2012 fog light / DRL question
Discussion in 'Gen 3 Prius Main Forum' started by Suprius, Jan 30, 2012.
  1. Suprius
    Suprius Junior Member
    29
    L.A, C.A
    Hey guys, I recently picked up 2012 III and noticed the DRL are now where the fog lights use to be on the 2011's. When you turn on the main headlights the DRL turn off. So now I was wondering how do the fog lights work on the factory equipped 2012s and is their maybe a mod that we can do to set the DRL on with the headlights?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You mean the Five with integrated fog lights? Someone should chime in and tell us how that works (once the 2012 Fives hit the street).
  3. Zanrok
    Zanrok Casual Prius Lover
    176
    27
    Reno, NV
    I was wondering the same thing... I looked briefly at the manual, there is probably some switch we are missing.... ill toy with it later.
  4. jaredy
    jaredy Member
    162
    SoCal
    OP changed.
  5. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    like most cars w/ drl, they do turn off when the headlights are on. Owning many cars with them (97 Camaro, 01 Saturn SL2, 07 Civic, 04/06 Z06), they all turn off. DRL is suppose to make you more visible but you won't need them with the headlights on. Of course, I always wonder why they didn't put the DRL's until 12's.
  6. Zanrok
    176
    27
    Reno, NV
    Well I spent about 2 minutes looking at the different options last night. It appears you can have DRL off, DRL on, lights on, and lights off. I didn't see an option for fog lights and lights on. But since the "fog" likes are the "DRL" right? I guess it's one or the other. :confused:
    Maybe there is some trick we are missing.
  7. qbee42
    3,074
    DRLs should be off when the headlamps are on. That's the way they are designed, and presumably required by law in some areas.
  8. Suprius
    29
    L.A, C.A
    I know that is true, but since the 2012 DRL are in the same exact spot as 2011 fog lights, I thought their might be a mod we can do to use our 2012 DRL as fog lights with the headlights.
  9. movingforward
    movingforward Member
    169
    The Great White North
    Looks like you'll have to do an auxiliary install that mounts on the front lower grill area. This will sound like it's not very DIY friendly.
  10. skm009
    skm009 Member
    132
    Ohio
    In case you didn't know. This is how the fog lights would look on 2012 prius V.
  11. kanevil
    kanevil New Member
    34
    San Gabriel, CA
    FYI I went to the parts dept and asked them bout the factory fog lights and they said that Toyota doesn't make a kit for them so one has to buy the parts seperatly and everything would be about $600 not including labor, ouch!
  12. WE0H
    WE0H Senior Member
    3,247
    528
    Don't worry just yet, there very likely will be a kit available from Prius Chat.
    Mike
  13. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Saw a 2012 with foglights at my local dealership. The foglights are located where the gen ll foglight location is. The DRL's are just plain DRL's without a fog light function.
  14. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Thanks for posting this pic in particular. If this one is equipped with ATP then that's what I hope to be driving soon.:thumb:
  15. SSPigboat
    SSPigboat Junior Member
    Illinois
    I'd be up for getting a kit when they become available.
  16. OilRigPilot
    OilRigPilot New Member
    Columbia, SC
    Just wondering if anyone else is NOT impressed with the light output of the 2012 FOG LIGHTS ??? IM NOT !!!! Has anyone changed these out with High Output LEDS ??? If so, post some pics please... and report on the difference..
    thanks
