HELP! There's a hole in my synergy drive!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenMaterialism, Dec 22, 2011.
  1. GreenMaterialism
    GreenMaterialism Junior Member
    70
    PA
    [APOLOGIES - in my haste, this landed in the Prius V forum, but it's all fixed now. Please don't tell Santa I goofed!]
    Greetings ladies and germs...
    So I was just under the hood topping off the windshield washer fluid, pre-holiday roadtrip. There I stood, admiring the amazingness that is the hybrid powertrain (and anticipating explaining it to relatives - again), and I noticed a strange thing...
    I was looking down into the space behind the inverter, at what I'm guessing is the main traction electric motor, and there's a deep threaded hole in the top of it, with nothing in it. It looks like it should have a bolt, or at least a plug/bung in it. I know this sounds like a very strange query, but is this normal? (Or, can you take a quick peek at your car and see if yours is the same...)
    Here are two quick photos, with the hole in question circled in yuck-green. (Sorry for the off-focusness of the 2nd one, but the hole in question is about a foot below that bracket that's in focus.)
    [photos got borked, so I put them in the reply...]
  2. GreenMaterialism
    70
    PA
    eek - those photos aren't displaying correctly on my machine, so here's another try:
    closeup:
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    looks like a mounting hole for something. Doubt the hole extends all the way through.
  4. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    That's where the supercharger gets bolted on, sorry, not really.
  5. qbee42
    3,081
    That's the electron fill hole. Every 35,000 miles you should change the electrons in the MGs, topping off in between if the level gets low. If you aren't finding electrons on the floor of your garage, you probably don't have a leak.
    [ For those technically challenged, this reply is a joke. Please don't go out and look under your Prius for electrons. On the other hand, what the heck; go out there and take a look. Post pictures if you find any.]
  6. GreenMaterialism
    70
    PA
    One of my thoughts as well - perhaps for a lift-eye?
  7. GreenMaterialism
    70
    PA
    Now that, good sir, would be awesome. Must make an emergency last-minute change to my christmas list!
  8. prj
    prj Member
    OH
    I have the same hole, but it's doesn't appear to be threaded.
    That's for the turbo encabulator, but only on European models. Here's the video explaining how it works:
    from the video:
    Now basically, the only new principle involved is that instead of power being generated by the relative motions of conductors and fluxes, it is produced by the modial interaction of magnetoreluctance and capacitive directance.
  9. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
  10. GreenMaterialism
    70
    PA
    Oh no - synthetic electrons?!?! And I'd just ordered conventional ones. Do you know, does anyplace on the interwebs sell these? The dealer charges way too much!
  11. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    eBay, 2 moles worth for $9.99
    2 people like this.
  12. glennhl
    glennhl Member
    175
    Arizona
  13. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Well d'uh!
    The hole through the engine represents the fastest route from the top of the engine to the bottom of the engine.
    Seriously? No one figured that one out?
  14. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Two atoms are walking down the street when one is hit by a bus.
    His friend is very concerned and rushes over crying "Are you OK?"
    "No, I'm not, he says, I've lost an electron!"
    Glancing up and down the street for stray subatomic particles, his friend asks, "Are you sure?"
    "Sure? Hell, I'm POSITIVE!"
    3 people like this.
  15. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Oh, THAT'S why my new Prius v Five doesn't have 17" wheels, it's a EURO model! I hope to hell the part where the manual explains how to operate the Turbo Encabulator is not in Swedish (as were the Thule Rack instructions for my Gen 2)!
  16. qbee42
    3,081
    Two neutrinos go through a bar.
  17. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    A couple weeks ago there was a Physicist on NPR commenting on a recent study which seemed to indicate neutrinos might, under certain circumstances, exceed the speed of light. This of course would open the door to time travel. He went on to note that since it was a single small study, about whose results he was dubious, its greatest impact was to make plausible the following joke;
    The Bartender says "What'll you have"? and two Neutrinos walk into a bar.
  18. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Heisenberg is out for a drive (obviously in his early pre-pre-pre-production Prius) when he's stopped by a traffic cop. The cop says 'Do you know how fast you were going?' Heisenberg says 'No, but I know where I am.
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    If you aren't changing the filter too, big repair bills are in your future! You're also crazy for going past the factory recommended 20k interval. RTM!!!!!!!
  20. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I have the same fitting. I can see the bottom of it because my engine compartment is still clean, unlike the outside of the car after all the messy weather. BTW, it's a purge port for excess electron pressure.
