Toyota Prius Gen II 120,000 tuneup questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pbratt, Jan 14, 2012.
  1. pbratt
    pbratt Junior Member
    34
    Dallas, TX
    Happy 2012 to everyone on the Toyota Prius chat board! I've found this site to be a wonderful resource in the past few years, and I'm sure it will continue to be a great place in 2012.
    I'm bringing my 2004 Gen II Prius in for a 120K mile tuneup next week. Since I do my tires at Costco, my cabin air filter/engine air filter myself (as well as doing the throttle plate cleaning myself), I'm only having the basic oil change service being done for the basic service. My dealer is generally pretty good, although they really balked at changing the original ATF at 110K, although they finally agreed to do so.
    I've done some recent long term service I had spark plugs changed at 106K, and my inverter coolant was changed when I did the water pump recall at 110K. I'm thinking about having my original engine coolant changed this time around; do folks recommend changing it even if the fluid is still nice and pink?
    I'm not expecting that anything will come up with the brakes, as they were changed at 74K and have plenty of life left in them. The original brake fluid was tested when the brakes were replaced at 74K and it was fine. Should I have the fluid tested to see if it needs to be changed?
    Finally, I was looking at the boards and saw that some people recommend ditching the 12V auxiliary battery at the 120K service. I still have my original and it has never caused any problems. Any thoughts?
    My prius has been a great car, and I've never had any maintenance issues (with the exception of the water pump breaking and being recalled). I'm very glad to have had it for 120K, and look forward to taking it to 250K.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    How about the serpentine belt? It should be replaced now, if it is the original. By the way, if you can clean the throttle plate by yourself, then you can replace the belt by yourself. Any chance that they did the PCV valve when they did plugs?
    Check around the engine water pump for a leak. Look for little pink splotches on the pulley and on top of the A/C compressor. If no leaks, and the coolant level is full, it is probably safe to keep running on the factory fill for a while longer. If there is a leak, then get that water pump changed and a coolant exchange happens by default. 100K is the initial service interval for the coolant, so it should be changed out sooner rather than later.
  3. Patrick Wong
    18,210
    6,515
    Yes, I recommend changing the engine coolant in the near future.
    No, I would not worry about the brake fluid at this time.
    Regarding the 12V battery preventive replacement, it depends upon how inconvenienced you would be if the battery were to fail at a random time, vs. how much you feel the need to squeeze the last dregs of life out of the battery. In my case, the former weighs more heavily than the latter so I would recommend replacing that soon, especially since we are well into the winter season.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    With that kind of mileage and since it has run on dyno oil its entire life I would check the condition of the VVT oil filter. Its a very small oil filter that cleans the oil that drives the variable valve timing system.
    If your interested in this please search back my old posts as I have an indepth write up about it.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I would also replace the inverter coolant as it a number of dealer techs have told me that they are not draining the coolant when replacing the inverter pump as part of the recall. They are telling me that they merely clamp off the hoses, replace the pump, top-off and bleed.
  6. The Critic
    3,193
    2,333
    CA
  7. pbratt
    34
    Dallas, TX
    Dear All:
    Thanks for the great thoughts. I've replaced the serptine belt at 75K and 110K, and the inverter coolant was replaced both times as well. I actually only drive the car on weekends, as I take the train to work. My wife does much of the driving, and since she has a pretty good head on her shoulders, I'm sure she knows what to do if the auxiliary battery dies-get a new one.
    Thanks again-I'll certainly get the engine coolant replaced.
    Cheers,
    Peter
  8. pbratt
    34
    Dallas, TX
    Update after going to the dealer-everything is looking pretty good. I had the brake fluid changed as it was getting discolored-something that one would expect at 120K. As always, the dealer recommend that I get the fuel injector flush, which is always declined.
    However, the technician did say that my radiator hose might need to be replaced at the next 15,000 mile service. It is getting a bit corroded, and folks on the boards have recommended that one replace these anyway at 100K. However, since it would take six hours of labor, the total cost would be $650 (150 for the parts and new coolant, 500 for the labor). Does that sound right for the length of work?
    I'll probably end up getting the new radiator hose sooner rather than later-summers in Texas get pretty hot.
  9. Patrick Wong
    18,210
    6,515
    I'd say that the labor hour and the parts cost estimate is quite high and you should look around for a better quote.
    I also suggest that you squeeze the radiator hoses yourself (especially the one connected to the thermostat housing) and satisfy yourself that they actually need to be replaced.
  10. pbratt
    34
    Dallas, TX
    It does seem high, doesn't it? This is going to sound like a dumb question, but where are the radiator hoses:( located? First time I've really looked.
    I will check out other places for pricing and labor.
  11. Patrick Wong
    18,210
    6,515
    Well, one hint is that an end of each of the two hoses is connected to the radiator. :D
    The hose that will become bad first is the hose which is connected to the engine thermostat housing because that hose is exposed to the hot coolant exiting the engine. This can be easily seen as you look at the front of the engine, below the intake manifold. Squeeze the hose to see if it is pliable (which is good); or if it is becoming brittle and cracked (which is bad.)
    The end of the other hose will connect to the engine head. That hose provides cooler coolant back to the engine.
  12. pbratt
    34
    Dallas, TX
    Thanks now I know where the hoses are:) The front one looks a bit worse for wear, and the first one is a bit brittle and cracked. So I'll probably end up replacing both, just because it makes sense (IMO) to do both at the same time.
    I emailed around to different Toyota dealers, and of course I got another couple of quotes for the same service for less than $200. You can guess where I'm going to go, especially since one of the quotes is from a place that has done good work previously.
