Nervous about buying a Prius
Discussion in 'Newbie Forum' started by I95_Warrior, Dec 28, 2011.
  1. I95_Warrior
    I95_Warrior New Member
    Phila Metro
    Hey guys :)
    Forgive me if I post on the subject of this thread in a more technical part of the forum.
    6 months ago, my 14-year old Camry blew a transmission. Since then, I have been renting cars to keep my career as a regional sales agent.
    A week ago, I decided to rent a Prius from a local Toyota dealership. Not only is the car cool, but I spent about $40 on gas during a normal week where I would have spent $120. The difference is damned amazing.
    The first day I drove the car, I drove the car around town, playing with the different modes. Obviously, eco mode was the most economic. I kept the display just in the first square, as to get the best gas mileage. I was able to maintain over 70mpg.
    Unfortunately, east coast traffic the next day bumped that down to about 56, driving with traffic. I even screwed around to see how low I could get the MPG, and the least I can get is about 43MPG, going 85 on the expressway.
    Although the MPG rating on my previous rental was 30ish, I knew I was barely getting 18. Driving the same way with the Prius I was getting 55.
    I just can't believe that driving this thing aggressively and passing people would still dictate double the gas mileage of a 4-cylinder combustion. Driving like a grandma, I can get 70.
    WOW. I'm so happy.
    I averaged my old gas expenditures through bank records: $500 per month over the past year. This is still not accounting for what I paid in cash. (35-40k rough miles per year.)
    The past week (2 days of experimentation, 5 days of driving like a screwball,) I put in $7, then $15, then $20. $42. This is an additional trip to NY. I'm guessing $35 per week average, or about $150 per month with the Pruis. I'm sure I would do much better with synthetic oil and smaller tires.
    It just so happens that I am spending $600 per month renting cars to keep my career going.
    So, I can spend $2000 fixing my 14 year old car, $600 per month in gas, and maintaining my old car ($600/mo)
    or continue paying $600 in rental, $500 in gas ($1100/mo)
    To spending $400 financing a new Prius, and conservatively $200 in gas ($600/mo) but having a nice car.
    Sounds great - except for the fact that I am scared about maintenance driving so many miles.
    I'm familiar with how to extend the life of a combustion engine, but this thing has both a CVT AND a traction motor, AND a battery. I have no experience with either CVTs or Traction motors. I also am just starting out and have no savings.
    Is this a reasonable car for somebody who drives a car so much? Is there any hope to get 400k out of a 2011 Prius? I should be financially well off in a couple years, so I would just have to make it 2-3 years (100k) without major repairs.
    Doable?
    Thanks in advance.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I don't have the bandwidth right now to give you a full reply but see Lifespan/Operating costs - Prius Wiki, for starters. In particular, you might be interested in looking at the recent Priuses at Advanced Vehicle Testing Activity - Hybrid Electric Vehicles along w/2 fas 4 u's adventures on his 09 Prius, now past 451K miles.
    The "CVT" (power split device) in the Prius is mechanically simpler than an automatic transmission w/only a single planetary gearset and has no internal clutches, bands, tiny fluid passages, etc. You can a see a pic at http://priuschat.com/forums/gen-iii...nventional-auto-transmission.html#post1416075 and some I took at https://picasaweb.google.com/105684...authkey=Gv1sRgCILH8tvp-8_pjQE&feat=directlink.
    You can see a bunch of other transmissions I took pics of at two different Tokyo Motor Shows at:
    https://picasaweb.google.com/105684...authkey=Gv1sRgCJ3aqv3yvIb-zQE&feat=directlink and https://picasaweb.google.com/105684...authkey=Gv1sRgCLyZ2MT70fekggE&feat=directlink. Might be best to view them in full-screen mode.
    The Prius also has no timing belt, no alternator and no starter motor. 3rd gen Prius also has no "drive" belts and the brakes last forever due to regen.
    IMHO, 400K miles is w/o a major failure of some sort would be pressing your luck. It's possible but I wouldn't be surprised if you need a new HV battery somewhere past 150K miles. I don't know if your area is hilly but I don't consider the Philly area to be a hot climate (vs. say Arizona). I'd say the chances of an HV battery failure seems to increase if one lives in a hilly area that's also hot.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    A 2009 has been proven to go 450,000 and counting miles with modest maintenance and no major failures. Start looking for a lightly used 2009. Since 2010 was a redesign with a different motor and different HV battery cells with higher power factor, long term reliability has not been established for 10-12. What you give up in slightly less good MPG with an '09, you will recoup in terms of lower purchase price and potentially far fewer repairs.
    It's too bad you are in PA, I would make you an offer on the Camry.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  5. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I also live in the Philly area so I do much of the same driving as you - the Prius makes a whole lot of sense for you with the amount of driving that you do.
    I have an 09 (purchased in October 2008) with about 67k miles and I have done nothing more than the standard maintenance (oil changes, tire rotation etc) and a new set of tires.
    The only thing that I would say is that expecting any car to make it to 400k is a real stretch. That is pushing it to the extreme and I do not think that anyone would make that guarantee about any car. There are a few folks here that drive a Prius as a taxi and they seem to be getting high miles and they are likely far harder on their cars than you would be. However looking to make it past 100k without a major repair seems like a pretty reasonable expectation. You never know, but I think that you are as likley to do it in a Prius as you are in any car.
