New Optima 12v Yellow Top D51 battery with Pencil Posts
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Joemontx, Sep 20, 2011.
  1. jdenenberg
    jdenenberg EE Professor
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 OE Battery also lasted 7.5 years (and still holds a charge). I bought my "Pencil Post" with the early $170 coupon and stored it for a month or so before installation.
    I attribute the long life of my OE battery to:
    1. Mostly long trips which keeps the battery at a high SOC - preventing "sulfation".
    2. NEVER fully discharging the battery - partly luck - partly attention to detail.
    JeffD
    torr310 and qbee42 like this.
  2. jdenenberg
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It is the same dimensions as the higher capacity OE in a Gen2 and should fit a Gen3 as well. I'm sure someone with an older Gen3 will confirm compatibility.
    JeffD
    2 people like this.
  3. OptimaJim
    OptimaJim Member
    74
    Wisconsin
  4. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Thanks for sharing the info...price is pretty close to that $170 shipped one :rockon:
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    Jim, my understanding is that the demand for the DS46B24R is very strong, perhaps quite a bit stronger than what you all at Optima were expecting. Are you in a position to comment on future production plans and opening up distribution to additional vendors?
  6. wildbottom
    wildbottom New Member
    99
    Mine will be 6.5 in March. Probably should make 7 years.
    Would be even longer if I didn't leave the Headlights on(It's possible, when I exit from the passenger side door and I use my HL for Daytime Running.)
    Tips for longer lasting battery:
    Keep the Interior cool when parked. Use shades or find a shady spot.
    Top off the 12V battery whenever you can. Esp. when you don't drive it often.
    torr310 likes this.
  7. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    seilerts, as I'm not involved in the sales end of things, I have not heard anything about how sales of that battery are going or when more retailers will be added. I will look into it and let everyone know if I hear anything.
    Jim McIlvaine
    eCare Manager, OPTIMA Batteries, Inc.
    www.facebook.com/optimabatteries
  8. hill
    8,851
    My car-pooler's '08 is starting to throw low voltage symptoms of low battery funk. I noticed an Optima reseller, RIGHT here on THIS thread's right side banner. I called to get a price. He says they don't sell it ... as optima doesn't make it available to them, to resell. :confused:
    Boy ... talk about wasted marketing banners.
    :p
    so much for tryin' to help a bro out
  9. fdf
    fdf Junior Member
    27
    To anyone thinking of buying a new accessory battery:
    eLearnAid has these on sale for $170, including shipping.
    Based on the good reputation of eLearnAid here on priuschat, I ordered one yesterday for my '07. Although the simple voltage tests I did a few months ago showed my original battery was still OK, I'm hoping to keep my Gen-2 until the Gen-4's come out in maybe '15 or '16, so this seems like a good time.
    I'm hoping for 3 or 4 more great years, and if the good people at Toyota have taken care to study the many thoughtful opservations posted here on priuschat, the next generation model could well be even better!
  10. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    That is what I paid for an OEM battery from the dealer last month. No big savings. Delivery time was 1 hour; let's see eLearnAid top that!
  11. fdf
    fdf Junior Member
    27
    Interesting point. I suppose it depends on whether the hype about this battery being better than OEM is true.
  12. Arroyo
    Arroyo Member
    217
    45
    Los Angeles area
  13. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Jim can you through any light on why the Optima is so expensive in the UK? I know the product is very good but I cannot justify spending close to the equivalant $300 for a replacement battery for my Prius when other manufacturers can supply a AGM battery with 40% more capacity for around $100/120. Or is Europe outside of your e brief. Europe must be a huge potential market.
  14. richard schumacher
    7,664
    1,046
    United States
  15. romad
    320
    57
    Prescott, AZ
    Richard, I needed a battery that day, not a week or so later. I got one within an hour. If Optima would sell their Prius battery at FLAPS then that would have been an option. I suppose one could just buy the adapter from eLearnAid and have it on hand. Then you could just get a regular Optima D51 from your FLAPS within an hour.
  16. fdf
    fdf Junior Member
    27
    Wow! I ordered it Friday at 6:30am MST, and it arrived at 4:30pm today, Monday -- California to New Mexico. They sent it in a USPS large "priority flat rate" box with the most fabulous fitting foam packing.
    I just finished installing it. The instructions were well intended, but not the clearest -- maybe more pictures would have been better.
    Rather than using "another car battery" and jumper cable to keep the computers up, I attached a little old power brick I've used in the past for trickle charging other batteries to the jump starting points while I was working. Worked OK.
  17. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    Britprius, unfortunately, I don't have any pricing information on our batteries, either in the States or abroad. If you are looking to pay more for an AGM battery and find our batteries too expensive, I would encourage you to choose an AGM battery that uses pure lead (not recycled). Pure lead makes a difference in performance and lifespan and anyone who uses it in their products is more than happy to share that information with you (we do).
    Jim McIlvaine
  18. mikesarebetter
    mikesarebetter Junior Member
    53
    south dakota
    Not quite sure i need a new battery yet but i found a great deal through advance auto parts website. use promo code VISA and you can get the battery for 150 shipped
    2 people like this.
  19. MeriJeen
    MeriJeen New Member
    Sedona, AZ
    2001 Prius
    I
    Optima Battery at eLearnAid is 180 with free shipping within US.
  20. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    It was cheaper than that at advance auto parts with the "VISA" discount code.
