torque, which I could have told him this issue has been slowly getting worse in the last two months. Its especially bad on the highway. When the code came up (P3190 Poor engine power) he speculated that it could be a power converter (not quite sure I heard that right on the phone) but like my boyfriend said above he has never dealt with this issue before and didn't know what exactly the problem is.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    You hit an animal. Are you saying that the car was fine, you hit the animal, then you started having problems? What sort of physical damage was caused?
    MAF and TB cleaning is usually the place to start with P3190. But what you describe also sounds like a problem with the engine coolant temperature sensor -- engine runs all the time, rich, because it thinks that it is -40F.
  5. pippijones
    63
    Philadelphia, PA
    The car was running fine and then I hit the animal, the body shop and the mechanic are both saying it has nothing to do with what I am experiencing. The only damage that was caused by the animal is my grill was ripped off and the bumper is bent at the bottom.
  6. seilerts
    3,326
    1,520
    Santa Fe, NM
    First thing to check is the engine coolant temperature as reported by the ECM (engine computer). It should be over 185F after about 10 minutes of driving. You unfortunately need a scan tool for that, but even the cheapest ones will do it. If you have an infrared thermometer, you could also measure temperature of the upper radiator hose. Is the grille missing completely?
  7. pippijones
    63
    Philadelphia, PA
    Yup the grille is completely gone, I'm going to have it fixed but just not right now.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you said you have no clue as the the maintenance of this vehicle...
    this makes me wonder... how are the spark plugs and ignition coils? i've had an ignition coil fail without throwing codes. it acts real sluggish and doesn't charge very well. the only way i found out was by pulling the coils or unclipping them (either or... one throws a code the other doesn't)... when i pulled coil 1, the car continued to run exactly the same (indicating it was dead)... if i pulled any other coil, the car threw codes and shut down. so... it can run if one fails.. if two fail, it fails.
    does it sound like a cylinder may not be firing right? like a slight limp to the engines balance? it's all load controlled by the electric motors so anything you do feel is lessened (i was surprised my engine even ran on 3 cylinders)
  9. pippijones
    63
    Philadelphia, PA
    The spark plugs are fine, and the battery is charging fine. It just seems like the car isn't using the battery. I turn on the car and instead of the car sitting silently it starts to idle. When I accelerate, the engine revs, sounds like a "regular" car when the rpms are really high, but the car is sluggish and hardly has any torque. So my gas mileage is dropping like a rock.
    I'm just trying to decide if I should just take my car to a very reputable dealership in the area and at least get more of an idea on what is wrong with it. I'm sure
    I'm just jumping to conclusions and getting anxious over what isn't really a big idea.
  10. V8Cobrakid
    3,790
    152
    has it been cold during these problems? do they go away over time?
    is this your first hybrid? how long have you owned it? do you accelerate heavily during the first few minutes of your drive? (you're a new owner, i want to re cover the basics)
  11. pippijones
    63
    Philadelphia, PA
    This is actually my second Prius, the first one I had was a newer one (2006) but I only had it for 6 months. The current Prius I've had since March 2010, so roughly over a year and a half. I'm located in Southeastern PA, and there was a recent cold snap, but since this problem started there hasn't been that many cold days. I don't accelerate heavily during the beginning of the drive, and recently when the engine starts revving loudly I actually lift my foot off the gas but once I put it back down it starts revving again.
    Last night I went out and took a look at the throttle, its not stuck open but I'm going to clean it anyway although I wont get to that till next week.