    That being said, Toyota has a well earned reputation for reliability and the Prius has proven itself over the past 10+ years as well. If I were you I would buy a Prius without a second thought. Treat it well and hopefully you will be able to take a run at 400k.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,814
    So. Texas
    See post #1 and then skip to last few pages of this long, on going thread:
    http://priuschat.com/forums/gen-ii-prius-main-forum/79235-299-999-mile-club.html
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    All the above replies are priceless, as is this forum! Buy a Prius and read the forum regularly. I now have 103,000 miles on my 2005 and have full confidence in the car. I just came back from Las Vegas yesterday. It helps to attune your thinking to thinking electrically and be conversant with such terms as voltage, current drain, load and most important! The 12 volt battery. I was in Electronics for many years so the transition was not difficult for me, but still had to think in terms of digital. Again the 12 Volt battery is probably our biggest problem post. The hybrid and the EV are definitely the wave of the future and will continue to attract for many years. Glad to hear that you are so overjoyed with the rental Prius. MPG is obviously the main reason people are buying but there is an added benefit, go to the rear of a Prius and try to smear some carbon off the tailpipie onto your finger. Absolutely clean! No carbon! No pollution. Buy a Prius and have fun. AND... buy a multimeter!
  8. fulltank
    fulltank New Member
    230
    Arkansas
    One thing that I've noticed with driving my new '11 is that my driving style has changed significantly (for the better). I have to believe that driving more 'conservatively' will yield a longer life span for any car. Regardless, that I now drive a Prius.
  9. HyperFX
    HyperFX NIMFY (not in my front yard)
    81
    35
    30
    New Jersey
    Owning a Prius is a surreal experience. The first time the engine shut off and i drove it away, I thought the car stalled on me. Lol. Whichever your decision, may you enjoy your ride.
  10. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    well the renting is the least economical, so the choice is really between either keeping old Camry or buying new Prius.
    Per fueleconomy.gov at 35K a year Camry gas is $4,915 and Prius is $2,261, or $221/mo. The 2,000 tranny fix cost is ~$42/mo spread over 4 years, if you Camry will last that long. $84/mo if it lasts 2 years. So basically $137/mo are buying your a new car.
    This is without maintenance costs as they will be lower on new car, for at least for 4-5 years while you are paying it off. @ 70K on 2 year old Prius, there weren't that many maintenance costs besides new tires and oil changes. Brakes will go at least 2-3 times of that before new pads are needed.
    A co-worker at work has a '06 Prius with 250K w/o any problems; expect mine to do at least as much. Of cause the traction battery cost and longevity is a question, but the battery can be rebuild, and Prius is main stream, there will be plenty recycled modules down the road if needed. Plus batteries are getting cheaper.
  11. qbee42
    3,079
    From a mechanical standpoint, the Prius doesn't have a CVT. It doesn't even have a transmission in the conventional sense where you can shift gears, automatically or manually. It has fixed gears.
    You won't find a mechanically simpler vehicle. Really the only worrisome thing about a Prius from a maintenance standpoint is that it contains some high-priced electronics. They are very, very reliable, but if one fails it can be expensive. On the other hand, this is also true with most other modern cars.
  12. richard schumacher
    7,664
    1,046
    United States
    Who the hell expects to get four hundred thousand miles from *any* car? But there's probably as good a chance of it with a Prius as with any other.
  13. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    If your rental Prius is 2010 or later and has been maintained by Toyota, it already is using synthetic oil. Also, unless it is a five with 17" wheels, it's already running 15" wheels with LRR tires.
    If you've found that the rental Prius has met your work needs (cargo, passengers, comfort, customer acceptance, etc.), I don't think you'll find a better vehicle for your needs. There are other more luxe rides and those with more cargo capacity, but if those aren't important or necessary to you, why bother. I think the other posters have done a good job explaining the mechanical aspects or the decision.
  14. bisco
    52,192
    how many miles did the camry go before the first major repair?
  15. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    It's an excellent car, but I'd avoid buying one until the "knocking on start up" issue has been resolved with a TSB, and you're sure the one you're getting doesn't have the problem.
  16. seilerts
    3,326
    1,519
    Santa Fe, NM
  17. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    I would do it. My 2010 has 30,000 miles on it and runs flawlessly giving a LMPG of 57. The eCVT as it is called is really a modified differential with 3 sources of energy driving it. No reliability problems there. The engines have been extremely reliable. The Hybrid battery packs suffers more from nonuse, than overuse which would seem to be your MO. Sounds to me like a good fit for you.
  18. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I'd go for the Prius. You have this website to anticipate, and if necessary solve virtually any problem. I am qualified to comment because I lived in South Jersey outside of Philly for 25-years. Well, it can be as hot and humid in the summer as Texas, right? But that's no matter, use your air cond to cool yourself and the HEV batts. You will improve air quality in South Jersey, too.
  19. I95_Warrior
    Phila Metro
    Nice.. Great info and links!
    Yeah, I'm a bit obsessive with maintenance, which should explain the 400k. I freak out if I can't find Royal Purple at an auto parts store.
    Thanks!
    Great.. Thanks! I feel like I'm actually driving a modern car.
    It has me driving much slower, too.
    Wow, great math there. Thanks!
  20. I95_Warrior
    Phila Metro
    That's what I've concluded as well. Thanks
    ME. I have high expectations from a Toyota, if it's maintained correctly from the start.
    I didn't know they used synthetic.. pretty cool.
    40k.
    Greath. Thanks
