can it do this? i hope i hope
Discussion in 'Newbie Forum' started by pressgo, Jan 24, 2012.
  1. pressgo
    pressgo New Member
    CA
    Hello, I need some input to see if this car is a good match for me. For work, I drive about 75-90 miles a day. Lots of freeway, lots of residential, lots of start up/shut off. Hills are ample about twice a week. Will always have two passengers. I know the prius is not a work horse but can it handle this day to day? if so, for how long do you think? Will high value parts need to be replaced often with this work schedule? currently looking at the Prius Two and thinking about the cost/benefit. Thanks in advance.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    Santa Fe, NM
    Because you will always have a passenger in the back seat, with frequent entry/exit, then you should make a point of cleaning out the hybrid battery fan once/year, but otherwise, there are no special considerations and as far as new cars go, a Prius would be hard to beat on the cost/benefit.
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    That is plenty long enough to warm up and get good mileage. Short trips are lower MPG than long ones.
    How long is it shut down? If your 75-90 is several short trips separated by hours, it may not be as ideal.
    My Prius is a workhorse, yours will be too. I admit I carry fewer passengers. [​IMG]
    Half a million miles?
    For budgeting purpose, I would assume I needed a $2000 battery every 200,000 miles.
    Plan on a $200 12 volt battery every 4 years.
    The inverter can cost $5000 and is most at risk if you ever jumpstart your car wrong. I carry jumper cables that don't let me do it wrong. Buy.com - Michelin 5100 Smart Jumper Cables w/ Surge Protection
    A transaxle is also $5000, for about $100 every 60,000 miles you can have the ATF changed.
    Here is my 'who should not own a Prius' post http://priuschat.com/forums/newbie-forum/94450-considering-prius.html#post1334003
  5. pressgo
    pressgo New Member
    CA
    shut down varies between 5 minutes to 2 hours. Average is probably around 35 minutes. my 75-90 miles are usually divided into 6 to 9 trips. is the prius still looking good for me? if so, i am thinking i should buy new since i need those miles. thanks again!
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I wouldn't worry about the shutdown. The longer the shutdown period, the more time the engine has to cool down and hence, the longer/bigger the mpg hit (due to cold/cooler engine). But, this isn't specific to the Prius. This affects all IC engine based cars.
    Now, you have the tough choice of picking a leftover '11 Two or a '12 Two. See http://priuschat.com/forums/gen-iii...490-2012-prius-now-dealers-2.html#post1454606. The '12 Two gets a lot of features that previously required you to pay more for, but I doubt you'd see great deals nor incentives on the '12s yet, since they are just now hitting showrooms vs. dealers wanting to clear out old '11s.
  7. seilerts
    3,326
    1,517
    Santa Fe, NM
  8. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    ...the thing is, the Prius is a good work horse. I would think you fit the profile of many Prius users: they bought it because they put on a lot of miles and need to reduce cost per mile. Where you might want to focus is comfort for so many miles, no complaints here, but our 06 interior is not quite as comfortable as say a Camry or Accord type vehicle for multi-hour (long) rides.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    OP should take comfort from the Prius as a taxi experiences.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Wonder if he'd have 2 passengers all the time. If so, c might be too small.
    I think when people actually see the c, they'll do a double take as in 'wow, it's pretty small'. Not sure everyone realizes c is a subcompact car. It's 4" shorter than Honda Fit.
  11. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I think the Gen III Prius would be great for your need, assuming you don't need to carry a lot of heavy cargo along with your passenger. (I assume there will be driver and one passenger, yes?) Since you said you have a lot of residential (stops, I assume), I would strongly advise getting a 2012 with the standard EV noisemaker function. I have had adults look right at me while driving slowly in EV mode and walk in front of the car because it was silent. I can imagine that kids on neighborhood driveways and streets would be worse.
  12. seilerts
    3,326
    1,517
    Santa Fe, NM
    It is not too small if you are the driver. :)
    Seriously, to have the choice between 3 cars of varying size/utility with 45-50 mpg ratings is another giant step in the right direction.
  13. pressgo
    pressgo New Member
    CA
    new 11' or 12'...not a hard choice for me. i would pick a new 11' if i can save some money now that the 12' is out. unless the 12' has some vast improvement in vehicle performance (i do not need the bells and whistles) i see no need to get the latest and greatest. i do need all the miles i can get so a new 11' or 10' would be good. i would go to lower years if i can find them new.
    also, 3 people total including myself. no V needed. the back of my head would get constantly slapped if i got the C and i would never hear the end of it. thank you all for the help!
  14. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    The Prius has been in use as taxi cabs in cities like New York, racking up crazy miles (we are talking 300,000+ miles in the space of a couple years) under harsh urban stop-and-go conditions with virtually no problems, aside from operator-caused errors (i.e. accidents).
    If the Prius is tough enough to serve as a taxi cab, at the hands of some of the most abusive drivers this world has ever seen (NYC cabbies!), the Prius will handle your demands like a walk in the park.
