GenIII Prius Custom PIDs for Torque app
Discussion in 'OBDII Android App' started by usbseawolf2000, Oct 7, 2011.
  1. comatoes
    comatoes #GreenLife
    288
    17
    Also, do the custom PIDs work for Gen II?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    For Gen II, please see this thread.
  3. comatoes
    comatoes #GreenLife
    288
    17
    Nice! Thanks, but how do you install the custom PIDs?
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Copy the CSV file in the micro SD card. Torque App can import them. Detail instructions are in the first post.
  5. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    bonjour,
    in the document attached in the first post, there is a small error regarding
    High voltage before it is boosted BV+
    High voltage after it is boosted BVB
    the results are not usable.
    formulas should be:
    (256 * F + G) / 2 instead of (256 * E + F) / 2
    and
    (256 * H + I) / 2 instead of (256 * G + H) / 2
    I will try tomorrow to correct:
    HV battery discharge control
    and
    HV battery charge control
  6. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Does the Torque free support importing of PIDs? I see /.torque dir, but there is not extendedpids directory. I tried to create one, but the stored prius CSV is not available in the menu. Isn't the dir name case sensitive?
  7. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    @paja - I don't think the free version support importing. You may be able to manually add one by one through the interface.
    @frenchie - Were you able to confirm?
  8. Capecoder
    Capecoder New Member
    massachusetts
    Where is the odbII connector located?
    Is there and iPad app similar to torque?
  9. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Thanks frenchie for spotting the error!:)
    Have you found the correct HV battery discharge control and HV battery charge control?
    Vincent
  10. frenchie
    frenchie Member
    150
    48
    bonjour
    regarding charge/discharge control,
    unit are kW (as in TS)...
    formulas I am testing :
    C/2 -64
    D/2 -64
    but as I don't have yet any equipment to compare with the real values, this is more a guess than a certitude.
  11. vincent1449p
    894
    332
    Singapore
    Both your formulas agree with the Repair Manual:
    Min.: -64 kW, Max.: 63.5 kW
    I did not use Adrian's formulas because they are different from RM:
    C/2 - 20.1
    D/2 - 108.1
    I suspect the actual PIDs are for WIN & WOUT, but it is only my guess. Could you list the values for those 4 PIDs using TS here? Perhaps someone with Torque or ScangaugeII be able to compare against your values?
    Vincent
  12. frenchie
    frenchie Member
    150
    48
    Bonjour,
    at this time, I have no access to TS, and as I lost most of the logs I prepared one year ago, I am not in a position to check.
  13. motoleon
    motoleon Junior Member
    48
    spain
    i have a few questions.
    In your torque file battery temps names are different that in google-excel from priuschat, why? what is the correct names?
    Traction Battery Temp,"BtT","2187","9 / 5 * A - 58","-58","402.6","F","7E2"
    Temp of Batt TB1,"BT1","2187","9 / 5 * C - 58","-58","402.6","F","7E2"
    Temp of Batt TB2,"BT2","2187","9 / 5 * E - 58","-58","402.6","F","7E2"
    Temp of Batt TB3,"BT3","2187","9 / 5 * G - 58","-58","402.6","F","7E2"
    Battery Temp 1 C 07E22187 02EA05610687 4010 00010100FFCE BT1 xx C Cell Temp Sensor 1
    Battery Temp 1 F 07E22187 02EA05610687 4010 00090500FFC6 BT1 xx F Cell Temp Sensor 1
    Battery Temp 2 C 07E22187 010702EA0321 1810 00010100FFCE BT2 xx C Cell Temp Sensor 2
    Battery Temp 2 F 07E22187 010702EA0321 1810 00090500FFC6 BT2 xx F Cell Temp Sensor 2
    Battery Temp 3 C 07E22187 010702EA0321 2810 00010100FFCE BT3 xx C Cell Temp Sensor 3
    Battery Temp 3 F 07E22187 010702EA0321 2810 00090500FFC6 BT3 xx F Cell Temp Sensor 3
    Battery Temp Inlet C 07E22187 02EA05610687 3010 00010100FFCE BT4 xx C Cell Temp Sensor 4
    Battery Temp Inlet F 07E22187 02EA05610687 3010 00090500FFC6 BT4 xx F Cell Temp Sensor 4
    and why is your formula "9 / 5 * C - 58" from battery temps different from Inverter Coolant Temp "9 / 5 * D - 40" for example?
    and why you use 1 byte formula and in google-excel priuschat formaula uses 2 byte formulas? like
    thanks.
  14. frenchie
    frenchie Member
    150
    48
    bonjour
    • regarding -50 & -40 just because the offset is not the same (and this was checked).
    • using 1 byte or 2 bytes: just because, regarding battery's temp, 1°C gives enough precision, for the use we have. To know the exact temp is, for instance, 35,21°C instead of 35°C is useless.
  15. vincent1449p
    894
    332
    Singapore
    If you look at Adrian Black's spreadsheet change log, I created the BT1 ~ BT3 on 11/7 and BtT was already found so I did not change the NAM. On 21/11, he updated all to use 2 bytes in MTH and also changed BtT to BT4. So you see, there are no correct or wrong names, just a matter of preference.You can just change to whatever name you like.
    As frenchie said, not all the offsets are the same.
    As above, there was an update on 21/11. Here is the new formula,
    BT1 = (C * 256 + D) * 255.9 / 65535 * 9 / 5 - 58 °F
    BT1 = (C * 256 + D) * 255.9 / 65535 - 50 °C
    Vincent
  16. motoleon
    48
    spain
    OK, ok, thankyou very much.
    I see...
    I have the old formula BATT TEMP=XX - 40 (new inlet temp) and now i modified my software to show all temps correctly.
    Thanks.:cool:
  17. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    I have got the blue BT OBD-II interface from DealExtreme this week and I purchased the Torque full version as well. I made few tests with the usage of USBSeaWolf's csv and they were okay. I just wonder if there is a more fresh version of csv fron GenIII published in this thread. I think lot of development was done in the meantime. I also have to change the temperatures to Celsius as the F are not common for me. I'll simply reverse the PID formulas based on c=(f-32)*5/9. I have to measure the idle power consumption of OBD adapter to learn if it is safe to leave it plugged in all time. The blue box doesn't have a power switch unfortunately. I expect something around 50mA based on the ICs inside the box., e.g. 1.2Ah per day which is not a big deal for daily usage of car.
  18. priusito_de_mi_vida
    priusito_de_mi_vida Junior Member
    78
    Spain
    Hello!
    I've downloaded the file too, but found that the temperature gauges are calculated in ºF, that don't say anything to me.
    I would want to get the gauges on ºC.
    Do you know how to rewrite the equation?
    I saw a duplicated gauge that shows temperatures in both ºC and ºF, and the equation difference is:
    Temperature shown in ºC: A - 40.
    Temperature shown in ºF: 9/5*A - 40.
    That doesn't match with ºC=(ºF-32)*5/9.
    What do you think?
    Anyone known how to change ºF to ºC in torque's equation menu?
    Regards.
  19. vincent1449p
    894
    332
    Singapore
    Hi priusito_de_mi_vida & PaJa and others,
    Yes, I have updated the file and separated into US & Metrics into different worksheet. However, I need someone to test and feedback to me so that I can make improvements.
    PM your email if you are interested to do the testing.
    Vincent
  20. motoleon
    48
    spain
    It IS correct:
    ºC = (ºF-32)*5/9
    ºF = 9/5*A - 40
    ºC = A - 40 = ((9/5*A-40)-32)*5/9 --> A - 39.999
    Correct me if i was wrong...:cool:
