I've been a bad bad Prius boy--Tire Pressure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Dec 29, 2011.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    After returning from our travels in April things have been crazy busy. And, unfortunately, giving the appropriate TLC she deserves to my Prius has gotten pushed to the back burner.
    Well, finally, today (yest, 8 months + after getting back on US soil) I finally checked tire pressures as a few weeks ago I'd noticed that my tire wear was more than I would have expected.
    You know the rest of the story, the pressures were embarassingly low. Around 32psi rear and 30psi front. I juiced up to 50psi all around (it was about 60F today) and as penance replaced the 3 year old cabin air filter in my wife's Highlander Hybrid. Hopefully that and the fact that I recently replaced wiper blades on both of our vehicles will absolve me of my car care sins.
    Anyway, just a reminder to all...make time for your car, check those tires, esp. in this cooler winter weather, and make sure they're up to the pressure you prefer to keep them.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    .... go, and sin no more
  3. efusco
    19,891
    1,196
    Nixa, MO
    Thank you father....:hail:
  4. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    A small "pancake" compressor is not all that expensive. I suggest that you buy one for your garage and set your tire pressures every weekend. You would be surprised how fast they drop when using the elevated pressures recommended here on PriusChat.
  5. efusco
    19,891
    1,196
    Nixa, MO
    I use a combo tire pump, battery jumper, emergency lamp gizmo. I've been driving with my tires at 50psi for 5-6, or 7 years now and am usually pretty good about checking them monthly at least. But I got out of the habit when I was traveling for 10 months and have just been lazy about it.
    I'm pretty sure that one time or another when the car was getting an oil change or otherwise at a service dept. that someone "kindly" decided to lower the pressures to the manual recommended levels (34F/32R), and with the cooler weather they dropped to the levels above.
  6. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    You would have noticed that had you been religious about setting the pressures weekly or even bi-weekly.
  7. richard schumacher
    7,664
    1,046
    United States
    I mothballed my compressor and use an old bicycle pump instead. The quiet is nice.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I just check mine at the petrol station about every few weeks, I'm rarely down more than 2 or 3 PSI.
    On a camping trip recently I had to travel few miles but on very rough rutted dirty roads. I set the tires down to 22 PSI (is that some kind of record) and left them like that for the whole three days I was there. I only drove about 7 miles over that three days and only at about 25 MPH. It didn't seem to hurt anything.
  9. efusco
    19,891
    1,196
    Nixa, MO
    Well, the paramedics have recommended I stop doing that after having to come give me supplemental oxygen and picking me up off the garage floor one too many times when I tried that method!! :mod:
  10. efusco
    19,891
    1,196
    Nixa, MO
    Likewise, my tire pressures have always remained pretty stable other than temperature associated fluctuations or if I had a leak. There's probably some mild loss of pressure over extended times, but certainly nothing requiring checks more often than once a month or so--again, unless there's a dramatic temperature change.
    I think that was actually a contributing factor to my laziness, I knew the pressures usually stayed pretty stable so I kept telling myself it could wait...but I didn't plan on waiting 8 1/2 months!
  11. ursle
    ursle Gas miser
    1,049
    192
    NH
    Gosh, not to be a stick in the mud but...
    I never(of course I check them quarterly) have to make adjustments to my tire pressure when the tires are filled with Nitrogen, and in my Hybrid Highlander and Prius I just wash the in cabin air filter three or four times a year.
  12. NargilFenris
    NargilFenris Junior Member
    75
    Wherever Uncle Sam sends me
    I checked my tire pressure after reading that dealers lower them to give a smoother ride. Yup tier pressure all around was 30. After I get my car back today I am pumping those babies up.
  13. oldasdust
    oldasdust Member
    356
    47
    illinois
    It's the cat and mouse game with tire air pressure at the dealership. Everytime one of my cars goes in ,it comes out with factory tire pressure even when i tell them don't touch the tire pressure.My cross to bear i guess ,for going to the dealership. Foregive me father for i have sinned.
  14. efusco
    19,891
    1,196
    Nixa, MO
    I used to make a show of checking the pressure in front of the service guy, then asking to use their pump to top them back up...juvenile, yes, rewarding anyway--defiantely!:cheer2:
  15. danboy
    danboy Junior Member
    65
    brooklyn ny
    Why so low, what do you gain from 22PSI and can that help in snow?
  16. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I don't know about snow, being here in sunny So Cal. My son goes off road in his Jeep, and lowers the tires all the way around to make it easier getting over rocks, etc. Of course he has special valves that he can set with the desired pressure and an on-board compressor system to pump them back up for highway use.
    I like to check my tires every couple of weeks at cold pressure, so I have a portable tank in my garage, which I find quicker to use than a portable compressor. My daughter just bought her first Prius, and the next day we went out and bought her a tank and good quality pressure gauge.
    The problem with dealers never goes away. I'm thinking of putting green valve stem covers on next time, just temporarily. Maybe they'll think I have nitrogen in my tires and not just automatically lower the pressure.
  17. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Mostly for ride comfort on very corrugated dirt roads, but also for traction on some sandy tracks at the camp site.
    You have to be careful how low you go. Obviously the tubeless tires need the pressure to seal them to the rims, and you've got to be mindful of not bottoming out the tires. There's also slightly reduced ground clearance, so 22 PSI is about as low I'm prepared to go. And that's with keeping to a very reduced speed.
    The track is very corrugated and with hard tires you just bounce and vibrate like crazy. Large 4WD's will typically travel it at about 45 to 50 MPH, but it's an isolated location with very little traffic so it's not really a problem to go much slower. Only one vehicle passed me in the same direction while getting there and back. Like I said it's only about 4 miles (each way) of the rough road, so taking it real easy at about 20 to 25 MPH only adds about 10 minutes to the (3 hour overall) trip.
    I'm not sure about snow, but in sand there's a huge improvement in traction with using these very low tire pressures. After the rough road to get into the area, it's then some sandy tracks to get to the best camp sites (it's a coastal area). Here the low tire pressures can really help too.
    BTW. I pumped the tires back up to 40/38 as soon as I was back on the main road, and still averaged over 50 MPG for the overall trip. :)
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    In snow you either need to stay on top of the snow, pack it down solid, or push through it to pavement. You aren't going to stay on top of it with a passenger car on tires, so low pressure doesn't help and probably hurts.
    On dirt, gravel, rocks, etc you get better traction when the tire conforms to the surface, so the lowest pressure you can safely run is good.
    If your pressure is too high you will sink into sand and pieces of gravel will act like ball bearings if the tire can't encompass them a bit.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    I had the same problem a month ago. I was actually going to lower my pressure for a more comfortable ride and to my surprise it was already lower thanks to the cold weather. Pretty embarrassing. :)
  20. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Didn't you get the tire pressure warning light on the dash?
    Only time I got the warning light was when the dealership lowered the pressure for 'courtesy' after a tire rotation.
