Correct oil level for 2004 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jayman, Nov 22, 2005.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Richard:
    That's a serious error for Toyota to make: to confuse "dry" with "service" refill.
    As I do a lot of industrial process control work, I'm familiar with things like tank farm agitator gearboxes, paper machines, vibrating screens, centrifugal compressors, rotary screw compressors, etc.
    The manuals are usually careful in differentiating "dry" and "service" sump capacity. You're absolutely correct in that it's *impossible* to get out all the old oil from a sump. A small amount will cling to the interior surfaces, in oil galleries, the oil pump itself, etc.
    I was just surprised about the large difference in stated and actual sump capacity: 3.7 litres stated vs 3.35 litres actual.
    I don't think I'll bother with the 350ml in the future, just put in 3 litres and call it Good.
    jay
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    The NAPA filter looks almost exactly like the Toyota one, in fact.
    It's actually made by Wix, and had reasonably nice things said
    about it in the various oil-filter comparison surveys I found
    around the net. I've got the original Toyota one just about drained
    out by now, and will eventually cut it open for a looksee.
    _H*
  3. jayman
    13,439
    641
    Winnipeg Manitoba
  4. prev93
    prev93 Member
    63
    Califon, NJ
  5. markl_me
    markl_me New Member
    Portland, Maine
    What if the manual is correct (3.9 US qts is really the capacity) but the dipstick marks are slightly misplaced (eg too low on the stick)?
    Just trying to think outside the box...
    Mark
    Portland, Maine
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Mark:
    Sure. I'll buy that. Makes sense too, a whole bunch of dipsticks stamped out at a plant somewhere, and the press was set up wrong. It wouldn't take much of an error either.
    For the life of me, I have no way to determine what is the "real" oil fill level. At least the large industrial equipment has sight glass systems where you can visually check.
    jay
  7. richard schumacher
    7,686
    1,068
    United States
    Now that's a thought. Can someone here ask Toyota directly about this? Is the dipstick wrong, are the manuals wrong, or what?
  8. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Ok,
    I'm a little slow. You all lost me, with the quarts, liters, all different levels on the dipstick....
    What is the proper amount? So when I get my oil changed I say..."I want x.x Quarts in, not a drop more not a drop less"
    Thanks
  9. richard schumacher
    7,686
    1,068
    United States
    Assuming that the dipstick is correct and the error is in the service manual, then one right answer is "three quarts" (U.S. quarts, not Imperial quarts). If you are providing the oil in quart bottles that quantity has the added virtue of convenience (no partial bottle left over to fool with). More than 3.5 quarts risks overfilling.
  10. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    There is a TSB (Technical Service Bulletin) on this the fill is less than the Owners Manual. 3 to 3.5 is good.
  11. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    Wonder if the '06 Owner's Manual corrects this? Any '06 owners out there to check?
  12. 925PriusGuy
    925PriusGuy Winter Gray & Blizzard Pearl Pri
    148
    Northern California- SF East Bay
    I have an 05' and 3 quarts puts me right at the 3/4 mark....with the filter change.
  13. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Yes 06 owners please reply.
  14. rick57
    rick57 Member
    572
    Circleville, Ohio
    I just pulled up the specs from the '06 Owners Manual(from TIS site) and it looks like they didn't change it. 3.7 L, 3.9 qts, and 3.3 Imp. qts with filter change. At work I fill with 3.5 qts which put the level just under the Full mark.
  15. GreenMachine
    760
    Vermont, USA
    Thanks for taking the time to do that Rick.
  16. onerpm
    onerpm New Member
    477
    MN
    I changed my oil this weekend, it was about 20 degrees out and I got a little frozen trying to change the filter.
    The last time, 3.5 qts. took it to the top mark on the stick; this time, it took more like 3.7.
    rpm
  17. 200Volts
    200Volts Member
    439
    46
    Northern CA
    I've had my 04 oil changed 12 times. It has always taken 3.6 to 3.9 quarts (done at Tracy Toyota, excellent). They add the last half a quart about 100mls at a time (usually 3 or more adds to top it off exactly).
  18. jackson5
    jackson5 Junior Member
    san diego
  19. richard schumacher
    7,686
    1,068
    United States
    Curious. You have checked the level yourself, right?
