Gen2 Prius: Custom PIDs for Torque (Android App) with formulas
Discussion in 'Gen 2 Prius Technical Discussion' started by usbseawolf2000, Jun 24, 2011.
  1. Flying White Dutchman
    4,376
    313
    what i read is that dealta SOC is :
    when the prius wants a SOC of 60% but its unable do to so and deviates from the wanted 60% more then 20% its bad
    so if prius wants 60% but its at 30% and unable to bring it closer to 60% ( within the 20% range from the prius 60% ) then it wil set a code and you have a bad battery
    if you prius wants 60% and it gets up to 50% then its a delta soc of 10% and thats stil good.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
  3. thatguy
    thatguy New Member
    Virginia
    Question about the MG1 and MG2 temperatures:
    Are the equations assigned to the correct description?
    If you look at the equations for MG gate status, MG torques, and MG RPM, you will find that MG2 comes first in the reply and MG1 comes second. For example:
    MG2 RPM = ( ( 256 * A ) + B ) - 16383
    MG1 RPM = ( ( 256 * G ) + H ) - 16383
    I know the RPM values are right because they match what you would expect when driving.
    However for the MG temperatures our spreadsheets list:
    Motor Temperature No2 | MG1 Temp | 1.8 * AA - 58
    Motor Temperature No1 | MG2 Temp | 1.8 * AB - 58
    MG1 Inverter Temperature | MG1 Inv Temp | 1.8 * Y - 58
    MG2 Inverter Temperature | MG2 Inv Temp | 1.8 * Z - 58
    Are the MG's really switched, or could this be a typo from the scangauge that got carried over? Has anybody verified that the MG temperatures are correctly assigned?
    Why do I care? I am trying to diagnose a problem that requires me to look at the MG temperatures. One of them ( AB ) is 50-70C hotter than the other. If MG1 is warmer I likely need a wheel bearing replacement ($$$), if MG2 is warmer I probably have a winding failure ($$$$).
  4. seilerts
    3,326
    1,519
    Santa Fe, NM
    I suppose you have checked the obvious, that the inverter cooling pump is running, and that the case has the appropriate level of reasonably clean ATF WS?
    Don't use a computer to diagnose a wheel bearing. Jack up the front of the car and see if the wheels turn freely, and that there is no axial wobble that would be the hallmark of a bad bearing. You can also inspect the axle seals in the process.
  5. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    No, it is not a typo, I actually corrected the error in this post. The Repair Manual refers Motor 2 as Transaxle and Motor 1 as MG2.
    Was the temperature difference during first start in the morning or after driving?
    Another way to confirm if it is MG2 is to temporary disconnect the temperature sensors to measure the resistance. Pls refer to this guide on 21-14 (Pg 358). Compare the resistance of C1-C4 (MG2) against C3-C6 (MG1). Both should be roughly the same after you parked overnight. If there are big differences, it could be sensor faulty.
    Next, just connect back MG1 temp. sensor and leave MG2 temp. sensor disconnected and power on car. You should get DTC P0A2D/249 and MG2 temp. should read -58F in Torque. The DTC can be cleared by Torque later.
    Vincent
  6. Flying White Dutchman
    4,376
    313
    where do you read its cell delta soc? and not the total pack delta soc
    the link that I already posted before does not tell me cell delta soc?
  7. thatguy
    thatguy New Member
    Virginia
    Thanks for doing all the hard work to maintain and verify the Torque extended PIDs. They have been immensely valuable for both improving regular driving and diagnosing this problem.
    After sitting overnight, both MGs report the same temperature. I haven't driven the car since I saw the >50C delta because, with the knowledge that MG2 was running so hot, it was clear that I have a bad winding. I'm getting quotes on swapping out the transaxle; the next time I drive it will be to a shop.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Wow, how many miles do you have on your 05?
  9. thatguy
    thatguy New Member
    Virginia
  10. jlim888
    jlim888 Member
    78
    36
    Hi USB,
    Quick question: I read on PLX website that KiWi has a power switch. Do you need to turn this power switch off? I'm afraid the Kiwi might drain the battery.
    Thanks!
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You don't need to. I just leave it off and my battery has never drained. When I went on 5 days vacation, I turned both the Smart Key System and forgot to turn off Kiii. I came back and Prius started fine. I think SKS consumes way more than Kiwi.
    Anyway, 5 days is not much and I have Optima battery installed.
  12. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    If I'm going to have my Prius sit more than 3 days I shut off the SKS and pull the plug for the Kiwi out of the OBDII port (I have the unit hidden in the center kick plate). I need an Optima battery as my OEM is on borrowed time.
  13. rosco64209
    rosco64209 Junior Member
    FL
    You should have no problems leaving the kiwi on at all times. I had the kiwi plugged in with two cell phone chargers, gps, and radar detector plugged into ciggerette lighters (no mods on cigerette lighters) also SKS was on. Parked in parking garage at tampa fl airport for 9 days and it started up no problem. I bought the car used 2 years ago and havent replaced the battery so im assuming its oem, but could be wrong. On another note, can someone look at my layout... am i missing anything really important (the gps sat is there bc my gps in my transformer prime is non existant for 99% of the time so i thought i would put that there to see how bad it really sucked)? am i using the right profile info? is there a way to change the values of the meters like my HV SOC should only go to 100% right not 160 or can you not change that? if anyone would like to share some tips or what numbers they are shooting for that would be AWESOME!!
    Engine Displacement: 1.4 l
    Weight: 1400 KG
    Boost Adjustment: 0
    Max Dial RPM: 7000
    Volumetric Efficiency %: 51.0 (This is the gen3 value. What is the gen2 value?)
    btw for people with tablets all you need to do is make the extendedpids folder in .torque then add the .csv. I could find the .torque folder but there wasnt an extendedpids folder in it so i just created the folder and copied the csv over.
    ps. A HUGE THANK YOU to usbseawolf2000 and everyone that contributed to putting this together. Keep up the good work!
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Looks like you have everything useful in there. Transformer looks good. How did you take the screenshot? Did you have Torque email the screen to yourself or was there another way to do it from Android OS?
  15. rosco64209
    FL
    i took the screenshot by holding the recent apps button. if you look at the pic you can see the button being pushed. im running ice cream sandwich on my prime so i dont know if the screenshot is a ics feature or a feature of the prime but if you hold the recent app itll take it. but its good to hear that i got the bulk of it on screen. after i learn a few things ill probably split the screens up and have all large icons. lol theres alot going on that one screen.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Here is a game you can play with MG1 and MG2 horsepower. Try to keep them toward zero. That means the gas engine power to the wheels would be near 100% mechanical. That should give you the highest efficiency since it is not going through the electrical path.
    You'll find it almost impossible to do it at very low speed so that's ok. The electric motors are designed to use for that reason. Any time you are above 42 mph, you can easily keep MG1 and MG2 power near zero. You'll find the car speed gradually increase. You can then coast or glide and repeat the process again.
  17. Mrn
    Mrn New Member
    Europe
    "That means the gas engine power to the wheels would be near 100% mechanical.... "
    How can the car move without any breaking force of MG1?
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    There has to be MG1 torque to counter the 28% from the gas engine. However, it would be spinning so slow that the power (torque x rpm x constant) is very low, near zero.
  19. mrbigh
    3,686
    699
    Long Island, NY
    And that will be called driving by instrumentation
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    One issue with the MG torque readings is that the resolution is too coarse. So a small non-zero torque value would show up as zero. For example when I glide the torque readings almost always show zero even though there are some HV currents flowing.
