Had one Integrity tire replaced with Eagle LS. Will this be a problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by paulisme, Feb 2, 2012.
  1. paulisme
    paulisme New Member
    179
    Charleston, SC
    A few months ago I had a new set of Goodyear Integrity tires installed on my Prius. This afternoon I had to get one of them replaced because of damage to the sidewalls. When I took the car in, I asked that the same type of tire be put on, but it didn't occur to me to check the tire until I got home. Of course the tire ended up being an Eagle LS instead of an Integrity. Would it be OK to keep this tire, or should I take it back and have an Integrity put on? I'm not sure how different these tires are or how important it is to have all four tires be the exact same model.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I would take it back and demand the G/Y Integrity . Is the LS a LRR design? Hal
  3. F8L
    19,011
    4,081
    Grass Valley, CA.
    I would never suggest running two different models of tire on the same "axle". You always want to maintain a pair of similar model tires for the front and a pair for the rear. Because different tire models react differently to road conditions it is not generally considered a good idea to run an oddball tire like this.
    Regarding the tire tire choice, Tirerack.com rates the Eagle LS poorly which is to be expected for a cheap tire. The tire is also likely to have a higher rolling resistance than the Integrity and could cause lower gas mileage but it is hard to say for sure since you only have 1. The Integrity is a terrible tire so if you decide to have the Eagle replaced with a LRR tire I would suggest something better like the Goodyear Assurance Fuel Max if they are stuck on giving you the Goodyear brand. Then offer to buy a matching tire so you can have a matching pair. Have those installed in the rear and keep a pair of integritys on the front.
  4. qbee42
    3,074
    The bigger problem is the three remaining Integrity tires. I gave mine away when they were new.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Good lord why would you buy another set of Integritys. They are the worlds worst tire.
  6. cnschult
    cnschult Active Member
    772
    96
    Michigan
    The world is a big place and includes China, what if we said the Integrity was the worlds worst tire to be made outside of China?? That's a little more realistic
  7. paulisme
    paulisme New Member
    179
    Charleston, SC
    Gee, these comments are incredibly helpful. Having owned 4 different sets of Integrity tires on 2 different vehicles and not having a single incident with any of them apart from running over a nail here and there, I find it hard to believe they're the worst tires in the world.
  8. Hal W
    Hal W New Member
    872
    53
    My 06 is still on the original Integrity's! I liked them so much I purchased G/Y Fuel Max for my HCH2. I don't understand where you guys are coming from! Are you road racers or Hyper-milers?, or do you just hate Goodyear! Hal
  9. F8L
    19,011
    4,081
    Grass Valley, CA.
    Integritys in a lot of cases exhibited very poor wear and they had horrible stopping distances. There appeared to be a fluke where the Integrity had excellent dry stopping distance but that data conflicted with other data I had read where it showed the Prius having a horrible stopping distance for it's size and weight compared to other vehicles in its class.
    That being said, they are not super cheap tires so why buy them when there are better tires out there for the same price or just slightly more?
    Check out the mpg and wet braking data for the Integrity. Approx 2.4 less MPG and more than 15' more stopping distance than the leading competition.
  10. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Same here. My '06 has 58K miles with plenty of tread left to go on the OEM Integritys. I had an '04 on which the OEM Integritys still had some tread left when I replaced them at 63K, again with the Integritys. I'm sure there are better tires out there, but I haven't had any bad experience like others have reported here.
  11. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Some of us have higher standards and can tell the difference.
  12. qbee42
    3,074
    It's not that; it's just that I value life. The Integrities were okay for dry summer driving, but they were a hazard when it rained and a death wish in snow. Even with VSC the Prius was unmanageable at highway speeds in wet conditions.
    I run Goodyear tires on my Jeep. Big snow tires, all year long. They work well, but scream like a banshee if you brake hard on dry pavement.
  13. Hal W
    Hal W New Member
    872
    53
    Well they are a summer tires[ maybe all season?]and in places that get rain on occasion road surfaces can get very slippery due to oil on the surface when it does rain. But any tire can be a hazard under these conditions! I am willing to bet that 99% of the unsatisfied people of the stock tire are not running 185/65/r15's as a replacement! I feel most people feel this tire is to small for the weight of a Prius and use this as a reason to up-grade!. Hal
  14. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Exactly. And if you had moved up to a better tire you would have felt, and heard the difference immediately.
    At 20,000 miles my Integrities howled so loud it was ridiculous and if pumped up to 42 lbs hit really really hard. That is a very stiff sidewall tire which makes it a death trap in the rain or snow. There's so many complaints about those tires on this board its right there behind the stock battery in hits.
    I have $62 Kumho's non lrr's and its like a new car.
  15. ursle
    ursle Gas miser
    1,049
    192
    NH
    When one's roof is another's floor who's to argue?
    I bet both of you have your original batteries also.
  16. edthefox5
    10,096
    4,806
    Clearwater, Florida
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    FWIW, the stock Integrities are pretty crappy tires.
    That said, too bad the OP isn't near me as I'd otherwise give him my extra Integrity (which has plenty of tread life left) for real cheap. If anyone who lives in or near San Jose wants it, let me know. I'd only want $3-5 for my time and gas...
    It wasn't an original that came w/my car but rather one I bought when I had an unrepairable puncture and didn't want to have 3 of one model and 1 of another.
