block the radiator in winter, post a picture of what you use to block it.
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Dec 30, 2011.
  1. ski.dive
    ski.dive Active Member
    966
    245
    Hutchinson Island,FL. Mt. Snow,VT
    OK:
    Heading to Vermont next week, driving up from Florida.
    How do I block my radiator so the Prius warms up faster?
    What do I use and where do I place the block,[CARDBOARD??].
    ***Post pictures of what you use to radiator block?
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    search? there are many threads on this.
    you can use foam pipe wrap from Lowes/Home Depot; ~50-60% of lower grill is all you'd need
  3. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    its actually alot easier to stuff the foam in the upper grill area but it seems almost useless ( I did my upper grill 2 weeks ago)
  4. bisco
    52,319
    i did as much of both grilles as possible last year with the foam pipe insulation and didn't notice a difference, but my commute is only 7 miles one way.
  5. Mendel Leisk
    41,844
    I'm using 3/4" diameter foam insulation. The "3/4" is the nominal pipe diameter, the foam is something like 1.5" OD. The tubes have a longitudinal slit which you can push over the grill blades. Some people secure it with zip ties. I use strips of velcro tape: easier to install/remove, and reusable.
    In mild winter weather I block 50% of the lower grill (one piece). If the temp's staying consistantly below 5C, then I'll block 100%. I leave the upper grill open, since there's a radiator behind there for the transaxle coolant.
    I also put short section of the same foam tubes on the crimped edges of the engine bay, along the sides above the fenders. Leave this in year 'round. It just holds heat in the engine bay better.
    ydpplqbd likes this.
  6. danboy
    danboy Junior Member
    65
    brooklyn ny
    I also put short section of the same foam tubes on the crimped edges of the engine bay, along the sides above the fenders. Leave this in year 'round. It just holds heat in the engine bay better.[/QUOTE]
    Do you have pics, if so please post for us to view.
