WS trans fluid not synthetic
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wigwag, Jan 16, 2012.
  1. wigwag
    wigwag Junior Member
    CA
    Given the high price and "lifetime" claim for WS atf I assumed it was synthetic. I bought some for a change and found a MSDS in the bottom of the box. The salient point: "mineral oil concentration by weight- 80-90%" To me this means dino oil. Viscosity is given as 23cSt@40c and 5.45cSt@100c. Make that really thin dino oil. The only synthetic I find in the marketplace that is recommended by it's maker for this application is Red Line D6 with a viscosity of 30.7cSt@40c and 6.4cSt@100c. Does anyone know of any other suitable synthetics?
  2. qbee42
    3,080
    You are talking about transaxle fluid for your Prius? In that case use the stuff recommended by Toyota. In the Prius it also serves to insulate and cool the MGs; do that wrong and you have a very expensive repair bill.
  3. 6lark5
    6lark5 Junior Member
    33
    Elk Grove, CA
    2012 Prius Alpha
    The transaxle is a very expensive part to experiment with.
    ATF WS isn't expensive. Its about $30 for 4 quarts from the dealer.
    I change mine every 30k to 40k miles (about every two years). No problems.
    Its a simple DIY job. Remove and replace. Done.
    My last Toyota lasted 22 years before I sold it. I find simple preventative works best.
    Its cheaper NOT to experiment.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Synthetic or not synthetic is not the main concern. The main concern is whether the fluid is the proper one for the transmission. In this case, WS is the only fluid that has been tested to work correctly.
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    There is at least one person using D6, I think he finally published a good UOA result.
    I'm using WS on a 30k change schedule.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    There may well be some fluids that would do the job just fine but as 6lark5 mentioned the transaxle is to expensive to experiment with.
    There are some fairly high voltages in the transaxle due to the two motor/generators. We do not know how well any of those other fluids would insulate.
    I have had two UOAs done and 30K seems to be a good change interval. Maybe the first change could be done a bit sooner.
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Agreed. Every 30k miles is about every two years for me. At $32 every two years, I see no reason to experiment with any other fluid with this expensive transaxle with the MG's.
  9. seilerts
    3,326
    1,519
    Santa Fe, NM
  10. El Dobro
    El Dobro A Member
    7,093
    3,271
    Synthetic or not, after what I got out of, maintenance on this trans is a veritable bargain.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    do tell... any pictures?
  12. El Dobro
    El Dobro A Member
    7,093
    3,271
    I had a VW with a DSG transmission and the service is at every 40,000 miles. The dealers charge anywhere from $300 to $600 plus to do the service. For a do-it-yourselfer, about the cheapest I've found the maintenance parts alone is $129.00 plus shipping. You need a special tool to add the fluid and you also need something to monitor the fluid temperature during the service. I made the tool myself for around $10, but if you want to buy the official tool, I heard it's over $200 now. From what I've seen of the Prius trans, it's a piece of cake to service.
    Here's the kit for a DSG change.
    DSG Service Kit 40k - IDParts.com
  13. hlunde
    hlunde Member
    419
    75
    Prius does not have a torque converter to generate high shear and heat, and it doesn't have to deal with the clutch wear particles. The only mechanical parts are gears and bearings. But insulation resistance of the oil could be a factor so don't deviate from specification!
  14. Mendel Leisk
    41,909
    ATF-WS is by no means expensive comparing to Honda's CVT fluid, which costs $16~20 in Canadian funds, for US Quarts.
    Also, I don't think there's anything inherantly better in a fluid being synthetic.
    Also, the conscensus around here is it's better to change it periodically, regardless of Toyo's claims.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Synthetics don't normally shear to a lower viscosity as fast as regular oil.
    For a "lifetime" oil there would be some advantage to that.
  16. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    So the transaxle fluid is supposed to last for the life of the car according to Toyota and yet it's not synthetic?
    Or is only the original transaxle fluid synthetic and Toyota's recommended stuff (since it's meant to be replaced periodically) not synthetic?
