2002 Prius fault code P3030
Discussion in 'Generation 1 Prius Discussion' started by priusmart, Nov 30, 2011.
  1. priusmart
    priusmart New Member
    Wendover
    2002 Prius
    Hi all... new to the forum :)
    My 2002 Prius is refusing to start, no ready light and has the main battery light and warning triangle on.
    I just code read the car and its come back with P3030.
    Just wondering if anyone can shed some light on what to do next? Very handy with spanners etc.... just a few pointers would help?
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    Santa Fe, NM
  3. priusmart
    Wendover
    2002 Prius
    Thanks for the info.... would this explain the non start and two warning lights?
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    723
    Boulder Hybids, Boulder, CO
    Also check the 12V battery, it should be more than 12V at rest before you turn the key.
    If not, charge it up....then disconnect the negative wire for a few seconds to "reset" all the computers....then try to start again. Does it code right away?
  5. priusmart
    Wendover
    2002 Prius
    Battery seems fine... even with a boost pack attatched it pops up the code P3030 straight away :(
  6. seilerts
    3,326
    1,512
    Santa Fe, NM
    Yep, you need to pull the traction battery, and it does explain the no-start.
  7. 3prongpaul
    954
    723
    Pull the HV battery out of the car, then check the bus bars and sensing wires. If you need just a couple of sensing wires I can send them to you for cheap. I have quite a few extras. Pmail me..
    While battery is out you should probably remove both sides of bus bars and clean all the terminals etc....or buy new ones.
    JamesPartridge and priusmart like this.
  8. priusmart
    Wendover
    2002 Prius
    Thanks for all the replies.... i am taking out the battery tomorrow and will pull off the bus bars.
    If i do need the sensing wires does anyone know where i can get them in the uk?
  9. sstk100
    sstk100 Junior Member
    Ne
    Working on a 2002 Gen I.....
    We just replaced the Gen I cells with Gen II cells, when done we get the P3030 code. Car starts fine but gets the red triangle and the car on display.
    When we did the conversion, we found a broken tab, and replaced it by cutting off one (from Gen II harness, with a short piece of wire) and soldered in the new wire and a new tab,... off the of the Gen II wiring loom. Is it OK to solder in a tab and short piece of wire???
    Or could we have missed another broken tab?
    Please help!
  10. seilerts
    3,326
    1,512
    Santa Fe, NM
    Yes it is okay. But use a meter double-check that repair, as well as the rest of the tabs.
  11. sstk100
    Ne
    I bought a new wiring loom for that side of the battery, and the error code problem has gone away.
    Re-installed the Gen I battery, that we retro fitted with Gen II cells and it's working perfectly. Charging the traction battery as it should.
    The whole process wasn't particularly difficult (although my son and I have considerable mechanical experience.) We were careful during the process to not fry ourselves...or the car.
    My cost for two Gen II batteries (2004 and 2006).... (for 38 of the Gen II individual cells) was $600 at salvage yards, plus about $100 for the wiring loom at Toyota. Did all the work ourselves otherwise. Total cost $700, but found a place that will buy the old cells for recycling and may get $100....so total cost for the "new" traction battery will be about $600.
  12. usnavystgc
    3,159
    989
    Tucson, AZ
    Awesome. You guys did a great job. I'm hoping for many more years of trouble free driving for you and your Gen I.
  13. sstk100
    Ne
    The 2002 was my sons car (our first Prius) and when the traction battery died. (at the 81,000 mark, as has been documented as the threshold) He got the red triangle, and lost electric power from the hybrid battery.
    We at first thought we might have to junk the car...but after doing some research, and getting a manual on the conversion, I decided to give it a whirl.
    I wasn't about to spend $3,200 for a new battery from Toyota!
    We converted the Hybrid battery with Gen I cells, to newer 2004 and 2006 cells (to have the necessary 38 cells required.) (2004 to 2009 have 28 cells)
    I've come to find out that the "manufactures" out there, that are converting Gen I batteries are also replacing the one side wiring loom as part of the rebuild. If you do one of these conversions, you would find out that this wiring loom with all the connectors, was also "glued" on with some sort of adhesive (as well as a stud/nut connection).
    When removing it, it also had corrosion, and a lot of the glue substance. Was pretty much impossible to get it cleaned up, with out breaking the very fragile connectors.....and we got an P3030 error code after re-installing... the first go around. (and RED triangle of death !)
    The P3030 you hear so often ( basically the code means there is a problem with the wiring loom that attaches to each of the 38 cells.)
    After getting the new wiring loom from Toyota, and installing it on the battery, and of course, putting the whole thing back into the car......it worked the first try !:cheer2:
    We're pretty happy it all worked out.
    I'm a rebuilder, and have rebuilt some other Prius's (not the battery but with body damage) Have a 2010 IV that has side damage that will be my driver. I already rebuilt a 2008 for the wife, and a 2004, 2006 and another 2008 that will be sold. (sold one a week ago)
    Princer likes this.
  14. JamesPartridge
    JamesPartridge Junior Member
    Rochester, NY
    2002 Prius
    I just got P3030 on my 2002 Prius. Wouldn't happen to have a couple of those sensing wires still laying around, would you, 3prongpaul? I bet I could even get away with simply feeding a piece of copper wire wire straight to the terminal on the module, no?
  15. 3prongpaul
    954
    723
    Yes, I have plenty but I recommend you take the battery apart first, if the bus bars are all corroded I recommend buying new ones from Toyota which include the sensing wiring and cleaning up your battery terminals. If you are trying to spend minimal money I can sell you used ones or you could simply use clean wire. Also check your battery ECU. In damp climates the ECU shorts out where the sensing wires plug into it.
    Raytheeagle likes this.
