My parking bulb disappeared
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jc562, Nov 16, 2011.
  1. jc562
    jc562 Junior Member
    27
    lb to sd CA
    So i was changing the parking bulb on my car with an led one and the bulb fell out on and into the headlight housing. i drove the car home and looked for the led bulb and it was gone. i dont see any hole it could of fell out off anyone have any idea where this bulb could of went?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I've had a parking light led bulb fall into the headlight housing once but I managed to fish it out using a paper clip with a loop of floss at one end. If you didn't have the hole plugged in, then it's possible that the loose bulb pinballed into the hole out somewhere in the engine area.
  3. jc562
    jc562 Junior Member
    27
    lb to sd CA
    That's what I was thinking but that hole is so small and all the way on top guess i will search the engine bay later on. I'm just glad it is out of the housing.
  4. Prius77479
    Prius77479 New Member
    Sugar land
    Hello, I was trying to d the same thing. Now my led build fell in to the head light housing. I can see it but how do I get it out? Help please
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Unless you can fish it out with something, you will probably have to dismount the unit and try to shake it out. Just a thought
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Straighten a paper clip and cover one end with some masking tape (to avoid it scratching the unit). Create a small loop on a floss (small enough to catch the LED) and simply wrap the rest of floss around the paper clip down its length. Bend the paper clip to conform to the area you're working in and fish it out into the hole.
