2002 misfire after warm start
Discussion in 'Generation 1 Prius Discussion' started by spreacker, Sep 4, 2011.
  1. spreacker
    spreacker New Member
    Indianapolis
    2002 Prius
    I
    I am hoping someone has an answer to my issue. I have searched this site and many others for 3 weeks and although I am sure that my Prius is in better condition than when I started, the following condition remains a mystery.
    When I start my Prius after it has been setting overnight or for a few hours after driving it runs without issue. If I drive it long enough for it to warm up, when I try to start it within the first few minutes to an hour it starts knocking and at times the check engine light comes on. I can drive it and after about 5 minutes of running rough it smooths out and runs normal.
    I have checked the engine codes and I get P0300 (random misfire), along with misfire codes on cylinders 1,2,and3. Never cylinder 4 for some reason.
    Here is what I have tried.
    Cleaned the mass air flow sensor.
    Cleaned the trottle body
    Swapped coil pack 2 and 3 (after several cylinder 3 codes without other misfires)
    Ran the tank empty and filled with a fresh tank
    Took the car to the dealer where they had it for 3 days and checked all systems including cylinder pressure, fuel pressure and diagnostics.
    Dealer found a leaking o-ring on cylinder 1 and replaced all of the o-rings.
    Got it back and can still reproduce the problem.
    I took the 12v battery out and had the dealer test it and they said it was fine.
    I had changed the oil using 5w-20 full synthetic and filled it to the specified level. After reading a post on this site I took a little oil from the engine and cleaned out some oil from the intake manifold.
    Reall thought I had it only to find that I could still reproduce the issue. This is my 16 year od daughters car and I really don't want to have her stranded at any time.
    BTW, outside temp has been in the 90's although I had it happen today and it is only 80 outside.
    Hopefully you are still reading. :). I know this is a long first post but I am hoping the detail will help.
    Thanks in advance
  2. Patrick Wong
    18,210
    6,513
    1. Odometer reading?
    2. When were the iridium spark plugs replaced? (Service interval is 60K miles on Classic.)
    3. Since cyl 4 is not misfiring, if you are going to swap igniters it would seem more useful to swap the igniter from cyl 4 into one of the cylinders that is misfiring.
    4. What is the physical condition of the spark igniters? Any cracks, burn marks, or rust on the plastic body? What do the electrical wiring harness terminals look like? If you note any flaws then the igniter should be discarded.
    5. What O-ring are you referring to, is this the one that seals the igniter to the engine valve cover?
    6. Do you find that the rough running coincides with weather conditions, for example after heavy rain?
    7. What was the pressure in the fuel system?
    8. What was the dealer tech's diagnosis regarding the cause of the engine misfiring? Was that blamed on the O-ring?
  3. spreacker
    Indianapolis
    2002 Prius
    I
    Thanks for the questions and suggestions, here are my answers
    1. 140,000 miles,
    2. Changed them last summer at 130,000 miles using plugs from Toyota dealer.
    3. Good idea, funny I read post to my wife and she said the same thing. :) I will swap 1 and 4 igniters to see if it changes the pattern.
    4. No visible cracks or burn marks, and i have not noticed any bad wires but i will inspect closely tomorrow.
    5. O-rings that seal the injectors.
    6. Has not rained in Indy all summer ;)
    It does appear to be heat related. My daughter just got home and stopped eat, then to a friends before coming home. No more than 1.5 hour stops and she said everything worked fine. It is about 70 degrees.
    7. I do not know the pressure. What should it be? I will ask the dealer. They only said it was OK.
    8. dealer assumed the o-ring replacement would fix the issue.
    Many thanks,
  4. Patrick Wong
    18,210
    6,513
    7. 43 psi or more at idle speed.
    Since you say that you hear engine knocking, not only do you have a misfire (based upon the P030x codes) but it sounds like you have a retarded ignition timing issue. I am wondering whether the engine ECU might have an intermittent connection within, provoked by high ambient heat.
    If you don't find any obvious problems and have reached the point where you wish to "throw parts" at the problem, you may consider replacing the spark igniters (maybe start with one new igniter and see if that eliminates misfire at that cylinder) and if necessary, replace the engine ECU with a salvage unit. Good luck.
  5. spreacker
    Indianapolis
    2002 Prius
    I
    Patrick,
    Thanks for the advise. It looks like I can get a salvage ECU on eBay or amazon for around $200. Does that seem correct? Also, I have seen posts talking about having to replace the keys by swapping the computer. Is this correct?
    Your logic seems sound given that the A/C is not working in the car and the ECU is located behind the glove box making it hotter in the car.
    Of course it is only reaching a high of 70 degrees now so I may not see this happen again until next year.
    Thanks again
  6. Patrick Wong
    18,210
    6,513
    $200 sounds good. Look for a unit with a part number of 89661-47054 which is the last revision of that ECU. Do not install a unit with a lower part number.
    If you replace the engine ECU, you don't have to worry about keys or other security issues. That would become an issue if you replaced the hybrid vehicle ECU.
    If possible, the AC should be repaired as that will improve your daughter's driving comfort which may enable her to drive more safely. This will also prolong traction battery life via better control of battery temperature in hot ambient temps.
