Throttle Body Cleaning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Critic, Dec 31, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    From the posts that I have read, this is a good service to do periodically because it supposedly gets gummed up more frequently on the Gen II.
    Does anyone have a DIY or some tips/advice they can provide for this service?
    Thanks.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Just do a search on google, there are many posts.
  3. The Critic
    3,193
    2,330
    CA
    Found it, thanks:
    TB cleaning
    As I thought, removing the entire air filter housing is the way to go. That would allow me to clean the throttle plate without disturbing the MAF sensor, if I am seeing this correctly.
    My memory of the 2g is starting to become rusty since I have not worked on one in a few months. :p
  4. The Critic
    3,193
    2,330
    CA
    Just did this service on a 08 with 52k last night. There was a light-to-moderate coating of black carbon over the entire throttle body. Used a costco mf rag, some screwdrivers and fingers, and cleaned it all up. Also did the engine air filter and drive belt at the same time.
  5. andyprius
    2,212
    188
    The physical method works, you can also give it a hit with MAF spray next time. :cheer2:
  6. bisco
    51,525
    is this caused by bad gas? my daughters 04 at 90,000 miles shows no signs of performance loss and we have never cleaned it.
  7. andyprius
    2,212
    188
    Re: Throttle Body Cleaningthink
    I think a light carbon or dust coating is normal and operation would be normal. It is good preventitive maintenance tho. Possibly if you drive in a highly industrialized and polluted environement this could be a real problem. Maybe we will hear from China, Mexico in this regard. :cheer2:
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Some throttle bodies get a lot dirtier than others, to be sure. Seems like many causes might be at play here; I for one have no idea what the common ones are.
    Just check once in a while. It takes all of a few seconds.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    It comes from the PCV.
  10. bisco
    51,525
    thanks guys, i'll pull off her air filtr and take a peek when it warms up.
