Navigation System: input address when driving?
Discussion in 'Prius v Main Forum' started by njrose, Jan 2, 2012.
  1. njrose
    njrose New Member
    New Jersey
    Is is possible to input address information on the navigation system of the Prius V Three when it is in motion, not in park? I heard that it is only possible when the car is in park. Thanks for your input.
  2. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Should be good using voice commands. Works great on our Gen III / IV
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yeah, you have to use the voice commands when the car is in motion. The screen gets locked out for most functions when the car is in motion.
    Koko and njrose like this.
  4. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Thankfully, almost got side swiped by a "texter" on the I 15. Then they just look at you like "whaaaat?" when you get their attention. Our kids are out on their own now but anyone with teenagers should be lobbying to ban cell phone use while driving.
    Manual input while driving for Nav or text is equal to drunk driving in most studies.
  5. easted
    easted Junior Member
    64
    Pillow PA.
    2018 Prius
    I am pretty sure the vee model 3 does not have voice command on the nav system, the vee 5 does have voice command on its nav.. No it is not possible to enter address info., unless the car motion is stopped.
  6. njrose
    njrose New Member
    New Jersey
    Glad you survived without getting hit by the texter. The other day I saw a driver on the phone run a red light. It looked like her daughter was sitting in the passenger seat as well. Yikes!
    I personally would not use the navigation while driving. However, I currently own a car with nav that allows address input while driving. It's convenient when on the road and my front seat passenger can input address info on the nav instead of pulling over and stopping the car to locate someplace like a restaurant, etc. But, if the voice commands work, it sounds like this would be a good alternative.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    On Gen 2's nav, you could use it if you were going either <3 mph or <=3 mph. You didn't need to be stopped. Gen 2's nav did have voice command so you could enter the address by voice. I've done it numerous times.
  8. njrose
    njrose New Member
    New Jersey
    Thanks. I'll test drive the car again to double check if the voice commands work on the vee 3. Toyota's website says that advance voice recognition is available on the vee 3 but I'm not sure if the commands can be used for navigation or perhaps just the phone.
  9. MBRGuru
    MBRGuru Member
    255
    26
    Yes, you can enter destinations by voice on both the Display Audio (v 3 system). You can press the talk switch and say destination and the full address, i.e. "Destination 1234 Street City, State". There are more commands too. You can say "More Commands" then I think "Navigation Commands" and it will list them for you. All can be used when driving.
  10. njrose
    njrose New Member
    New Jersey
    Excellent. Good to know...I'll test it out on my next test drive. Thanks.
  11. schinia
    schinia Member
    162
    25
    cape carteret,nc
    don't expect too much!
  12. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    Might be worth mentioning that you can enter saved destinations (favorites) while the car is moving. I have a v Three BTW.
  13. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    I'm eagerly waiting for Coastal to come out with a Lock Pick for the Prius V. I had the Ultimate Lockpick on on my 2010 Prius and It was great. One could input destination and more from the passenger seat of course. ;)
    TOYOTA LOCKPICKS
  14. easted
    64
    Pillow PA.
    2018 Prius
    I was mistaken in my previous post when I said I thought the vee mod 3 did not have voice recognition. It indeed does have it, and it is applicable to the bluetooth phone system and the nav. system. I spoke with a prius salesman today at the local dealer, and he verified this, and demonstrated the system on my vee 3.
    Koko likes this.
  15. njrose
    njrose New Member
    New Jersey
    That's good to know. Thanks for the update!
  16. gramps
    gramps Member
    198
    45
    Southeast Texas
    My 09 Prius has the voice activated Nav but if the city or address is not a somewhat common name the Nav gets "confused" and enters a city or street that isn't even close no matter how clear I pronounce the words. Seriously makes me want to scream some times. My cell phone voice Nav works better but that defeats the purpose of having a car with factory navigation and the safety issues.
  17. Chicago Josh
    Chicago Josh Junior Member
    Chicago
    If you have an iPhone and use Entune, you can search for an address in the Bing section of the Entune app on your phone. Then connect it to the Prius and load saved destinations into the nav unit. Then you should have the new address available.
    It's a couple of steps, and it's annoying to have to find a workaround like this, but if you have a passenger doing it it shouldn't be too bad.
  18. njrose
    njrose New Member
    New Jersey
    Thanks for your input. I feared this might be the case. I know that whenever I make calls to businesses with voice recognition options, the system doesn't always identify what i'm saying. At least I have the options to say operator or press 0 in these instances.
  19. njrose
    njrose New Member
    New Jersey
    Good to know. Thanks.
  20. Cactus Hybrid
    129
    46
    Same with a Droid :D
