NEW!!! Service Bulletin for Engine Knocking at Startup T-SB 0012-10
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, Jan 12, 2012.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Hurray!!! Toyota have finally acknowledged the underlying problem of knocking on a very cold start and have redesigned the intake manifold to correct it. See attached.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Am I reading this correctly that you will have to throw a DTC before they will replace?
  3. El Dobro
    El Dobro A Member
    7,088
    3,270
    No, it says if one or more of the conditions are exhibited.
    DogDaze and Fostel like this.
  4. seilerts
    3,326
    1,518
    Santa Fe, NM
    It says one or more of the following: P030x, initially runs rough, loud knocking.
    Anybody ever see P030x on their ScanGauge, or have it pulled as a pending or historical DTC?
    Here is the requirement from the service manual for setting P030x. Since cold start knocking may not happen twice in a row very often, it seems unlikely that it would ever get past the pending state, due to two OBD trip detection logic.
    The ECM illuminates the MIL and sets a DTC when either one of the following conditions, which could cause emission control system performance deterioration, is detected (2 trip detection logic).
    • Within the first 1000 crankshaft revolutions of the engine starting, an excessive misfiring rate (approximately 20 to 50 misfires per 1000 crankshaft revolutions) occurs once.
    • An excessive misfiring rate (approximately 20 to 50 misfires per 1000 crankshaft revolutions) occurs a total of 4 times.
    Fostel and cwerdna like this.
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Later in the TSB it talks about reading the DTC, replacing the manifold and then making sure the DTC is reset.
    I was just not sure that this was saying that they were expecting to see a DTC. Mine has never thrown a DTC when this event happened.
    Kdcntn likes this.
  6. seilerts
    3,326
    1,518
    Santa Fe, NM
    I think very few people would see the check engine light. You'd need to have cold-start knocking on two successive start-ups, with at least 10 minutes of driving on each trip. If, for example, you turn the car on, it starts knocking, then you turn it off to avoid damage, this would never get recorded.
    DogDaze, Fostel and jdcollins5 like this.
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Neither has mine. I've experienced it twice, most recently about 2 months ago. I've even had TechStream hooked up since that time, and the "health check" came back OK and never had any check-engine light show up to notify of a DTC.
    I'll definitely be calling my local dealer to schedule this, and make sure to alert them to the fact it's happened twice now.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    This is good. Hard to believe it is caused by the IM.
    There was at least one member here that reported DTC/Check Engine Light during the episode.
    Man, my car will be in the shop for a while with all these TSBs piling up. :)
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes it is hard to believe that it is the intake manifold. The two times it happened to me was within the first 5000 miles. This could hardly be caused by buildup in the intake manifold. Unless of course there are other unknown reasons why they are saying this.
    DogDaze likes this.
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Mine did it several times the first winter I had the car, maybe twice last winter, and not at all so far this winter. I don't understand how it could "fix itself" either. :confused: But I'm not complaining.
    I talked to my Service Manager today to schedule the motor mount and gas strut replacements. I had him enter the problem into my service history so I will be covered if it reoccurs after 60K miles. I don't want to be bit by the extended warranty problem again.
    EDIT: Just reread the TSB and realized that since I am from Oregon I am covered out to 150K miles/180 months for this TSB.
    The Service Manager also thought any one of the three reasons on the new TSB would be sufficient for the manifold replacement, I told him I had never had a DTC with this car.
  11. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    I just called the dealership I used to work for, they will be replacing mine on Wednesday. :) They will also be replacing my window master switch set then as well (the r/r window no longer functions from the master switch). This is exciting, Toyota taking care of problems as usual. :)
    ColoradoBoo likes this.
  12. unreal
    unreal Junior Member
    74
    SoCal
    thanks for the info, im gonna make an appt. for this..
  13. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    CEL for this is basically never going to happen, neither is reproducing at the dealership. Will they take our word for it if we show up and report the issue?
    About time they addressed it.
    I reiterate the first time this happened I am pretty darn sure it was above 40F.
    Tim Jones and Kdcntn like this.
  14. wick1ert
    1,311
    183
    Delawhere
    But was the temperature during the majority of the time the car sat in the "cold soak" under 40F? I think that's the key, as the first time it happened to me it was over 40F when I started the car, but it was in the 20s/30s overnight when it soaked.
    I think that they'll take your word for it if you show up and report the issue. I called mine today, and they said to bring the car & TSB in and they'd confirm it falls under the TSB and then order the parts. Apparently, they don't typically get the TSBs until about a week or so after Toyota issues them, or so they claim. I think they want to try and upsell me on something else too, but we shall see.
    Princer likes this.
  15. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    The dealerships have the TSB already, so if you bring the car in it should be fixed..., but for sure this fixes the issue, ive seen it first hand, the new manifold has numerous ridges in the part of the manifold where it connects to the egr pipe..., whereas the old one it completely straight..., the ridges act like a dam preventing the water that gets built up in the egr pipe from being sucked into the cylinders all at once (which is what happens in the morning on a cold startup), now it allows the water to atomize properly...
  16. SmogSlide
    SmogSlide Member
    128
    17
    Melbourne
    Guess Toyota takes you all in the north more seriously, not so in Australia. There are other TSBs which I wish my local dealer could have done for me, including this engine knocking at cold start.
    I am taking mine in for a service tomorrow and will mention this. But as before, we (Toyota Australia) probably don't have this TSBs in their service schedules.
    Can anyone in the US fix our problems with Toyota Australia?
    GT-I9100T ?
    OzPrius likes this.
  17. duffasaurus
    duffasaurus Senior Member
    177
    Charlotte, NC
    Had both TSBs installed. One on Wed. and the other today. The RR engine mount was on backorder, but arrive in two days. The intake manifold was in stock and arrived today for install. The dealer offered to put me on the payroll for all the time I spend there in the last two day! :) Time will tell if this was all worth the trouble!
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Thanks guys! Got mine printed out. Never happened. Covered for 15 yrs/150k in CA.
    I'm under the 2406 VIN, so it's subject. I assume Toyota Auto Body is in Japan.
  19. El Dobro
    El Dobro A Member
    7,088
    3,270
    This one thing that's throwing me is the VIN listings on the TSB. From other TSBs, there's usually a VIN list for all three factories. If I'm reading it correctly, the listings show Tsutsumi line#2 and the Fugimatsu plant, but not Tsutsumi line#1. Correct?
  20. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ***Mod Note*** Sticking thread.
    Good news - never had it on mine (though valve train is a bit noisier in the AM - not the same issue)