  7. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    Aha! Same issue.
    Misfires sometimes when cold but more when restarted. Sometimes does it even when restarting engine after ev event.
    CEL light on sometimes.
    Plugs fine.
    There was some evidence of spark jumping on the boots. I will try using some dielectric grease on them and report back. It does seem to be worse when the weather is moist.
    No codes retrieved yet as I don't have a scanner.
    spreacker. Did the new ecu fix the problem?
  8. Newbyowner
    Newbyowner Junior Member
    Webster Florida
    2003 Prius
    I
    Hi all not sure if you still have this problem as it has been a while since the post but my 2003 Prius was doing exactly the same thing. I was told by the dealership $3000 to begin fix & it might go up after they got into it. I decided that that was way out of proportion & was going to just start changing sensors till I located the problem. I had already done all the things mentioned by the OP with no results. Changed the crank position sensor & the knock was gone but the MIL still would not go out & the mileage got really bad. Read the code again & it was only coding for the knock sensor (was not doing this prior to the crankshaftsensor change). Bought a new knock sensor & when everything was taken apart to replace found that the wire to the knock sensor had broken loose. Replaced sensor & repaired wire & all is well again. So anyone having this problem check the crankshaft position sensor. I'm sure most of you have the equipment to check this rather than what we did with the random changing. Good Luck all!!
  9. spreacker
    Indianapolis
    2002 Prius
    I
    Ok, Spring is here in Indiana so the heat is starting to rise. I just changed the oil and the misfire kicked in right away. It would do it some over the winter but the cold weather seams to help so I thought I would put it off. I just looked at my old post and found a few comments. I did not swap the ECU since it was an expensive guess. I am going to look at the post after yours closer to see if the crank shaft sensor could be the issue.
    Any luck with yours?
  10. spreacker
    Indianapolis
    2002 Prius
    I
    Thanks! I will look into it. I got a fancy ohm meter for Christmas and thought that may help me find a failing sensor. I will check the crank shaft wiring.
    Did your issue occur more in warm weather and on a restart after stopping for 10-15 minutes?
    Thanks again
  11. spreacker
    Indianapolis
    2002 Prius
    I
    Update, I replaced the crank position sensor this evening. Took the car for a test drive, stopped for about 15 minutes. When I restated the issue was still there. So, at least I can take crank shaft position sensor off of the list. I looked at the replacement for the knock sensor and my auto manual said something about removing the intake. Seems like more than an evening job. The only codes I ever get are random misfires and misfires on cylinder 1, 2 or 3. Still seems odd that I have never seen a misfire on cylinder 4. Maybe I look into the ECU. Seems like not much money and easy to swap.
    If anyone has ideas I am all ears.....I will keep you updated on my progress.
  12. spreacker
    Indianapolis
    2002 Prius
    I
    OK. Replaced the Crankshaft position sensor and it did not change anything. Today the new ECU came in. Very easy to replace and at $195 it was almost the same price as a knock sensor. That was the good news.....bad news..it did not fix a thing. Same issue as it knocks and runs very poor after a warm start. It is always fine on a cool start and runs fine even after it is running warm. I unhooked the knock sensor and tried to start warm, same issue, I unhooked the MAF sensor and tried to warm start, same issue. I pulled a vacuum line (thinking old school vacuum lock), same issue. At a loss. Next item would be Camshaft position but I am not sure if it has anything to do with things. I have never seen a engine code other than "random misfire" and misfires on cylinders 1,2 and 3. Never 4... Swap of coil pack between 3 and 4 did not change this fact so I feel the coil packs are good.
    If anyone has an idea I would appreciate the help. So far I am only into the fix for $255 so I am willing to keep going.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    Hi spreacker,
    Sorry you're having this problem. Here's my theory:
    I think the engine coolant temp sensor (also called thermistor) is bad (or associated wiring/connections are bad). It seems open (which would cause high resistance (normal at cool engine). The way the thermistor works is it is a variable resistor controlled by heat. When its cold, the resistance is high. As it warms up, the resistance drops. If you have an open or unresponsive sensor, the resistance remains high. The ECU thinks the engine is cold and adjusts the fuel mixture and other things appropriately (causing engine knock when warm). This would (in my theory) cause the symptoms you mention and probably not throw codes. This also makes sense that you only see it when outside temps are high. Electronics operate better in cold temps and failed components are sometimes only evidenced in hot temps.
    Here's a diagram of the circuit
    And here's a pic of the ECM and where pins 19 and 28 are located
    Here's a link to locate it (this is for a Gen II but its probably similiar for Gen I but, don't quote me on that).
    http://priuschat.com/forums/gen-ii-...448-coolant-temperature-hack-better-mpgs.html
    The best way to check this is with a Scangauge (see if the engine temp changes while the car warms up if no change or little change, that's your problem), if no Scangauge, you can either locate the thermistor (sorry but I don't know the location) and unplug it and monitor the resistance as the engine warms up (it should vary between 156kohms and 79 ohms) (this may cause some warning lights to come on but, I'm not sure) or, you can monitor the voltage changes on the thermistor while the engine is warming up (set meter on DC to measure 5 volts and hook leads up to pins 19 and 28 of the ECM). PS: Don't measure the resistance on the thermistor when power is applied (you could damage your meter). If you want to measure resistance, power must be cut off.
    Here's about what you should see (sorry about the celcius scale but, that's all I could find):
    VOLT __ degree C
    4.09 __ 0
    3.64 __ 5
    3.22 __10
    2.78 __15
    2.46 __20
    2.18 __25
    1.88 __30
    1.67 __35
    1.48 __40
    1.31 __45
    1.15 __50
    1.01 __55
    0.88 __60
    0.77 __65
    0.68 __70
    0.60 __75
    0.53 __80
    0.47 __85
    0.41 __90
    0.36 __95
    0.32 __100
    That's my best guess on this one. If that's not it, I don't have any other ideas (sorry :confused:). Hope this solves your problem. Keep us updated.
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    Any status update on this problem?
  15. orange4boy
    orange4boy Member
    235
    46
    Vancouver BC
    2003 Prius
    I fixed my issue which sounds the same as yours. It turned out to be a bad Ignitor. ($55 aftermarket) I found the bad one by lossening all the bolts and lifting each one out about an inch. I could hear the sparks on all the good ones but silence on the bad one. If yours is just intermittent then pulling the bad one will not change the RPM but pulling the good ones will lower it.
    Mine was intermittent for six months which caused missing then just died which caused a lot of vibration when accelerating.
    I'll bet this is your problem. Exactly the same symptoms. Worse after warm start and EV events. Random misfires reported on all but #4. Swapping the ignitors will not find the problem, just move it around. You may have to buy one new ignitor and swap it for each existing ignitor in turn to find the bad one but that just takes a bit of fiddling.
  16. spreacker
    Indianapolis
    2002 Prius
    I
    usnavystgc,
    Thanks for the detailed post. I wish I would have checked it a couple of days ago as I just replaced the cam sensor which is about 2 inches way from the thermal sensor.. :). I have now swapped the ECU, crank sensor, knock sensor, MAF sensor, and cam sensor. The car still does the exact same thing. major fail on my part at this point.
    I will look into the thermal sensor next. I will bet that is it since it looks like a $20 part and so far I have spent about $400 on parts. :)
    Any tricks to removing the inverter coolant tank? I replace the cam sensor by moving the wiring harness to the side since that was easier than taking out the bottom rear bolt on the tank. Looks like the thermal sensor will require the removal of the tank. My hands are just too big. :)
    I also saw the other post on the coil pack. I may try that although my issue never happens while the engine is running normally. Only after sitting for 15-20 minutes and restarting. If I let it cool all of the way down it runs fine which would point more to your theory. I may try both as I am just about to loose my mind at this point.
    Again, may thanks for all of the posts and assistance.
    Will keep everyone posted.
  17. spreacker
    Indianapolis
    2002 Prius
    I
    So, it appears that the Gen I and Gen II ECU wiring is different. I believe I have found a wiring diagram for a 2003 that should match. I will dig through the book to find the thermo wiring so I can test from the ECU side. It is impossible to get to the thermo without getting to the point that I could just replace it.
    One other thing, If I understand correctly your theory is that the data being provided to the ECU is that the engine is not warm when in fact it is and that is what is causing the issue. If that is correct. How is it that the Hack posted fools the ECU into thinking the opposite i.e. warm when not but there is no issue with rough running?
    I long for the day's of distributer caps and setting points.... :)
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    When the hack fools it into thinking the opposite, it only affects how often the engine starts for emissions purposes and not for how it "actually" runs. If you read the hack posts, you will find that the engine needs to be warmed up a bit to run right and if it fools it too early, the engine will indeed run rough (just like yours). Almost all who tried the hack could not get the engine to run right by hacking from startup. Once above 40 deg C, the difference is negligible and the engine runs fine. In your case the ECU (in theory) thinks the engine is always cold and therefore sets up a rich fuel mixture (causing rough idle when the engine is actually warm). The ECU will monitor other sensors (O2 etc) and eventually adjust the mixture accordingly causing the engine to run smooth.
    What is the reason you need to remove the inverter coolant tank? The thermistor you need to locate is for engine coolant temp and not inverter coolant temp.
  19. spreacker
    Indianapolis
    2002 Prius
    I
    Thanks for the clarification. That makes perfect since. As for the inverter tank. The engineers at Toyota obviously will never have to work on one of their designs. The gas engine thermistor is directly below the inverter coolant tank on the 2002 Prius. There is no way to get to the thermistor without removing it and it appears nearly impossible to remove the lower rear bolt on the tank without removing one of the two motors. :)
    I will do some metering prior to replacing.
    Thanks again and I will keep posting my results.
  20. ChapmanF
    18,550
    If you remove the tank you'll probably have to refill and bleed the inverter/transaxle coolant (tedious). Somewhere, someone (probably hobbit) posted photos of how simply moving the whole inverter (all hoses attached) gave enough access to get to something (though I don't remember what), and no refilling.
    Something to think about.
    -Chap
