Oil Drain Access Panel - Gone! What's my MPG hit?
Discussion in 'Gen 3 Prius Fuel Economy' started by HanSolo, Jan 13, 2012.
  1. HanSolo
    HanSolo Junior Member
    Bettendorf, IA
    Well, the title says it all.
    After two years and 50,000 miles I rolled under the car to drain the oil and low and behold the access panel is gone. Completely missing. The up side is it is a clean break along the crease.
    What is the consensus estimate of the mileage reduction I'll expierience because of the negative aerodynamic effect? And, to get a little more technical, the negative effect of the increased cooling in lower temperature driving?
    Thanks!
    Josh
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    One member removed the entire under-cover and reported little to no hit in FE. Certainly that is not conclusive but does give you an idea.
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    You should be losing 3.14 MPG - but removing the hubcaps nets a positive 2.81 MPG - add to that changing your wipers to low profile (1.4 MPG), and you should be doing fine...:)
  4. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    A dead beaver took mine out. I am not paying 300 to replace it
  5. johnnywhale
    johnnywhale Junior Member
    li ny
    None whatsoever. I teach auto shop, one of my student interns at a local toyota dealer bent it back too far and broke it off. i watched him do it, found out the cost of the panel, and gritted my teeth. i remind him of it a lot though!
  6. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    Toyota should replace it free for the life of the car. If you own a Prius and get regular oil changes it will fall off over time. Every Prius has this issue.
    Jin and tumbleweed like this.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I agree that it will make no noticeable difference in mileage. I had the four under body covers off for several thousand miles and noticed no difference. These covers are there to increase mileage by a tenth of a MPG or so to improve the CAFE score.
    I have all the covers back on because it does keep things cleaner and may offer some protection from rocks etc.
  8. HanSolo
    Bettendorf, IA
    Thanks for all the replies. Good to have some agreement that the missing cover won't cost me a noticeable amount of FE.
    Thanks all.
    Josh
  9. Charlie Lear
    Charlie Lear Newbie Evangelist
    Melbourne, Australia
    Mine half fell off the day after a service, and made a loud scraping noise until I was able to park the car over a deep gutter and get underneath to jam it back up. Obviously not clipped/screwed properly after the oil change.
    The dealer got the part price, turned white, and announced that I could either wait a couple of weeks for the part to arrive and make an appointment to have it fitted, or they would put a couple of cable ties on it and renew them each service. Hey, I needed the car...
    This is the same dealer that has been completely unable to detect a dash rattle, even though I have complained about it from when the car was two weeks old.
  10. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    There is a TSB on this. . . go to your toyota dealer.
    Free replacement.
  11. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Please give us more information as our Prius is a 2010 with
    over 71,000 miles and I am concerned that sooner or later
    the oil cover will break or crack.
  12. tumbleweed
    4,067
    687
    Eastern Oregon
    Mine broke off a long time ago and I did a temporary fix (which is now broken also). Toyota refused to replace it because I was over 36K miles when the TSB was issued. Punishment for being one of the first to buy the new model and put a lot of miles on it.
    Apparently they would prefer to save a few dollars by not fixing what is obviously a defective part. Not a good way to treat long time customers.
    Jin likes this.
  13. The Traveller
    The Traveller New Member
    Does anyone out there know where I can find a replacement oil pan access door for my 2010 Prius III?
    I know there is a problem with this and a service letter from Toyota, but my car is now in Europe and the warranty has ran out.
    Thanks,
    The Traveller.
  14. tumbleweed
    4,067
    687
    Eastern Oregon
    You can't buy just the door it's attached to the panel so if you want one you have to buy the under engine cover. Over here you can probably get one from one of the on line discount parts suppliers for $300 or so, I don't know about Europe. You would also need to order some of the little plastic push pins because some of them will probably break when you remove it.
    You can leave it off without any noticeable effect on mileage.
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Saw a unit on e-bay...
