2012 Prius v Groaning Noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AnnieS, Jan 5, 2012.
  1. AnnieS
    AnnieS Junior Member
    Seattle, WA
    Below about 40 degrees our 2012 Prius v groans when it first moves in the morning, as if there's a break problem, but we're not using the break. It goes away very quickly. Does anyone have the same problem?
  2. Flyman
    Flyman Junior Member
    64
    Packwood, Washington
    :) We live South of you in Packwood and we are having the same symptoms, it sounds like something hanging up or scraping as it rotates. I plan on asking about it when the first service is due unless it gets worse prior to that. The temperatures were in the 30's here for a couple of weeks but are now running from 43 to 50.
    We have had the car since Halloween and it has a little over 1500 miles on it.
  3. MarathonMarty
    MarathonMarty Prii 4-timer
    Spokane, WA
    2013 Prius v wagon
    Very interesting. I live in Spokane and have owned my 'v' since early November. I also encountered the 'groan' when the temps dropped below 40, especially when it was also damp. I have taken the vehicle in to the dealer but, alas, the weather warmed up that day so when they test drove it there was no groan. I've also noticed that the 'groan' is rotational in nature ie. it isn't a steady continuous noise but is intermittent as you drive forward. Never has happened in reverse and usually stops within less than one city block, maximum. No brake pedal being applied during the groan and I agree it sounds like something rubbing for a short period of time before releasing or breaking loose. This evening it was 38 and very dry when I drove home after work. No 'groan' at all so I think moisture is also one of the ingredients. And we're all residents of Washington and we all bought our vehicles within the same time period. I'd be willing to bet they came over in the same shipment and that they were in the same production run. I'm not really worried about it but none-the-less, I think we should keep an eye on this.
  4. tonycan
    tonycan New Member
    Vancouver, WA
    I've experienced the same problem. Took it into the dealer and they called in a field engineer. Did some work on the brakes, but the same noise continues. Car is scheduled to go back to dealer for the second time. Very annoying sound.
    Just noticed every poster is from Washington state. Hmmmm.....
  5. thomcat
    thomcat Junior Member
    Ballard, WA
    Add mine to the pile - same groan, gone after a few blocks. Haven't had my first free checkup yet, so I can ask later this month.
  6. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    AnnieS, Flyman Member, MarathonMarty, Tonycan & Thomcat – Load up your Vees and move from Washington to Florida. There are no groaning 2012 Prius v hybrids here in Margaritaville.
  7. tonycan
    tonycan New Member
    Vancouver, WA
    Now I'm groaning!
  8. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    I hear it once in a while when I start up the car. It seems like when I turn a corner I thought it was a brake noise. Maybe it's from the steering I hear the sound when I turn every once in a while.
  9. Priuswagon
    112
    Kingston Washington
    My prius has 2700 miles on it and that sound comes and goes. I notice it when I turn after I turn the car on.
  10. Wuster
    Wuster New Member
    17
    VA
    Ahhh... Isn't that like 10 months out of the year in Spokane? :)
    My wife's family is in Spokane, and when we visited in 2010, the high that week was like -4...
    All kidding aside, could the "groan" be the Vehicle Proximity Notification System? It makes a grinding like noise at low speed (below 15 mph, I think) to let pedestrians know, so you can't sneak up on them.
  11. dustmonkey
    dustmonkey New Member
    michigan
    Same exact sound/issue with my 2012 PV5; wasn't too happy with the service techs response when I noted the brake-dragging sound - he said this: "Is this your first Toyota?" Indicating 1. I didn't know what I'm talking about, and 2. That this is going to be a one-way relationship, where he tells me, not me telling him. Not a good start with service.
    But to the noise: it definitely sounds like brakes dragging. I finally got a straight answer which still didn't satisfy: "The brakes are new," and/or "when brakes sit they collect rust and they're going to make that noise," which does make sense for long-term parking, but my Prius V will generate the brake noise after stopping at a light.
    Not real happy with how Toyota is being coy with this issue; it's like they're trying to find a fix while keeping customers at bay with vague answers.
  12. DragonflyDM
    DragonflyDM Junior Member
    53
    Pittsburgh
    Mine does it too.. But i thought it sounded more like a break squeek... It goes away once the wheel warm uo.
  13. dustmonkey
    michigan
    Yes, but has Toyota ever given you a satisfactory answer as to why. I'm sorry, but you shouldn't hear brakes like that. I can't recall hearing whining brakes on any used car I've purchased, much less a brand new one. And everyone seems to have the same experience but no one seems to be getting a serious answer except that it's characteristic of the vehicle.
    If that's the case, then something is wrong and Toyota needs to step up and satisfy their very loyal Prius customers with a reasonable answer.
    FWIW, I love my Prius V5 and would get another one tomorrow, as I would encourage anyone to consider a Prius. But that doesn't mean I'm going to accept anything less than the quality that has brought the Prius this far.
  14. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I thought it might be the emergency brake not releasing entirely, until I read all the posts more closely. Curious.
  15. MarathonMarty
    Spokane, WA
    2013 Prius v wagon
    No, it definitely isn't the proximity alert. This is far louder than that. You actually can't hear the proximity alert from inside the vehicle. This is my third Prius and I am very familiar with the infamous brake squeek upon first driving after a cool damp night. Had a lot of that with my '10. I actually have had very little of that with my 'v'. I'm thinking the 'groan' is either in the brakes somewhere, the steering, or the front drive. Almost sounds like a bearing that's dry and gets some lubricant as you first start to move. I'm open to suggestions. Otherwise I absolutely love my 'v'.
  16. Priuswagon
    112
    Kingston Washington
    Yesterday when I started the v my husband heard the sound he says it's the parking brake sticking? Hope I am remembering this right but he was sure it was the parking brake. I haven't taken it to the dealership I am hoping the brakes will break in and the sound will go away.
  17. monkey28
    monkey28 Junior Member
    31
    Toronto
    Same thing happened to mine, I just wait, may be it will come up a bulletin in future.
  18. MarathonMarty
    Spokane, WA
    2013 Prius v wagon
    It is not the parking brake in my case. I don't use the parking brake as a general rule. Only do if I'm parking on a non-flat surface. Waiting for warmer weather so the groan goes away.
  19. tonycan
    tonycan New Member
    Vancouver, WA
    I guess the larger question is, "Are we going to have to live with this groan?" I like the v a lot, but I'm not going to live with a groan beyond the third trip to the dealer--especially without good communication from Toyota.
  20. dustmonkey
    michigan
    Exactly right.
