Fog Light question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Remstarasianboy, Jan 17, 2012.
  1. Remstarasianboy
    Remstarasianboy Junior Member
    Austin TX
    2013 Prius v wagon
    I would search but my iPhone app doesn't search the forums well. Anyways I wanted to buy the Prius fog light kit off of eBay.
    Does anybody know of the Prius pre-wired for this or would I have to run the wires.
    I had a Saab 9-2x and when I bought the oem kit all I had to do was remove the fog light covers and put the lights in. The wires zip tied right behind the covers. The switch went into place and it worked. Took about 5 minutes to do.
    Has anybody done this yet?
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Off topic but I too went from a Saabaru 9-2x into a Prius.
    Posted from my iPhone via the Tapatalk app.
  3. bullittman68
    bullittman68 Junior Member
    unknown
    2017 Tesla Model S
    I went from a Subaru WRX wagon to a Prius. Same size and functionality, but this one costs half as much per mile to drive.
    To answer your question, no it is not pre-wired... Sorry!
  4. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    What kind of fog light kit are they exactly? If they are the oem quality that are sold here in the prius chat shop or the dealer than they have excellent instructions already that I personally followed. If you go to the top of the accessories & modification threads, look for a stickied thread on "OEM quality fog lights" you will find 2 sets(1 black & white, the other in color) of pdf instructions that should help you.
  5. Remstarasianboy
    Austin TX
    2013 Prius v wagon
    They are Toyota oem and come with the lights, wire and switch. Thanks I will check our forums.
  6. Tideland Prius
    16,632
    Well the kit will come with everything (if it's OEM) but you have to wire it up yourself and thread a wire into the firewall into the driver's side footwell area to hook it up to the switch.
  7. SoCalBPrius
    563
    118
    SoCal
  8. SoCalBPrius
    563
    118
    SoCal
    & tell us how the install went w/pix. after your finished:).
  9. Remstarasianboy
    Austin TX
    2013 Prius v wagon
    Will do. Thanks guys.
  10. OilRigPilot
    OilRigPilot New Member
    Columbia, SC
    Just wondering if anyone else is NOT impressed with the light output of the 2012 FOG LIGHTS ??? IM NOT !!!! Has anyone changed these out with High Output LEDS ??? If so, post some pics please... and report on the difference..
    thanks
  11. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Just used the 2012 Five OEM fog lights for the first time last night- they pretty much blow :( they're useless actually- but they look nice in the grill.
    The Five's LED lowbeams are far superior....
  12. mario24601
    mario24601 New Member
    Los Angeles
    I went from G35 coupe to Prius ;)
  13. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Well, they are foglights, not driving lights.
    You can also replace the bulbs with yellow colored ones. They will illuminate the road a bit better, where you can "see" better, especially in bad, rainy conditions.
  14. ny_rob
    1,968
    813
    L.I.- NY
    Yeah, and it was foggy last night... that's why I tried them.
    Like I said- they were useless in the fog. They added no additional benefits over using the factory LED lowbeams.
  15. ewilke
    ewilke Junior Member
    33
    socal
    You do have to run the wires but hey are set up good
    I got the factory ones from e bay the fog lights are not bad as for brightness I wired the to turn on with the car so I use them as day time running lights.
  16. Tideland Prius
    16,632
    Technically the foglights would be run with the parking lights (and low beams off) but then regulations here say foglights must come on with low beams so they're pretty much useless. In the 2010/2011, the beam seems to shine a bit more to the sides of the car (possibly because they're mounted at the corners of the car rather than inboard on the air dam like the Gen 2 Prius).
  17. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Although mine is not a 2012 model but I'm satisfied with it when it comes to driving in fog and rain. At one time, I was driving in heavy fog without a fog lamp and the projectors did it's job - an advantage over the free form halogen healights.
  18. ImeanGreen
    547
    73
    Somewhere out there
    Best mod you can do for the foglights.
    Really true. Bought a pair of putco jet yellow bulbs with half the price of the PIAA and etc. Very please with the light's performance. I'll post a picture of the light color if I have a chance tonight.
  19. ny_rob
    1,968
    813
    L.I.- NY
    Yeah, that's why I commented that they're useless on the 2012 Five- cause the low beams remain on when you activate the foglights- which adds even more light to the foggy road ahead of you :mad:
    Better off with just the LED low beams.
    Now if you could (legally) turn off the low beams and just have the fog (and parking) lights on- then they'd probably improve visibility in the fog.
