Observations on my new '06
Discussion in 'Gen 2 Prius Main Forum' started by RonM, Dec 5, 2005.
  1. RonM
    RonM New Member
    72
    As posted in the Order Tracking forum, I picked up my new Seaside '06 Option package #8 on Saturday. After a day of playing with it (actually, less than that -- still had to hang the Christmas lights!), here are a few observations that others who received their '06 Prii earlier have not mentioned:
    1) Although the Roadside Assistance Plan has apparently been canceled for the 2006 model year (per the Toyota press release), my '06 still shipped with a sticker on the window highlighting the roadside assistance phone number. No bother, we already have AAA anyway. Just a little odd...
    2) While Toyota tentatively confirmed to me earlier that the California emissions warranty information posted on their web site (showing a shorter warranty than earlier model years) was incorrect, I was a little leary until I could see something on paper. I can now confirm from the actual warranty booklet that I received that the California emissions warranty (which covers, among other things, the batteries) is unchanged.
    3) The diagnostics menu found via the Display, upper left, lower left, upper left, lower left easter egg is different than explained by others on this site for earlier model years (I've personally never seen the diagnostics screen from an earlier model). Now, it brings you to a screen that has various component tests, LAN tests, options to clear codes (good?), and memory (bad?), as well as a secondary menu (no easter egg required) that has multiple options like GPS info, etc. Similar to before, but with a few things like the LAN test that are new (?). I am willing to post pictures of these new diagnostics screens, if there is interest. Please respond to this thread or send me a personal message. I won't bother if folks don't care.
    4) Another curiosity, especially for those tracking versions of the Navigation DVD. As reported elsewhere, when getting the DVD version number from the "normal" non-diagnostics menu, the version is given as "05-01" (doing this from memory, and there was an earlier thread on this, but it seemed to be the same as recent '05's except with a leading (non-significant?) zero). However, if you go into the Navigation diagnostics sub-menu on my '06, the DVD version is reported to be "5-03-14". I know the unit is under the seat, but I didn't bother to try to figure out how to get to it to check the label on the DVD itself.
    5) By the time we did the paperwork at the dealer, it was evening, and I drove it home in the dark. I was very dismayed at how bright the LCD screen was. Later, I discovered they left the dash light switch on full brightness, keeping the LCD from being dimmed. The switch from white maps with dark roads to the opposite at night (black map background with light roads) is MUCH better!
    Still learning about it. I hope to post more things that may be of interest, if and as I learn them.
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    More Data
    Yes, send the screen shots and more 06 data.
    Thanks,
  3. jwe8f
    jwe8f New Member
    174
    Indiana
    On item 1, I wouldn't be surprised if Toyota was turning roadside assistance into a profit center, and they still want you to call the number. Of course you'd have to pay for the rescue, so AAA or something would be better.
    On item 3 you didn't recall the keystrokes as they are on the '05. Have they changed? They were Menu, Volume, upper left, lower left, upper left, lower left.
    Also on item 3, it sounds like you are on the right menu, is there an 'override' button? I think we would be very interested in pictures of these screens, and the one where you hold the 'Info' button down while the car is on, turning the lights on and off 3 or 4 times.
    On the NAV, I think the '06 displays 05.01, but says 5.1 on the disk. No need to check that, we have a recent picture of the disk.
    Thanks!
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    You didn't say if the override was still available. I'd heard a report that it was not. Further, Rick says there's a button to turn of the inside reverse beep noise. Did you find that? Maybe post a quick 'how to' so folks can locate that easily. I saw a screen shot of the climate control screen and was disappointed that a "Vent" button had still not been added. I'd like to see some nice clear shots of the new Energy and Consumption screens as well.
    Congratulations and feel free to keep sharing your new 'discoveries'. Can't wait until a current '04/'05 owner's had a chance to spend some time with one of the '06s to share some insight into the changes.
  5. Tideland Prius
    16,536
  6. RonM
    RonM New Member
    72
    Doc,
    I couldn't agree more that we need to have a tried and true '04/'05 owner look at an '06 first hand. Otherwise, we're just talking at cross purposes.
    There was NOT an override button on the screen where it apparently used to be. In fact, if I understand some of the other, more dangerous, items on that screen, they are gone as well, I think.
