  1. WellesleyToyota
    WellesleyToyota New Member
    wellesley ma
    Anyone planning to do anything out of the ordinary on their new Prius V? Id love to get a picture thread going!
  2. pvogel
    pvogel '05 Five & '12 v
    87
    25
    Santa Clara, CA
    I plan to add a trailer hitch for a bike rack as soon as someone has one they indicate fits the v.
  3. rubdr
    rubdr New Member
    midwest US
    Bought a hitch from juiced hybrid . Fits perfectly on the v three I have. Took 1/2hr to install. Hope this helps!:)
  4. bronwyn
    bronwyn New Member
    Portlalnd
    Which bike rack are you doing to carry. I'd like to get a yakima hold up, but can't done anything yet. (Just took delivery yesterday!)
    Anyone thought about roof racks? I'm not crazy about the clips but I'm less keen having holes drilled into my roof. The one thing I am missing about my subaru outback is the factory roof rack.
  5. rubdr
    rubdr New Member
    midwest US
    The hitch from juiced hybrid is a class I hitch. You could place a bike rack into it without any problems. I use a small cargo carrier and also have a small utility trailer that works fine too! Best of luck!
  6. Dlbewley
    Dlbewley Junior Member
    CA
    I have a Sportsworks / Thule rack which requires a 2" receiver. I can't seem to find one yet. Is there areason for that? Other than you shouldnt haul a giant boat with the Prius.
    Would my warranty be affected if I installed a 2" instead of 1.25"?
    I guess I may have to sell my rack and rebuy.
  7. bisco
    49,492
    i'm thinking of modding my kingpin clusters. anyone else tried shimming the lower escalators?
  8. russcarver
    russcarver Junior Member
    91
    Erie, CO
    You can always buy an adapter to convert from one to the other.
    --Russ
  9. 2prius
    2prius New Member
    dc
    Well, I would not recommend Juiced Hybrid just yet. I put my order more than 2 weeks ago when I saw this post and saw it is "in stock" on their website. I called them after one week my order not been updated, I was then told it is under"testing" and will be ready to ship in a week. I waited another week and called, the story became this hitch is under "production" and will take at least one more week before they can ship it out. Worse thing is when I wanted to cancel it, I was told the person dealing with cancel is not available, and the person answered my call is unwilling to pass on my very simple request for refund. So after more than 2 and half weeks, the item is not there, and I may have to call my bank to get my money back. Very disappointed. So would not recommend.
  10. priusvgator
    priusvgator New Member
    47
    Space Coast, FL
    I am also looking for a roof rack for my surf boards. Haven't found anything great yet.
  11. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    I just installed a NEW set of horns from PIAA, bought from Amazon. The package includes TWO horns..one 500HZ the other 600HZ, and two ground wires. Each horn has two male plugs and factory attached brackets.
    I don't like my stock horn at all. The new horn(s) have a nice European sound to it (like a Ferrari) and MUCH more audible! Installation took only half an hour. with no crimping or cutting of any wires!
    Here is how I did it..
    First open the hood, take off the plastic cover around the hood latch, used a 11mm wrench to take off the old horn bracket (Prius has two horns, one on each side).
    I detached the stock wire bundle that is clamped to a plate in front of the radiator (to have more slack to work with). I then remove the single female wire plug that is attached to each horn.
    I then plugged the stock wire plug from the old horns into the new horn's plug (It fits perfectly). I attached the supplied ground wire to the horn's other male plug and the other end to the previously mentioned bolt (Gound). I then finished up by attaching the new horns into the same existing hole/location as the old ones using the same 11mm bolt.
    Lastly, I zip-tied the wire bundle securely and replaced the plastic cover and honked my new horn(s). ;)
    http://www.amazon.com/gp/product/B00079V5ZI/ref=oh_o00_s00_i00_details
    david zaret, DaveShep and Osteoblast like this.
  12. shrktank
    shrktank New Member
    56
    Imperial,Mo
    Would you mind sharing with me how you install the rack? I would love to get one for my 2012 Prius, but I tend to lack skills.
    Does the Prius already have holes to use to mount the hitching system?
  13. TruSound
    TruSound Member
    246
    32
    The 818
    1st mod: the day I got it...medium grey window tint all the way around.
    2nd mod: This one is a huge improvement on the dim yellow interior lighting, I installed super bright LED's...both map, dome, cargo area and lower front door, MUCH BETTER !
    Complete plug and play set was around 50 bucks...Here's the link
    http://store.ijdmtoy.com/
    3rd mod: Like Cactus, I upgraded the wimpy OEM horns, I used the Fiamm Freeway Blasters purchased from Pep Boys, one high pitch and one low. Installation is super easy and took about 15 minutes, I used the stock mounting brackets. The improvement over stock is huge, a 40 dollar mod well worth it.
    4th mod: OEM wheel center caps, you'll need them when and if you remove the plastic Frisbee wheel covers.
    Here's the part # for a 2012 v Three.
    42603-52110... $ 60.90 out the door at my local dealer.
    Future mod...Motegi Racing 17" black wheels MR121
    Have a look...
    http://www.tirerack.com/wheels/Whee...lse&filterNew=All&filterWeight=All&sort=Brand
  14. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Holy crap, those are bright... Got pictures of how it looks all around with your car? I might just entertain the idea of modifying my car's lights a little.
  15. Cactus Hybrid
    129
    46
    thanks for the tip! I just got a set of LED's for my interior also..http://store.ijdmtoy.com/Toyota-Prius-SMD-LED-Car-Interior-Lights-p/pkg_toyota_smd_21.htm
  16. mattheikkila
    mattheikkila New Member
    84
    24
    concord, california
    Is anyone selling a gun turret for the V yet?
  17. bisco
    49,492
    how is the picture gallery coming along?
  18. jas1178
    jas1178 Junior Member
    44
    St. Petersburg, FL
  19. Cactus Hybrid
    129
    46
    Very easy took 20 minutes for the kit..just remove and replace. The rear cargo area was the most difficult because I couldn't figure out how to pop light housing out..
    I finally figured it out...Using a small flat-head driver, you have to pry it out from the right side as you pull out the housing.
  20. Osteoblast
    Osteoblast Junior Member
    55
    NC
    I thought swapping out the horn was a triumph of technology over reason until I actually pushed it and realized it sounded like a shriner clown car! Followed your lead and did the same and what a difference! I may try the semi-truck air horn this summer as I think that would be pretty funny!
    The LED upgrade was an awesome idea as well!! Did that this weekend and it is amazing how well lit the cargo area is now.
    My next project is that sissy gearshift and somehow upgrading those amber footwell lights to blue.
    Ideas?
    Thanks Cactus!