    I see a button on one screen that turns off MFD beeps when you select a virtual button, but I did not see one to turn off the reverse beep (also have not tried the '04/'05 method to turn it off either). Frankly, when you get to the diagnostics screens, the buttons are not labeled with user-friendly names (not surprising) and given some of the problems people have gotten themselves into, I was being cautious so as to not ruin things on Day 2 of ownership. (I was also in the garage at night when the temp was in the 30's, so I was a bit rushed)
    I will post pictures of some of these screens, since there seems to be interest. I am a bit surprised regarding the request for the Energy and Consumption screens, but that's easy to do as well.
  7. RonM
    RonM New Member
    72
    Now I am confused as to which Easter Egg is which (and I am not near the car), but isn't the Info-lights-on/off screen the same as the Display-upperL-lowerL-upperL-lowerL? In any case, I will try all the tricks in the recently added posting in the Knowledge Base that addresses them all, and take shots of the various screens.
    No, there is no longer an override button, that I can find. I have not played with the Nav enough yet, especially the voice commands. If, as advertised, there is now the ability to enter a destination (not one of the saved 6) via voice recognition, then its no big deal. If not, then the '06 is lacking in that regard, at least until someone else finds the override...
  8. RonM
    RonM New Member
    72
    One other observation that I forgot to add last night. I don't think it was mentioned elsewhere, but for most option packages, the "splash" screen that appears when you hit the Power button does not say Prius, but rather Toyota (with their logo). The only exception is the option package(s) that get the lower res '05 screen (I think that is only Package #1, or maybe #2 as well -- see the thread on this topic) -- the splash screen is unchanged for those option packages (EDIT- Per the '06 manual).
    In all the documentation of Easter Eggs, hacks, and various things we talk about on this venue, we now need to keep track of whether its an '04/'05 or an '06 (I know, the same issue exists with Classic -- just don't see as many folks posting that the Classic these days), AND which MFD the particular option package has...
  9. efusco
    19,891
    1,196
    Nixa, MO
    Ok, folks, I'm going to confess. I have this very odd "hamstrung" feeling with the '06. New NAV, new screen, new suspension, new interior, new stereo set up and tools, and new reverse camera. I know nothing about that stuff and feel helpless to answer any of the already cropping up questions coming out.
    Very odd feeling for me after making myself into a bit of an 'expert' over the past 2 1/2 years.
  10. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Hehehehe. 'Bout time. B)
  11. OUscarb
    OUscarb Member
    167
    Sooner Land, Oklahoma
    I did a post search for 2006 suspension. No returns. What did they change on that? Sorry if it is common knowledge.
  12. efusco
    19,891
    1,196
    Nixa, MO
    I'm not sure what's changed, but the early press releases discussed that--but those were, IIRC, the European press releases and I don't know 100% that there were any changes made in the NA version....guess we need the NCF for that...I'll check the Toyota site when I get a chance, but some folks who've checked say it isn't out yet.
  13. RonM
    RonM New Member
    72
    As of yesterday, no, it was not yet available on Techinfo.
  14. naterprius
    naterprius Senior Member
    1,843
    Where the heck are the new car features? Techinfo is lacking. Rick57, can you get them?
    Nate
  15. RonM
    RonM New Member
    72
  16. RonM
    RonM New Member
    72
    Hmm... Considering there seemed to be so much interest, including quite a few PMs, it doesn't look like this ended up being information that was useful to people. I'll hold off posting more then. More time to learn the new car...
  17. jwe8f
    jwe8f New Member
    174
    Indiana
    I'm definitely interested, noticed your excellent posts, and will pursue, but tonight is not a good night for details, got a lot of balls in the air at the moment (heh-heh...).
  18. KMO
    KMO Senior Member
    1,916
    657
    Finland
    2023 Prius Prime
    On the suspension front, some changes to suspension, plus other tweaks to reduce noise (eg some fancy new windscreen glass) were made earlier in 2005 in Europe. So there have been 6+ months of refined-2004 production for Europe.
    The 2006 version is now available (at least to order) in mainland Europe (not UK/Ireland), presumably retaining those suspension tweaks. It appears there may be some delay on the right-hand drive 2006.
  19. mchinta
    mchinta New Member
    63
    I am also definitely interested. Please provide more details about new features that you observed.
  20. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    I agree, Evan -- that's the single biggest improvement Toyota could have made to the climate control screen. (Though from what I've seen of it, the general layout has been improved.)
